#16
Re: Looking for a rule - No defense on robots without tubes
On the contrary, if it's not in the rules, it's not a rule. Discussion on this point seems quite necessary. The head referee should have been informed that he was "enforcing" a nonexistent rule.
#17
I disagree with the "If the head ref says it's a rule, it's a rule." At the beginning of the LA regional the safety guys said -no- shaded or even -tinted- glasses at any time. We kindly went and talked to them, showed them the rule, and the update that said tinted were allowed, and then they made an announcement stating that tinted glasses were allowed. You just need someone to go and talk to the ref for a while. I know the outcome of LA would have been soooo different if this rule was enforced. And I don't think it would have been fair.
#18
lets not complain. read the thread on complaining. it's near the top now that im writing this post.
#19
He original poster has a valid point. It is not whining or complaining but rather just making us aware of what could happen at future regionals.
#20
the original poster no. it sounded as if a couple other people were. but it's hard to tell people's expression on the internet isn't it? =]
#21
<G52>When making a ruling, the head referee may receive input from other sources, particularly Game Design Committee members, FIRST personnel, and technical staff that may be present at an event. However, the head referee's decision is final. |
#22
Although it isn't explicitly stated as a rule, I agree with it. It allows the intent of the game to occur, which in this game, is to score ringers on the rack and to strategically place spoilers over the opposing alliances ringers.
#23
The most you can infer the intent to be, above all else, is to score more points than your opponents using the methods described in the rule book. That's it. |
#24
I'll go on the record with the "If it's not in the rule book, it's not a rule" crowd. The rule book is there to inform teams of the rules during the design and strategizing phase. Enforcing a rule not in the rulebook and backing it with the intent of the game is simply blindsiding teams that are pursuing a strategy you've suddenly made illegal. Unfortunately, the head GLR ref is not a ref I would feel at all comfortable bringing this up with, so our team simply worked around it. I suspect I know from where this misinterpretation stems.
Here is my concern... I am not complaining... But...
We all have been living and dying the past first 6 weeks with the rule book and the Q&A forum. We all designed robots to play the game within these rules. There has been tons of "Lawyering" which has been frowned upon, but is necessary. So, now we start to play and a "rule" is made by a local ref to enforce what he thinks is the intention of the game "To hang and score ringers" which could totally either help or hurt certain teams based on their design. For example, I stated in my post earlier that it helps the teams that are "scorers" by ringing. But, after thinking about it, it really helps non ring scorers. If you have a ramp bot with no arm, you can't ever have a ring. Which means, nobody can defend you. Ever. Even if you are playing defense against a robot that does have a ring, nobody can hit/push you...because you have no ring... Anyway... "As the FIRST World Turns"... |
#26
There is a difference between obsessively "lawyering" the existing rules that have been provided to all FIRST teams, and having someone create a new rule on the spot and expecting everyone at an event to respond. Neither should take place, but for entirely different reasons. -dave Last edited by dlavery : 11-03-2007 at 20:12. |
#27
Rule <G52> and the rule <T04> that it refers to appear to be designed to avoid looking in a rear-view mirror. Given an advance detection of a conspicuously obvious misinterpretation of rules that I presume the referees are duty-bound to enforce (and I further assume that they are allowed to "interpret" them only when ambiguity exists), I again would recommend to my team or to any other, that we/they should politely and respectfully insist the referee consult with other experts, and/or that we should play within the published rules (not the interpreted ones) and let the chips fall where they may, and/or that we should not play until the matter is corrected. Whether this would make me a patriot or a traitor would depend on whether the observer is a rebellious colonist or a Tory loyalist... Blake PS: A little rebellion every now and then is a good thing.... :-) |
#28
Our team was a definite benefactor of this rule "change." We can handle defense when placing tubes, but our method of picking up ringers didn't allow for much defense (at least at the beginning of GLR). When the head ref made this announcement Saturday morning, our driver and I were elated-- we knew we'd be able to score more. However, I have to fault myself for not recognizing that this wasn't an actual rule. As a driver, it was my responsibility to have known that this was a mistake. To my knowledge, no one questioned this at GLR. As drivers and coaches, we should accept a little bit of the responsibility here, too.
I understand the frustrations that this discrepancy created, but it's also a perfect illustration of the lessons FIRST teaches us. Everyone makes mistakes and a thorough understanding of the rules can solve a lot of a problems. Last edited by jarowe : 11-03-2007 at 20:57. Reason: had something to add |
#29
Thanks for speaking up here, Dave. Most of us understand that the GDC makes the rules, while key volunteers like Head Referees and Lead Robot Inspectors are responsible for applying them. Sometimes we need to be reminded of that. |
#30
This is just another example of a rule made up by the head ref at GLR. I have been in this for 7 years and this is the forth year that I can remember that he has made up his own rules.
We all put a lot of work into this project and to waste an event to his rules changes is very disappointing. We have never had any problems at other events. Last edited by Mr.G : 12-03-2007 at 10:46. |
| pic: Vex-sized tubes for Mini-FRC! | Jessica Boucher | Extra Discussion | 4 | 15-01-2007 19:32 |
| looking for pics of tracked robots | amos229 | Technical Discussion | 11 | 28-08-2006 17:50 |
| Attention All Teams! Looking for 1 Picture of Each of Your Robots | artdutra04 | General Forum | 13 | 01-05-2006 21:02 |
| Can first go this year without changing a rule | nuggetsyl | Rules/Strategy | 11 | 07-01-2005 15:36 |
