Go to Post You know you have bad field problems if both Dean and Woodie come out to try to fix them... :) - tim_reiher [more]
  #31   Spotlight this post!
Unread 06-03-2007, 11:35
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Team 254 2007 robot
Originally Posted by Budda648 View Post
That's the sweetest blue I have ever seen. Please don't let it be any darker than what it is pictured.
Are you guys worried about the big black wire dangling off the side? It could be an entanglement issue, unless you've already fixed that problem.
It's a piece of IGUS cable chain, to carry the pneumatic tubing and wires running up to the grabber. It never leaves the footprint of the robot, but it does flop around a bit. 968 has been practicing with theirs run inside the elevator, which has worked well, so we'll probably do the same for the comp bot.
Originally Posted by rachal View Post
Wow, gorgeous design, and very nice wheels I can't wait to see this at LA.
How is the elevator mechanism actuated?
Two big CIM's are driving a 2" spool that pulls a cable attached to the grabber
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 07-03-2007, 00:25
teenmisfit's Avatar
teenmisfit teenmisfit is offline
AKA: John Willis
FRC #0501 (PowerKnights)
Team Role: Driver
teenmisfit has a spectacular aura aboutteenmisfit has a spectacular aura about
Originally Posted by Lil' Lavery View Post
Do you actually plan on touching that 16 fps high gear? 116 only used our 10.5 fps high gear once all of VCU, there wasn't much need for it.
we used our 14fps high gear for most of the time then switched to low gear for pushing or climbing ramps. Im sure they will make great use of it ... PS u have a beautiful bot and i met 968 last year and they looked amazing. Look forward to hopefully seeing you in atlanta
  #33   Spotlight this post!
Unread 09-03-2007, 03:02
alphaone's Avatar
alphaone alphaone is offline
Pilot
AKA: Chris Purcell
FRC #0254 (Cheesy Poofs)
alphaone is a splendid one to beholdalphaone is a splendid one to beholdalphaone is a splendid one to beholdalphaone is a splendid one to beholdalphaone is a splendid one to beholdalphaone is a splendid one to behold
Send a message via AIM to alphaone
Whoa cool.. Looking forward to seeing it in action.
Caution wake turbulence departing beechcraft 1900. wait... what?
Currently Attending Embry-Riddle Aeronautical University -Private Pilot ASEL/AMEL
pic: Team 254 2007 robot Cory Extra Discussion 17 21-01-2007 23:44
pic: Team 254 2006 Robot 1 Cory Robot Showcase 29 08-03-2006 16:04
pic: Team 254 robot....almost there! CD47-Bot Robot Showcase 7 18-02-2004 16:17
pic: Team 254 Robot Cart (1 of 3) CD47-Bot Extra Discussion 3 28-02-2003 16:51
Team 254 Robot Pics archiver 2001 6 24-06-2002 01:05
