Go to Post Chief Delphi is special. ... Self-police please. - PayneTrain [more]
Unread 05-03-2007, 23:36
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Mechanical Question about project Urgent!
Say I was testing the efficiency of different turbines. What is the best way to measure the current generated by these blades in varying wind speeds?
Help is greatly appreciated.
Unread 06-03-2007, 22:44
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Mechanical Question about project Urgent!
Yikes! Your simple question is more complicated than it may seem. From your question, it sounds like you are referring to wind driven electric generators aka windmills. So do you already have a windmill that is driving a generator? If so you just get a multimeter, put it in current mode and measure the output of the generator.
If you are talking about design, then there are several factors to consider. But ultimately the amount of current generated is a factor of how fast the windmill turns.
Maybe you should explain the problem in a little more detail....
Unread 06-03-2007, 22:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
A little bit more info about the project is available here
http://www.chiefdelphi.com/forums/sh...ad.php?t=55287
although there still is no way we can answer the question without a LOT more information....
Unread 06-03-2007, 22:48
Andrew Blair's Avatar
FRC #0306 (CRT)
An important question is, do you have a little turbine, or a big turbine?
My initial suggestion is to use an inductance coil meter. It's one of those claw looking things you put around wires, and it uses an inductance loop to measure various things. Typically a little more capable than a multi-meter, and you won't hurt it by over-current.
But, if it's small, a multi is fine.
-Sir Francis Bacon
-Albert Einstein
Unread 06-03-2007, 23:43
Im sorry;
I am basically attaching a stack of little turbines (3 in diameter) on the top of the hood of a car. This is where an air scoop usually goes. This assembly can mount on say a Honda Civic. I want to see how much electricity I will generate with this setup at different wind speeds (20, 30, 40, 50, 60) mph. This is useful as a 100 buck aftermarket kit. I know its not as effective as running a generator to the wheels, but this can be sold for cheaper and installation will be easy.
Once again,
Thanks for the responses, and sorry for the lack of detail.
Unread 07-03-2007, 07:38
Brenn,
A few things came to mind when I saw your post. The output of any of these fan/generators will be pretty low as far as current is concerned but in order for you to use it effectively, you need to follow up the output with some form of voltage regulator. As the speed of the car increases so will the output voltage and current but the RPM of the fans is also determined by the electrical load. The greater the current demand the more electrical "drag" there will be. You might also want to control the amount of air flow as there will be a point where the fans may self destruct due to excessive speed. This can be a way to get charge current back to the battery but you will need some form of isolation to prevent the battery and alternator from back feeding the fans. The voltage regulator, if properly designed can handle this function.
Experimentation is key here. I would start by making a box with some lamps that you can switch in and out. Connect that to one fan and hold it out the window while someone else drives the car at specified speeds. Measure the current generated while you switch in additional lamps as a an increasing load and I think the data will be very revealing.
BTW, there are DC fans and there are brushless DC fans. The brushless fans will not act as generators.
Good Luck
Unread 07-03-2007, 15:56
AKA: Dan
Brenn,
Good Luck
It sounds as if Brenn is not even concerned with attaching any sort of load. So, Brenn, correct me if I am interpreting correctly. You already have the 3 wind turbine/generator assemblies. Your task is to determine the amount of current is possible at several different wind speeds, as simulated on a car. Measuring current implies a complete circuit such as you might see in a charging circuit as described by Al. If all you have are these wind driven generators, then you can only really measure voltage (again with a multimeter). You would expect that as you drive faster, the voltage will go up. Connect the outputs of your 3 generators in parallel (not series although this would be interesting), lead the + and - ends back to the passenger compartment and attach to the multimeter to get a reading as you drive. Al alluded to it, but do you know what sort of generator you are using? AC or DC?
Unread 07-03-2007, 20:42
So I get brush DC fans and measure the voltage between the two leads? Would that work?
I want to generate DC current.
Thanks for all the input.
Unread 07-03-2007, 22:52
DonRotolo's Avatar
Back to humble
FRC #0832
Voltage is only part of what you need to measure. You must also measure current, to calculate POWER. There must be a small load on the generator - maybe a light bulb, maybe just a resistor - and by measuring voltage (V) and current (I), P=V*I (P is in Watts)
(Rememebr that Watts is power, and if your system can generate xx watts, the resistor must be able to handle xx watts or more, or it'll overheat)
Don
PS: you DO realize of course that the amount of fuel being spent to overcome the drag of the wind turbines is far greater than the energy produced by the turbines, right? That's called "efficiency", always less than 100%.
Unread 08-03-2007, 00:28
Yeah I know that, but wouldnt this be useful in a city environment?
And does the DC brush fan include a generator. Is it itself a generator?
Unread 08-03-2007, 01:01
MrForbes's Avatar
AKA: Jim
I can't see how it could be any use at all for saving fuel...but it could help teach you about different forms of energy, so it's a very useful project in that regard.
Unread 08-03-2007, 02:24
When youre braking wouldnt the fans help conserve some energy. So in a city environment where one is constantly braking...
Urgent help with a project; brennerator Technical Discussion 3 05-03-2007 13:40
Urgent CMUCAM question silliewillie Programming 2 21-02-2005 15:09
Urgent!! (programming question) anupalsingh Programming 6 25-02-2004 10:53
How Do You Best Learn About Mechanical Stuff? sanddrag General Forum 51 02-09-2003 01:18
Urgent motor question Brett W Motors 2 13-02-2003 15:14
