Go to Post Please excuse his spelling/grammar, he's an engineering student. - MrForbes [more]
Unread 07-03-2007, 19:49
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: How to type my code
All I did was install EasyC that came with the Vex Programming Kit, and then linked MPLAB to the EasyC compiler. Just read the two following threads in order and you should be fine. You don't have to buy anything either...
http://www.vexfan.com/viewtopic.php?t=4
http://www.vexfan.com/viewtopic.php?t=31
I hope that helps,
Nathan
How do you manage code changes? ericand Programming 22 01-03-2006 03:56
Can I "type" code in EasyC? scottmso Programming 1 04-02-2006 07:22
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
Field Location of Type-0 and Type-1 IR Signals Travis Hoffman General Forum 3 27-02-2004 07:58
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
