Go to Post While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic. - Katie_UPS [more]
Unread 05-03-2007, 22:52
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
<R14> (Team Numbers)
For reference:
<R14> The judges, referees, and announcers must be able to easily identify ROBOTS by Team
Number. Teams must display their Team Number in four locations at approximately 90-
degree intervals around the perimeter of the ROBOT. The numerals must be at least 4
inches high, at least in 3/4- inch stroke width and in a contrasting color from its background.
Team Numbers must be clearly visible from a distance of not less than 100 feet.
So tonight one of our students referenced an answer on the Q&A that I had not noticed:
<R14> must be met at all times. If a robot lifting device is designed such that one or more of
the team numbers are no longer visible when it is deployed, this would not be meet the
requirements of Rule <R14>. If another instance of the number became visible on that same
side of the robot after deployment, this would be in compliance with Rule <R14>.
Is FIRST kidding??? We actually have to have our team numbers ALWAYS visable on 4 sides even if there is an alliance partner robot parked on top of us covering our number??? Does anyone know what the actual penalty is if a referee can't see a team number on all 4 sides because a robot is parked on your lift/ramp that has your team number on it? Has anyone been called on this? This seems a bit ridiculous.
Unread 05-03-2007, 22:55
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: <R14> (Team Numbers)
FIRST is more referring to if a team has a number on a side of a ramp, that when it folds out, then becomes the bottom. I don't think they care when a robot parks on it, as that would just be like a robot driving in front a number in a normal circumstance.
Unread 05-03-2007, 23:04
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
interesting. from what I could tell at PNW, it was never enforced.
Unread 05-03-2007, 23:37
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
It seems that the only time that they enforced this was during inspection... And as long as you passed inspection, they never really checked this again.
Jacob
Unread 06-03-2007, 07:53
Electrical Engineer
Rookie Year: 1995
...Is FIRST kidding??? We actually have to have our team numbers ALWAYS visable on 4 sides even if there is an alliance partner robot parked on top of us covering our number??? Does anyone know what the actual penalty is if a referee can't see a team number on all 4 sides because a robot is parked on your lift/ramp that has your team number on it? Has anyone been called on this? This seems a bit ridiculous.
Chuck,
What is ridiculous? Is it the fact that FIRST enforces a rule that has been posted in the rules and unchanged since Jan 6th or that your team designed a robot that can not meet the rules?
Team numbers serve a number of purposes and it goes beyond allowing spectators and judges to identify your robot. If a robot needs to be disabled during a match, how does the referee tell which robot to disable?
I suppose that a workaround to this "ridiculous" rule would be to disable all alliance robots for a safety infraction by a single partner... Would this be less ridiculous to you?
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 06-03-2007, 08:15
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
At VCU, my team applied the numbers to the bumpers. Somehow they were applied upside down on one side but the ref never called it. I believe that he is saying it is ludacris that the numbers should be able to move around any obstacles in its path. At VCU, several teams deployed ramps, making the #'s not viewable but the judges knew who they were b/c they didnt move after deployment.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 06-03-2007, 11:57
Originally Posted by Mike Betts View Post
What is ridiculous?
Our robot can meet the rule as long as someone isn't parked on our ramps and blocking the team numbers. What I find rediculous is that apparently FIRST thinks that if a robot is blocking your team number and a ref can't see your team number on all sides at all times then it is somehow your fault and a violation of <R14>. This is an impossible rule to meet at all times. How can we design a robot such that the team numbers are ALWAYS visible since your robot probably isn't transparent? This blanket statement by whoever answers the Q&A is a bit extreme. You know as well as I do that in the course of normal play there are plenty of times when another robot is blocking the view of your robot but now this is somehow your fault? I understand if the intent is as Sean first stated. That makes sense and should be no problem for us. It would appear, however, from watching some of the webcasts that there are plenty of examples of robots parked on top of other robots blocking robot numbers which would seem to me a normal course of play but according to this Q&A response would be a violation of <R14>. My question was, is this actually drawing some sort of penalty at the comps and if so what is it? I never saw it called in the little bit of webcast I had a chance to catch and was wondering if this is something we need to worry about.
Unread 06-03-2007, 12:29
Nate Laverdure's Avatar
FRC #2363
Woah, cool down!
I understand your concern-- this has always been a tough requirement to meet. However, I think you misinterpreted this rule. I read it as several others have tried to explain it: this is about numbers that change locations on your own robot, not numbers that are blocked from view by another robot.
Here's how I read the Q&A, line by line:
<R14> must be met at all times. And the refs will penalize you if it isn't. Or maybe not. Refer to the posts above.
If a robot lifting device is designed such that one or more of the team numbers are no longer visible when it is deployed, this would not be meet the requirements of Rule <R14>. If you have your team number on a ramp or lifting device, then it must also be visible when the device is deployed. As Sean said above, this rule does not imply that the team number must also be visible when another robot is blocking one's view. I think you are confusing "deployed" with "in use."
If another instance of the number became visible on that same side of the robot after deployment, this would be in compliance with Rule <R14>. Imagine a cube with the team number written on both the side facing you and the top. Now roll the cube toward you 90*. Notice that "another instance" of the team number has come into view.
Hope this clears things up.
Unread 06-03-2007, 12:48
Thank you all for the responses and for the record I don't see this as a big problem. I was only concerned by the wording including "all times" when "deployed". As far as I know, most if not all of the ramps/lifts this year must be considered "deployed" when "in use". I read the Q&A to imply "Thou shall not put your team numbers on your ramp/lift because the number could be blocked from view at some point by another robot and would thus be a violation of <R14>." Hopefully the refs will apply the common sense rule on this one and everything will be fine. I just didn't want to get to competition and find out that we were disqualified from that 60 point lift because one of our numbers were hidden under a lifted bot. I would rather know now that this could be an issue and we can fix it on Thursday with some more Lexan and numbers. I appologize if any of my wording has come across as too harsh. I didn't mean it that way.
Unread 06-03-2007, 12:56
GaryVoshol's Avatar
Cogito ergo arbitro
The concern is not that the number is hidden by another robot, but by something the robot itself does. For instance, if the number is on the bumper and then the ramp covers the bumper when deployed, the number could not be seen.
If we had to worry about numbers being blocked by anything else, most robots would be illegal at the start of the match, as the number is pushed up against the diamondplate.
(since 2004)
[OCCRA]: Team numbers Squirt_47 OCCRA Q&A 1 28-09-2006 16:43
[OCCRA]: Team Numbers Dstiebel OCCRA 5 06-10-2004 22:00
Order of Team Numbers... marlon_jbt Chit-Chat 39 29-04-2003 09:34
New team numbers archiver 2000 10 24-06-2002 00:32
Team Numbers archiver 2000 2 24-06-2002 00:24
