Go to Post Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about! - Andrew Blair [more]
Unread 11-03-2007, 15:26
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Need help with gyro turn
I have gyro onto the robot. As soon as i get the angle from the cam. I want my gyro to turn exactly at that angle. so for e.g. my pan angle is 34 degrees than i want my robot to turn 34 degree. However, my Gyro just can't do that. Can someone help me how can i code it so it turns the angle i want it to turn? this is what i have.
/********VARIABLE*******/
int unit_speed = 50;
angle = ((((int)PAN_SERVO - 124) * 65)/124); /* +/- 65 degree [0 to 148] */
error_angle = (angle - (int)temp_gyro_angle); /*Check the angle difference between camera and Gyro*/
printf("Error_angle=%d\r\n", error_angle); /*Print Error Angle*/
if (error_angle < -5) /*If Error angle is less than 5 degrees*/
speed = ((error_angle * unit_speed)/100); /*PID Forumula to control the speed as we move close to target*/
printf("Target is to the left\r\n"); /*Prints if target is to left*/
while(speed > 5)
pwm13 = pwm14= 127; /*Turning Left and the turn is controlled, see below comment*/
pwm15 = pwm16 = 127 + speed; /*The motor movements are controlled by the PID Speed Calculated*/
printf("PWM 13=%d pwm14=%d pwm14=%d pwm15=%d\r\n", (int)pwm13, (int) pwm14, (int) pwm15, (int) pwm15); /*Printing motor values for Debugging*/
printf("Speed=%d\r\n", speed); /*Tells us what is the value of speed according to PID Calculation*/
if (error_angle > 5) /*If Error angle is greater than 5 degrees*/
speed = ((error_angle * unit_speed)/100); /*PID Formula to control the speed as we move close to the target*/
printf("Target is to the right\n"); /*Prints that the target is to right*/
while(speed > 5)
pwm13 = pwm14 = 127 + speed; /*Turning Right and the turn is controlled, see below comment*/
pwm15 = pwm16 = 127; /*The motor movements are controlled by the PID Speed Calculated*/
if (error_angle > -5 && error_angle < 5) /*If the error angle is between -5 degree and + 5 degree*/
printf("Target is straight on"); /*Prints that we are right on target*/
pwm13 = pwm14= pwm15 = pwm16 = 127; /*Stops our motor for a while*/
printf("PWM 13=%d pwm14=%d pwm15=%d pwm16=%d \r\n", (int)pwm13, (int) pwm14, (int) pwm15, (int) pwm16); /*Printing motor values for Debugging*/
printf("Speed=%d \r\n", speed); /*Tells us what is the value of speed according to PID Calculation*/
Unread 11-03-2007, 15:33
Jigar Patel
AKA: Jigar Patel
Re: Need help with gyro turn
Unread 11-03-2007, 21:53
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
...hmmmm
Why don't you, first, try something a bit easier. Let your value of angle be the error term for your P controller. As long as your camera holds its tracking, you should see your robot turn to align to the camera and the value of angle will drive to 0. 0 error, 0 angle Then keep an eye on the value you are getting from your gyro calculations (I am assuming that by gyro, you mean yaw rate sensor, and you are integrating yaw rate to calculate an angle) There could be error creeping into your gyro calculations that is causing problems with your controller.
Don't PANIC!
S. P. A. M.
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
Need help with Gyro = Analog Devices ADXRS150EB Jack Jones Technical Discussion 9 18-07-2005 07:00
With gyro need to access ADC for poteniometer mrozek Programming 0 21-02-2005 13:39
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
