Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Unread 07-03-2007, 16:44
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
03/07/2007 USFirst Site down
Anyone else having problems with the FIRST site? I'm just getting this:
Could not load file or assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
ASP.includes_navigation_ascx.__BuildControlTree(in cludes_navigation_ascx __ctrl) +0
ASP.includes_navigation_ascx.FrameworkInitialize() +19
System.Web.UI.UserControl.InitializeAsUserControlI nternal() +31
System.Web.UI.UserControl.InitializeAsUserControl( Page page) +14
ASP.homepage_master.__BuildControlNav2() +49
ASP.homepage_master.__BuildControlform1() +81
ASP.homepage_master.__BuildControlTree(homepage_ma ster __ctrl) +114
ASP.homepage_master.FrameworkInitialize() +34
System.Web.UI.MasterPage.CreateMaster(TemplateCont rol owner, HttpContext context, VirtualPath masterPageFile, IDictionary contentTemplateCollection) +1980912
System.Web.UI.Page.get_Master() +48
System.Web.UI.Page.ApplyMasterPage() +18
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +543
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
Autodesk Streamline site down? Jeremiah Johnson 3D Animation and Competition 0 16-01-2005 18:51
First site down? phillutz Technical Discussion 4 15-01-2005 12:11
New Look at the usfirst site archiver 2001 8 24-06-2002 02:37
FIRST WEB site down archiver 2000 7 23-06-2002 23:45
FIRST site down - help Ben Mitchell Chit-Chat 5 28-04-2002 18:19
