Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 05-03-2007, 15:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Team 1114 -- Simbot Prime
Could we get any more info on the drivetrain? closeup pics?
There was a thread during the offseason showing their prototype 6wd chassis. I believe it's very similar to this, with some modifications (direct drive on the center wheel, etc).
2001-2004: Team 100
2006-Present: Team 254
Unread 05-03-2007, 15:25
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Originally Posted by Karthik View Post
Lots of things.
Seriously, it's more fun to let people try and figure it out.
hmm.....i think I am starting to put this together
Unread 05-03-2007, 15:32
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
...but where is the flag holder?
Unread 05-03-2007, 16:06
Kate00's Avatar
Kate00 Kate00 is offline
Not In My House
Kate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond reputeKate00 has a reputation beyond repute
That was what I was wondering.
[Kate Mosley]
Unread 05-03-2007, 16:55
Ian Mackenzie Ian Mackenzie is offline
FRC #3683
Ian Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond repute
Good catch, but it is there, just hidden. And yes, it does stay (approximately) vertical THROUGHOUT the match...I'll let you figure out how that works (it's non-trivial, and took way more work than it should have).
Unread 05-03-2007, 17:08
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
Talking Re: pic: Team 1114 -- Simbot Prime
I bet you have it spring loaded so tat its kept up at all times and when you flaps go done the tension releases it to aim straigt up.
Unread 05-03-2007, 17:10
Bharat Nain's Avatar
Is this used to scoop pop corn from the popcorn machine?
Yet again, nice job. Another impressive robot.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 05-03-2007, 17:14
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
When you see how the flag holder works and where they placed it, you will be
Unread 05-03-2007, 17:27
AdamHeard's Avatar
Lead Mentor
Is it mounted on a pivot on top of your manipulator with a weighted bottom so it stays near vertical by balancing?
Unread 05-03-2007, 20:32
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
Originally Posted by Jay Trzaskos View Post
I love this robot, and from what I can tell, and from what I've heard it's manipulator is amazing. But my Question is this. Whos coaching this beast? Karthik, are you still taking on strategy and such on the sidelines, or are you going to jump back in the box? I just know that I can't wait to see video of this beast in action.
I will be coaching again this year. I can't wait, this game is going to be a fun one to coach!
So far Vince is the closest. We'll see if Simbot Prime works the way it's supposed this weekend (AKA Primetime)
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 06-03-2007, 00:30
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
This is a massive understatement. Too many man hours went into that ridiculous flag holder. As much angst as I developed for the darn thing, I must say, it's pretty cool.
Nope, I won't be coaching this year. When you have a coach who's won 4 of the 5 regionals he's coached in (Derek Bessette), you don't make a change. Now, if we could only get Derek to stay awake in the box.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 06-03-2007, 00:41
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
I know Derek is a great coach, but I'm starting to think that this is the real reason 1114 doesn't want Karthik coaching, I mean, his singing is bad enough!
In all seriousness, from what I have seen, this is going to be one real competitive and successful robot. I wish you all the best, and Karthik, I expect updates through out the weekend.
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 06-03-2007, 02:05
Sagar Vyas's Avatar
Sagar Vyas Sagar Vyas is offline
Sagar Vyas
Sagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of light
Send a message via AIM to Sagar Vyas
I've seen this bot (the practice bot), all I can say is best drive train yet. Can't wait to see it in action at GLR, it truly will be 'Primetime'
Team 1503, Spartonics - Alumni
Unread 06-03-2007, 06:38
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Hopefully the "Random" seeding matches will have us together for all the matches...
Looks great!
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 06-03-2007, 09:13
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Looks great!
No such luck Don! Not if my predictions hold up.
But I do see one heck of a rivalry developing between 469 & 453
http://www.grovesrobotics.org/GLRmatchlist.xls
From Team 1114 Karthik Thanks and/or Congrats 13 03-05-2006 22:36
pic: Team 1114 Drive Team Karthik Extra Discussion 7 05-04-2005 17:57
Thanks from Team 1114 Karthik Thanks and/or Congrats 2 14-03-2004 20:40
pic: Team 1114 Gearboxes CD47-Bot Robot Showcase 16 19-02-2004 12:16
pic: Simbot Sally CD47-Bot Robot Showcase 4 04-03-2003 10:35
