#16
Re: pic: Cornelius VIII - FRC469
Can't wait to see you guys this weekend. Maybe we'll have the pleasure of playing with you! |
#17
looks really heavy
#18
as always, we carried out an ambitious design and, strong from our previous experiences, we knew weight would be a problem from day one. Early estimates of our robot during the design phase went over 170 lbs. From there, weight was at the center of everything we did. We currently weight around 115 lbs but went as far as using different aluminum alloys on certain part of the robot to reach this figure.
Francois. |
#19
Yes, we can pick up from the floor and from the back wall... The ringers are held mostly horizontal...
Yes...it would be nice to play with the Killer Bees... I don't think we have since I've been on 469... Looking forward to this weekend as well!! |
#20
There should be a camera and a working autonomous.
Indeed, weight was a great concern. Everything on the robot was made as light as possible, such as the gripper, which weighs less than 2 pounds, and the elevator motor mount, which was made of stamped 1/16th aluminum. If we were to somehow be overweight, there's pretty much no more places to drill holes without making our robot a crumple zone. To be fair, I credit some of the ideas to other great teams who have been able to shove a ridiculous amount of features on a 120lb robot. I had 33's short-lived stamped-steel swerve drive modules from 2005 in mind when I worked on the motor mount. Wait until you see it move. It'll make the weight seem even more impressive. |
#21
![]() ![]() Don, The similarities are eerie. Knowing that we're on the same page as 469 makes me feel really good about things. |
#22
Karthik... I feel the same way... See you in two days...
#23
#24
The devices on the ramp are in fact for lifting it to twelve or so inches. They are, however, not complete as pictured. The gripper itself, as I think Don mentioned, can grab tubes from the floor, the wall, and, theoretically at least, from the HP over the driver station wall. The mast rotates to make this possible. The camera should be along shortly. We actually didn't have any time to work on it due to more... pressing, programming issues. Our plan is to still use it at least for auto. We are again using 4 dewalt transmissions on the drive and plan to servo shift them again this year. Weight wise, we used as thin and light material as possible everywhere. There are almost no pieces on the robot thicker than 1/16th of an inch. Even parts that needed thicker walls to support holes, like on the gripper, are only 1/8th thick around the hole and milled down to 1/16th everywhere else. The round tube, of course, is even thinner. It really was a situation where we thought about weight in everything we did. -dtk btw, if any of this turns out to be a "secret" don't tell them it was me who told you . |
#26
keep it secret
| pic: Blizzard VIII | Steve W | Robot Showcase | 28 | 02-25-2007 12:50 AM |
| pic: 610 Coyobot VIII - Chassis View | Jonathan Norris | Robot Showcase | 1 | 02-10-2007 05:18 PM |
| pic: Cyber Blue 234 - Falcon VIII | David Kelly | Robot Showcase | 11 | 02-24-2006 11:13 AM |
| pic: Cyber Blue 234 - Falcon VIII | David Kelly | Robot Showcase | 2 | 02-23-2006 11:37 PM |
| Pic for team 469, Cornelius | archiver | 2000 | 0 | 06-23-2002 09:59 PM |
