Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 08-03-2007, 14:13
blakwyte's Avatar
blakwyte blakwyte is offline
FRC #1731 (NASA Fresta Valley)
blakwyte is an unknown quantity at this point
Re: Outside the box defense
*bump*
this is basically a list of the strategies that we were considering using in the semi-finals ... so weird!!
basically what we decided was:
knocking the ringers on the opposite side down to obstruct the opposing teams ramps i probably legal ... we'd seen other teams do it before without being called and the rules say "Inadvertent bulldozing of GAME PIECES while the ROBOT moves around the field is allowed." ... this strategy is essentially bulldozing since your object isn't to get ringers in a specific area but just to make a mess
placing a ringer on another bots ramp is technically illegal, but there are no penalties for it, since they assumed the only reason you would do this would be to cause an opposing robot to be in possession of multiple ringers "GAME PIECES may not be intentionally placed on opposing ROBOTS for the purpose of causing a violation of [rule <G09>]. Any such GAME PIECE placements will not be considered in POSSESSION of the affected ROBOT, and will be ignored."
deploying ramps on the field to block an avenue probably isn't a great idea. however, we had a unique situation where we had 2 bots with ramps, but could only fit one bot up either of them. we considered deploying ramps in front of the other alliances' ramp bot (which we had fondly nicknamed "the parking-lot bot" because of it's massive ramps) in order to prevent them from scoring with ramps. the other coaches convinced me that we would be penalized per-second for deploying on the field but i'm very sure that this isn't the case. suffering a 10 point penalty to prevent a 60 point bonus is probably the best possible defensive move to make. i want some feedback on this as it seems a little unsportsmanlike to use this strategy, although it would definitely be effective and (probably) legal.
we used the "bang the rack" strategy alot and it is extremely effective
Team 1731 - FVR
2006 NASA/VCU Regional Semi-finalist
2006 NASA/VCU Judge's Award
2006 NASA/VCU Highest Rookie Seed
2007 NASA/VCU Rockwell Automation Innovation in Control Award
2007 NASA/VCU Regional Semi-finalist
Some Video of 1731 in Action
Unread 08-03-2007, 15:03
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
Originally Posted by blakwyte View Post
*bump*
see rule G35
10 points for every 5 seconds in opponents home zone. so a max of 30...most ramp bots will head back and deploy 10-20 before the START of end play soo the last ~30 seconds of the match
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 08-03-2007, 15:43
Render Render is offline
AKA: Robert Udicious
FRC #1885 (Robocats)
Render will become famous soon enoughRender will become famous soon enough
Originally Posted by akshar View Post
see rule G35
I think they are talking about deploying the ramps outside of the opponents homezone, meaning they get the 10 point penalty for being larger than 72x72 outside of the homezone. I believe this penalty is not cumulative but i could be wrong.
2007 - NASA/VCU Quarter finalists
2006 - Championship Event Rookie All Star winners
2006 - Palmetto Rookie All Star Award winners
2006 - NASA/VCU Rookie All Star Award winners
Attending:Las Vegas Regional, Championship Event
Unread 08-03-2007, 18:09
blakwyte's Avatar
yep i'm talking about outside the home zone, which is a one-time 10 pointer ... inside the home zone it's obviously a cumulative penalty. but if you look at some of the ramps that are out there, particularly the really large ones that take up most of the lateral room in the home zone and are "front end loaders", it would be ultra-easy to block from outside.
also, i'm unaware of whether you can be penalized the full 30 for being pushed into your opponents home zone. i don't believe you can but i'd like something definite.
Team 1731 - FVR
Unread 08-03-2007, 18:33
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
while some of these strategys are "unconventional" i have a feeling we'll be seeing them before the end of the season...
ex: your ramps [that cannot be retracted once down] fall accidentaly on the opposing side of the rack, youre essentialy stuck there so why not make the best of it.
296's robot has no ramps [we do but theyre not installed] so this wouldnt apply to us but im sure it will or has happened to someone, somewhere.
anyone observed this?
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 08-03-2007, 22:52
themagichat themagichat is offline
AKA: Norris
FRC #1302 (POJO(number 42))
themagichat will become famous soon enough
Originally Posted by geeknerd99
and we could lower and raise our ramp to slap the spider arm, making it harder to score.
Cool concept, but couldn't that also effect the placing of your alliance partners ringers. I guess it all depends on where you are shaking and how much it transfers through the rack. Personally I believe that strong offense is the best defense. Why just lower their ability to score by playing defense when you can take away thier opportunity to score by scoring on their side. It may seem out there, but if you have 3 good hangers on the field it really works great. Team 25 and 103 did an awesome job of it at the NJ regional.
Unread 08-03-2007, 22:54
The only thing is they may give you a Yellow Card for deliberately breaking the rules
edit: That is exactly why we made our ramps massive wings since it is much more difficult to block both sides. This way they are required to enter the homezone to block penalizing their team. Another point is that a team with one ramp and a large platform can be blocked for 30 penalty pts, but block 60 bonus points. With 2 ramps such as our design TWO robots must each block one side netting a minimum of 20 pts and a maximum of 60 in penalties against the other team.
Unread 08-03-2007, 23:28
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
RENDER, Looks like you did very well at VCU. Congrats. Did you get any oppotunities to use your ramps and if so what kind of defense if any did you see? The kids on the team I mentor totally agree with your front loading problem of being easy to block, and to be able to do so without getting penalty points. Having two side loaders requires two robots to block ramping.
We ended up taking side loaders one step further. Please take a look at this rendering:
http://www.chiefdelphi.com/media/photos/27536
What do you think? How would you defend the ramps?
Unread 08-03-2007, 23:50
Dave McLaughlin's Avatar
Happy Birthday! Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Y waste 60 points deplying a ramp where you cant get on it?
Unread 09-03-2007, 00:46
lenergyrlah's Avatar
lenergyrlah lenergyrlah is offline
FRC #1731 (Fresta Valley Robotics)
lenergyrlah is an unknown quantity at this point
no it's not -- just if you "give" your opponent a ringer it doesn't count as possession.
& if your opponent pushes you into their home zone you don't get a penalty (as long as you try to escape).
2007 Rockwell Automation Innovation in Control Award
2006 Highest Rookie Seed Award
2006 Judges Award
Unread 09-03-2007, 01:34
Rick-906's Avatar
AKA: Richard
any thoughts on trying to turn the rack around mid-game making it easier to score on the far side [which would then become the near side]?
Unread 09-03-2007, 20:36
blakwyte's Avatar
that rack is soo hard to move ... i'd never even thought of this strategy but i suppose it would be possible. i'd tend to think the chunk of time that it would take to actually make that metal monstrosity do a 180 would be too hefty to give you any benefit ...
141: i was actually looking at your ramps earlier with a mixture of awe and wonder ... i can't think of any way to defend against those ...
Team 1731 - FVR
Unread 11-03-2007, 01:31
EricH EricH is online now
Nope.
<G24> Clearing HOME ZONE – the first audio signal, sounded five seconds before the start of the END GAME, serves as a warning for ROBOTS to exit from the opposing HOME ZONE. ROBOTS attempting to exit from the HOME ZONE after the audio signal may not be blocked or impeded in this attempt.
<G25> END GAME play – ROBOTS may not occupy the opponents HOME ZONE during the END GAME. Any ROBOT in an opponent’s HOME ZONE at the start of the END GAME will be assessed a 10-point penalty. A second 10-point penalty will be assessed if the ROBOT is still in the HOME ZONE 5 seconds after the start of the END GAME. Another 10-point penalty will be assessed if the ROBOT remains in the HOME ZONE 10 seconds after the start of the END GAME. However, a ROBOT that has been blocked or otherwise prevented from exiting the HOME ZONE (as described in Rule <G24>) will not be assessed any penalty.
And a team that could have been given 30 points in penalties was dragged in, disabled. (Disabled teams don't count.)
Unread 11-03-2007, 01:56
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The rack can only move a maximum of three feet laterally or rotationally.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-03-2007, 01:58
Rotationally, it's capable of a full 360 degrees. (or however much the power drop allows.) The chains to the anchor are on a collar that can rotate "freely" if it has to.
Arms outside of the 72 Inch Window SgtMillhouse648 Rules/Strategy 3 04-03-2007 16:46
Dodgeball outside the dome? Spindash54 Championship Event 7 25-04-2006 18:28
Attention Teams from outside the US going to Atlanta! Elgin Clock Championship Event 5 25-04-2006 10:47
Robot parts outside of the field. MBF Rules/Strategy 6 10-02-2003 16:48
has anyone ordered the wheelchair wheels outside of skyway? archiver 2001 0 23-06-2002 23:17
