Go to Post No Firsting way! - Tytus Gerrish [more]
Unread 20-02-2007, 18:40
AdamHeard's Avatar
Lead Mentor
can't edit drawing dimensions
Hi,
I'm making some parts for work in inventor 11.
I'm in the drawings (.idw) now and it won't let me edit the dimensions (right click -> edit). I need these to put in some crucial information (0.25 now, it needs to be ".25 typical, 6 places" for example.) I just made some drawings last week for robotics and was able to do this. It's almost as if some hidden master switch was hit.
any thoughts?
Unread 20-02-2007, 23:04
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Re: can't edit drawing dimensions
Take a look at this thread, a recent update to Windows may have broken Inventor. http://www.chiefdelphi.com/forums/sh...ad.php?t=54332
Team 1816 - The Green Machine
Unread 21-02-2007, 19:49
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Could you be more specific? When you right click on the dimension and try to edit it through the precision menu is it not letting you or what exactly is it doing?
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 22-02-2007, 00:02
AdamHeard's Avatar
Lead Mentor
It will not let me edit/add text to a dimension.
It will let me change precision however.
It seems to be the problem linked above but I only work two days a week so I have been unable to test it.
Unread 27-02-2007, 10:59
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
When you do drawings in Inventor they are based on the part files of the drawings that you are doing. If you change the dimentions on the part level they should change on the drawing level. If you are still having trouble let me know.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 27-02-2007, 15:59
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
http://usa.autodesk.com/adsk/servlet...linkID=4183228
Early reports are that KB920342 causes problems as well - but I turned off automatic updates a long time ago so I'm not sure on this one yet.
Unread 01-03-2007, 08:15
JD Mather's Avatar
A Hotfix has now been posted.
http://usa.autodesk.com/adsk/servlet...linkID=4183232
Unread 04-03-2007, 13:49
AdamHeard's Avatar
Lead Mentor
Originally Posted by JD Mather View Post
The hotfix won't install. It says something along the lines of not being able to find the program.
I can't uninstall windows hotfix either. This is Northrop Grumman's computer and they don't let you mess with security.
Unread 04-03-2007, 19:04
JD Mather's Avatar
Pass the Hotfix link on to their IT department.
Unread 08-03-2007, 10:31
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i'm having the same problem, but on my personal computer (i.e., i have no IT department to run to). any advice would be helpful. this inability to create notes is killing me.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 29-09-2007, 00:36
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
Smile Re: can't edit drawing dimensions
well its good to know that there is a fix for this. I was doing some work in Inventor and was trying to put in text and it was not working and I was like what is going on... I asked my dad and he celled a friend who teachers it in a school and he did not know what was up with it so I was like I will go look on chief delphi and saw this thread and was like YES!!! thanks, you guys help out a lot!!!
Unread 02-10-2007, 10:57
JD Mather's Avatar
Make sure all Service Packs are installed as well.
You can find Hotfixes and Service Packs by searching Google on Autodesk Inventor Hotfix and Service Pack. Install in the order in which they are listed on the Autodesk website. Be sure to follow all readme instructions for installation (particularly for the SP1 for Inventor 2008 as you need to un-install a part of the program first.)
Unread 22-10-2007, 15:14
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
If you are trying to add notes at the end, then just add a text box and line it up visually. It will not be exact, but most machinest don't care. They just want the note there. Sometimes, Inventor just likes to be a pain. (Happened to me at a SkillsUSA state competition). The pain just comes with the program.
Dimensions and drawing of the rack robotboy11 General Forum 0 12-01-2007 10:35
default camera code edit Windward Programming 8 25-01-2006 18:33
Edit whitepaper rbayer CD Forum Support 5 03-10-2002 18:11
Edit Error Jack CD Forum Support 1 29-08-2002 22:02
