Go to Post Does this mean the end of "Spin Around/Dance" autonomous modes? - Tom Bottiglieri [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 09-01-2007, 11:46
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Car Nack Predicts 01/08/07
Car Nack can predict, but that doesn't mean we won't try. However by making such a statement, the strategic value of the Keepers are much greater than the points they earn.
Unread 09-01-2007, 12:15
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by Cory View Post
Why? It's much harder to score them there than at the top.
How so?
With the lower racks you can pre-align the robot up positioned with the keeper to run into a bottom rack scorring spider leg and you will be golden.
The only thing you have to worry about is the "slight adjustment" after you set up your robot, but I don't think that will make much of a difference.
What is your reasoning Cory? I'm guessing less leg shake up above, and the target to help you? Maybe, but it also constitutes actuating an arm or something to reach that high as well.
I know from past experience it takes quite a while to drop a tetra on a goal in autonomous mode. The only advantage this year is you start with the game piece in your possession.
Unread 27-01-2007, 17:10
1768's Avatar
1768 1768 is offline
FRC #1768
1768 is an unknown quantity at this point
I strongly disagree with Billfred. I predict that in _very_ few matches will less than one keeper per team be scored. The spiders are nigh impossible to shake without a running start, and barring collisions any team with halfway competent programmers (a group among which I count myself) should be able to score underneath a light.
In short, IMHO Car Nack is dead wrong. But I've been wrong many times before.
Unread 30-01-2007, 23:00
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Elgin Clock View Post
How so?
The leg shake is very dramatic at the bottom, and any dead reckoning autonomous is surely to be interfered with if it's not the first bot there and it's aiming for the bottom.
In terms of coding difficulty, if the team is using closed loop control (or has done enough testing to know how long to run the motors to get their manipulator to the right height), it should be no more difficult to score on the higher spiders during autonomous (in fact easier due to the lesser shaking) than down low.
As for Car-Nack. It really depends on how good 383 and the rest of the Brazilian teams are this year, because that's the only regional I could see less than 5 keepers scored. Not knocking the Brazilians in any way, it's just a much smaller and younger event (even than Israel).
Unread 09-02-2007, 14:09
Oh great and knowledgeable Car Nack, you have spoken and your words are true.
Finding a hole in a wall (a fixed plane) set under one light is not the same as multiple lights above multiple moving objects on a moving assembly for potentially only 2 points. If there is any successes, it will be late in the season.
Unread 21-02-2007, 21:14
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I believe Car Nacks vision is getting blurry -
I think many teams will score in auto, using the camera.
Regarding the low vs. high - there is a distinct advantage to scoring on the lower level - but i wont divuldge my strategy
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 21-02-2007, 21:21
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
I'm not sure how many will get lucky.
I do know that we won't. 1213 doesn't do high-risk for low-pay.
Unread 21-02-2007, 21:22
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Originally Posted by Car Nack View Post
Car Nack Predicts
The scoring of keepers will be a relative rarity. In fact there will be at least one Regional where there will be a total of less than five keepers scored for the entire competition.
Car Nack has spoken
It won't be in Florida
www.179swampthing.org
Unread 06-03-2007, 15:49
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Car Nack Predicts
Car Nack has spoken
Well, was Car Nack right yet? It certainly appeared that the prediction was very close to true (not many keepers were scored anywhere), but did any of the 1st week regionals have less than 5 keepers scored?
Unread 06-03-2007, 15:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Swampdude View Post
That took you 16 seconds
2001-2004: Team 100
2006-Present: Team 254
Unread 08-03-2007, 16:22
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
In New Jersey, 237 scored four keepers. 25 scored two or three I believe. 375 also scored two?
Certainly not as much as I thought would be scored.
http://www.mikesorrenti.com/
Unread 10-03-2007, 23:43
Generator of Entropy
FRC #2973 (The Mad Rockers)
Seemed to be quite a few blind squirrels finding nuts in Florida. I lost count.
Unread 11-03-2007, 00:29
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Only one keeper was scored at the Southern California regional (by 330). Many close calls, but only one found its mark.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 11-03-2007, 00:59
Car Nack was correct in his prediction. (By the way, no camera on our robot--and we came the closest to having more than one (or zero)).
Unread 11-03-2007, 03:52
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
In Flordia the refs barly moved the rack. If that happened in nj we would have hit it every time.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Car Nack Predicts 6/06 Car Nack Car Nack's Corner 13 21-04-2008 03:11
Car Nack Predicts 1/06 Car Nack Car Nack's Corner 13 05-04-2006 08:02
Car Nack Predicts 05/06 Car Nack Car Nack's Corner 6 03-03-2006 07:45
Car Nack Predicts 3/06 Car Nack Car Nack's Corner 39 28-02-2006 22:19
Car Nack Predicts archiver 2000 2 23-06-2002 21:59
