Go to Post Chiefdelphi is a great resource for all of FIRST to use over the years and has grown into a community that has taken a life of it's own. - Koko Ed [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 10-03-2007, 22:01
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
Re: Week 2 Regionals: Veterans Still Have No Advantage
Originally Posted by meatmanek View Post
I don't think this game is 'dumbed down', as you say, and especially not because we're only allowed to handle one tube. This year's game provides quite a few different choices in effective arm and grabber design. You can use an articulated arm, a 4-bar linkage, a sliding elevator, a telescoping arm, and anything else your team can come up with. Grabber designs include pinch-type grabbers, curved pincers, two spatulas, wheel type, and grabbers that deal with the inside of the tube. Optimization and automation can be done with sensors and programming. In terms of ramps, I have seen many clever designs, including lifter types where the lifting robot does the work, cable driven ramp extensions, ramps where a robot driving up will extend the ramp, and so many others.
The focus this year is on tube handling and lifter design, rather than storing game pieces.
I agree ,You have given great example of how to do the task.(lift a tube),what I am trying to say is that
why limit someone creativity. How cool would it be if a team score a entire row in autonomous or the rules allowed for more than placing a tube, drop a ramp or climb a ramp. Just a quick example. I think it was 2002 the game had 3 large goals on casters .These goal were multipliers .Team 71 designed a robot that dropped down ,grabbed the three goals in seconds then walked them into the scoring position.
That was truly INSPIRING .First is about inspiration. If a team uses a 4link or sliding elevator is that inspiring?
Your Friend
Jim
Team 107 Holland Christian / Metal Flow
2005 Midwest semi finalist
2005 Johnson & Johnson sportsmanship (midwest)
2005 West michigan Champs with 93 and 66
2005 Johnson & Johnson sportsmanship (west michigan)
2005 web site award
Unread 10-03-2007, 22:29
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
The same thing could be argued for any rule. Isn't a weight limit stifling creativity? I could build a really awesome robot if I didn't have to worry as much about weight.
Rules don't limit creativity, they channel it in different directions. In this game, the rules reward a creatively and effectively designed mechanism, rather than a creative way around the way most people play.
Only holding one ringer is part of the game, like not using your hands in soccer, and not traveling in basketball.
I would be inspired if a team can manage to score all of their team's ringers in one match.
This year, awe-inspiring moments like that will most likely come from the drivers and coaches. That's not to say robots can't be inspiring. I'm impressed by the lifter robots that can manage to lift 2 robots, and also by the really effective scoring robots.
Real programmers use vim.
Unread 10-03-2007, 23:03
I will be inspired with you ,IF or when this happen. Thanks for the intelligent debate. You seem like a very thoughtful young person. That is what is inspiring .Good luck to you and your team.
jim
2005 web site award
Veteran Teams have No Advantage dtengineering Regional Competitions 30 09-03-2007 21:05
Week 6 and still not finished! Phil Paspalas General Forum 61 19-02-2006 17:10
Which treads have an advantage? master Technical Discussion 15 15-12-2005 18:09
What do you still have to do? Mr. Roboto General Forum 7 06-03-2005 11:14
Still have work to do in St Louis? asher Regional Competitions 3 31-03-2002 23:18
