Go to Post Frisbees [as next year's game piece]. That is all. - Frenchie461 [more]
Unread 06-03-2007, 12:29
Jimmy Holmes Jimmy Holmes is offline
It's not all about the robots
FRC #0027 (Team Rush)
Jimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of light
Re: pic: Cornelius VIII - FRC469
hmmmm, looks very interesting
http://www.chiefdelphi.com/media/photos/27145
Unread 06-03-2007, 13:07
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
Long Ramp JImmy, does it fit in a 5 foot or the 4 foot class, and whats the area of the complete ramp?
Unread 06-03-2007, 15:23
dtk's Avatar
dtk dtk is offline
AKA: Daniel Kimura
None #0469 (Las Guerrillas)
dtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud ofdtk has much to be proud of
All the cool kids are doing it! Can't wait to see it in person at Detroit.
Originally Posted by Lil' Lavery View Post
While the metal grating is ideal for traction-wheeled teams, will your ramp provide any provisions for improving the chances of omni-wheeled teams at getting up?
I can't tell from the picture, but the section of the ramp that deploys from the rear one piece, or does it have a gap in the middle?
Is the device sticking out of the ramp at the rear just to ensure that your ramp doesn't become a "traction device", or does it raise the whole ramp to 12"?
Can you load tubes off the ground, or just the wall?
Is there a camera that I'm missing, is it coming later, or are you guys not using it?
What motors are used where, and are you using DeWalt transmissions again?
And of course, the perennial 469 question, HOW DID THAT MAKE WEIGHT!?!
Sorry for the tons of questions, but 469 is really one of the more inspiring bots every year, and I'm dying to learn more about Cornelius. Good luck, I'm sure you will be a force to be reckoned with at GLR.
Hope you can pull off the ramp-ringer combo, nobody really has yet.
The rear ramp deploys as a whole piece. The cutout that you can see in the picture is just there in order to give the arm a spot to fold into. We have also had several discussions about traction material for the ramp but it is a low priority for us at this point.
The devices on the ramp are in fact for lifting it to twelve or so inches. They are, however, not complete as pictured.
The gripper itself, as I think Don mentioned, can grab tubes from the floor, the wall, and, theoretically at least, from the HP over the driver station wall. The mast rotates to make this possible.
The camera should be along shortly. We actually didn't have any time to work on it due to more... pressing, programming issues. Our plan is to still use it at least for auto.
We are again using 4 dewalt transmissions on the drive and plan to servo shift them again this year.
Weight wise, we used as thin and light material as possible everywhere. There are almost no pieces on the robot thicker than 1/16th of an inch. Even parts that needed thicker walls to support holes, like on the gripper, are only 1/8th thick around the hole and milled down to 1/16th everywhere else. The round tube, of course, is even thinner. It really was a situation where we thought about weight in everything we did.
-dtk
btw, if any of this turns out to be a "secret" don't tell them it was me who told you .
Unread 06-03-2007, 16:55
BRosser314's Avatar
Post-A-Holic
AKA: Brandon Rosser
Smile Re: pic: Cornelius VIII - FRC469
keep it secret
pic: Blizzard VIII Steve W Robot Showcase 28 25-02-2007 00:50
pic: 610 Coyobot VIII - Chassis View Jonathan Norris Robot Showcase 1 10-02-2007 17:18
pic: Cyber Blue 234 - Falcon VIII David Kelly Robot Showcase 11 24-02-2006 11:13
pic: Cyber Blue 234 - Falcon VIII David Kelly Robot Showcase 2 23-02-2006 23:37
Pic for team 469, Cornelius archiver 2000 0 23-06-2002 21:59
