Go to Post Heat Gun(n.):Your build season replacement for a microwave. - jajabinx124 [more]
  #46   Spotlight this post!
Unread 05-03-2007, 12:15
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: keepers once the match has started
Originally Posted by Luke View Post
When I watched that event happen my first thoughts was that the rules as stated meant the NJ ref should have DQ'ed the team instead restarting the match. Each new match the ref continued to prevent the DQ offense from happening by walking onto the field and wrestling the tube off the robot after autonomous. My thoughts were that this is not what the rules says. But wait am I going defend a rule which I believe is too harsh? What I believe now is, we were seeing the ref was trying not to DQ a team due to a rule which carries an undue and too harsh Penalty and needs updating.
Why should this carry a DQ penalty? This is the goal of the autonomous and if you just missed but accidentally put the keeper on after, why a DQ? Usually a DQ is due safety or equipment damage or unfair advantage; I do not see that here.
I think FIRST should rethink this harsh penalty. From the actions of the NJ refs, I believe, that they DID NOT wanted to make that DQ call either.
GOOD CALL NJ REFS!!!
The NJ match in question was stopped because of a mis-communication between the head ref and the scorekeeper/field controller. The match should have been paused until that keeper was removed from play.
One of the main jobs of the head ref at the end of autonomous is to remove any "precariously perched" keepers to specifically avoid that situation (an inadvertent score at the start of tele-operated period), THEN signal to the field controller to continue the match. You should see this happen regularly at all of the competitions this year. The DQ penalty is in place more for a deliberately placed "late" keeper.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
  #47   Spotlight this post!
Unread 05-03-2007, 12:31
Stu Bloom's Avatar
Re: Keepers after autonomous
And I will repeat here what I answered there.
Head referees have been instructed by FIRST to remove any precariously positioned keepers at the end of autonomous period to avoid an inadvertent scoring of a "late keeper". In cases where the keeper is entangled and/or difficult to remove it will be cut and removed. You will see this at all competitions this year.
Stuart Bloom
Mechanical Engineer
  #48   Spotlight this post!
Unread 05-03-2007, 12:56
Luke Luke is offline
None #0365 (Miracle Workerz)
Luke will become famous soon enough
Thanks, that explains what I saw as well.
As an aside, many times actions are not alway communicated clearly or at all to spectator either, I wish they would so we could have the facts too and not be left confused, trying to figure it out.
Weight of game pieces (Ringers/Spoilers/Keepers) Setsanto Kit & Additional Hardware 16 15-01-2007 21:05
the countdown has started xzvrw2 Chit-Chat 2 12-07-2005 03:39
MARCH MADNESS -- has it already started??? wasabi824 Chit-Chat 13 22-03-2004 01:45
ONCE AGAIN, EVERYONE TELL ME THE ANSWER! =) archiver 2001 2 24-06-2002 02:42
has the new season started, or what? Brandon Martus Announcements 1 10-01-2002 02:42
