Go to Post So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 10-03-2007, 22:29
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: Week 2 Regionals: Veterans Still Have No Advantage
Originally Posted by Jim Schaddelee View Post
why limit someone creativity. How cool would it be if a team score a entire row in autonomous or the rules allowed for more than placing a tube, drop a ramp or climb a ramp.
The same thing could be argued for any rule. Isn't a weight limit stifling creativity? I could build a really awesome robot if I didn't have to worry as much about weight.
Rules don't limit creativity, they channel it in different directions. In this game, the rules reward a creatively and effectively designed mechanism, rather than a creative way around the way most people play.
Only holding one ringer is part of the game, like not using your hands in soccer, and not traveling in basketball.
First is about inspiration. If a team uses a 4link or sliding elevator is that inspiring?
I would be inspired if a team can manage to score all of their team's ringers in one match.
This year, awe-inspiring moments like that will most likely come from the drivers and coaches. That's not to say robots can't be inspiring. I'm impressed by the lifter robots that can manage to lift 2 robots, and also by the really effective scoring robots.
Real programmers use vim.
Unread 10-03-2007, 23:03
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
I will be inspired with you ,IF or when this happen. Thanks for the intelligent debate. You seem like a very thoughtful young person. That is what is inspiring .Good luck to you and your team.
jim
Team 107 Holland Christian / Metal Flow
2005 Midwest semi finalist
2005 Johnson & Johnson sportsmanship (midwest)
2005 West michigan Champs with 93 and 66
2005 Johnson & Johnson sportsmanship (west michigan)
2005 web site award
Veteran Teams have No Advantage dtengineering Regional Competitions 30 09-03-2007 21:05
Week 6 and still not finished! Phil Paspalas General Forum 61 19-02-2006 17:10
Which treads have an advantage? master Technical Discussion 15 15-12-2005 18:09
What do you still have to do? Mr. Roboto General Forum 7 06-03-2005 11:14
Still have work to do in St Louis? asher Regional Competitions 3 31-03-2002 23:18
