Go to Post Not only would it be cool but the mental image of Dave's suffering when he writes a message in unintelligible characters makes me grin uncontrollably. - Andrew Schreiber [more]
Unread 01-03-2007, 22:50
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
Wireless programming
Ok, I know you can send code wirelessly if you have a coprocessor with wifi. I am talking about using the kit radios to send code to the robot. Have one plugged into a laptop and the other in the programming port.
Unread 01-03-2007, 22:51
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Wireless programming
DON'T DO THAT!!!
The radios are RS-422, and your laptop and the program port are RS-232. You could fry something...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 02-03-2007, 07:47
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
They only way we have found to wirelessly communicate with the program port on the robot is to use a bluetooth setup. However, the one we have isn't fast enough to program, so we just use it for feedback while we are testing.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 02-03-2007, 15:03
emmell's Avatar
emmell emmell is offline
Murphy was an Optimist!
AKA: Mannie Lowe
no team (They're all my teams)
emmell is just really niceemmell is just really niceemmell is just really niceemmell is just really niceemmell is just really nice
I ditto Kyle's comments. A Serial bluetooth dongle (check out www.blueconsole.com) is a great way to debug without tethers. Remember, however, you can't use them at the venues or in competition and it won't work for programming the bot. You still need to be tethered for that.
Mannie Lowe
FIRST Program Manager - Center for Mathematics and Science Education - University of Mississippi
Mississippi FIRST Tech Challenge Affiliate Partner
Unread 07-03-2007, 09:47
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
You can buy RS232/RS485 converters to adapt the kit radio DB9 interfaces, but you would need two (one for each radio) and I doubt you can buy one for under $50. They would not likely be useful for other applications that you have either.
Go with the Bluetooth setup.
If you are looking for an electronics project, consider basing it on the MAX3130 RS232/IrDA chip http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1947
Unread 07-03-2007, 09:58
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
In addition to the RS232/RS422 problem, there's also the fact that the radios run at 19200bps (versus the 115200 required for programming). Even if you could change the programming baud rate (which actually you should be able to do with some of the unofficial programmers), it would take forever to download code to the robot at that speed.
Unread 07-03-2007, 10:04
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I have a wireless programming setup that works, runs about 75% speed of normal wired programming. Just turn off the verification option on the IFI loader, works great. Granted you cant use it for robot control, but you can program with it.
Here's my post about something else but it includes links to MaxStream's website... who makes i might add the awesomest FCC legal radios you can buy....
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 07-03-2007, 10:19
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
-q
Ditto on the MaxStream stuff. I've been using their tiny little XBee ZigBee/802.15.4 to do wireless TTL via an FTDI serial USB to TTL chip. (Not for FIRST stuff, but it could work.) Amazing little things...I picked a signal five floors above the transmitter. More devolopment required than the XTend radios, though - you would need to make your own circuit board for them. But for $19/$32 depending on the trasmit power, they are cheap enough to play with.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 07-03-2007, 19:22
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Were are curently working on a wireless programmer for the RC. The user will be able to send and recieve data, set the robot into program state, and reset the RC all from the loader terminal. No release date yet. It should be available before nationals. It will use a blue tooth interface and operate at the same speed as the wired com. The product will be called Chicken Wire.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 09-03-2007, 21:39
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Mike,
Put me down on your pre-order lists for both your Chicken Wire and Chicken Aid. 1503 and 1680 will both also volunteer to do any testing you'd like to do in the field.
Bruce
FYI to all,
We're both (1503 & 1680) using a pair of Chicklets ( 1 for the Logitec 3D joystick and one for the Logitec Wired Gamepad) with great results. (The only problems to date have been self induced ... DOH!)
Wireless programming and debugging link heydowns Programming 2 23-01-2006 21:39
2 Wireless routers MattK Chit-Chat 7 02-06-2004 20:46
Wireless Glasses Nick Seidl Chit-Chat 9 01-08-2003 23:32
wireless camera Stephen P General Forum 1 11-01-2003 13:58
Wireless Camera? XRaVeNX General Forum 4 08-02-2002 19:54
