Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Unread 11-03-2007, 16:38
Po-ser's Avatar
Po-ser Po-ser is offline
AKA: Polina Danilyuk
FRC #0694 (Stuypulse)
Po-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud of
Send a message via AIM to Po-ser
Roller Grabber Question
Hi all,
I've got a question for teams using plastic rollers on their grabbers (I'll use the Robowranglers as an example: ). How much room do you leave between your top roller and the bottom roller? In other words, how much do you compress the tube when you pull it in to keep it stable? Just curious. Sorry if there's already a thread on this somewhere that I missed.
Thanks!
Aim for the stars, land in Hawaii.
2003 - NYC Regional winner
2005 - NYC Regional Woodie Flowers Award
NYC Regional Chairman's Award
Championship Galileo Division semifinalist
Unread 11-03-2007, 20:50
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: Roller Grabber Question
I designed the end effector for the HOT Team (67) to be adjustable to compensate for variation in ringer inflation, but we did not have to adjust the distance between roller all weekend at GLR.
We have our belts positioned 5-5.5" apart.
If you want you can see pictures of it on our website.
http://www2.huronvalley.k12.mi.us/sc...tos/index.html
Unread 11-03-2007, 21:16
run the trap!!!
Team Role: Human Player
We did extensive research on this subject and built a total of 3 different "suckers" before we got it right.
Center to center, the perfect distance was 9" - but we used 3" wheels so the compression was 6." This may sound tight, but the rubber wheels we used were able to "suck" the tube through the narrow opening.
But the primary griping force wasn't in the wheels at all, it was in the belts that drove them. The belts were arranged in a "V" configuration, so that as the tube was drawn in the compression became even greater. The belts act like rubber bands, squeezing the tube.
It is impossible to remove an inflated tube without running the motors.
(rubber wheels not shown)
-Philip J. Fry
Unread 11-03-2007, 22:20
Po-ser's Avatar
That's gorgeous! Thanks for the info and the photos. I've been looking up videos of roller grabbers in action and it looks like everyone uses lots of compression.
Unread 11-03-2007, 22:24
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Hey... isn't that against the rules? ;P
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 11-03-2007, 22:45
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
http://www.chiefdelphi.com/media/photos/27496
^ 868's kicker wheel. A little different, but the same principle.
We compress the tubes probably 1.5", but I can't remember exactly how much. We do have trouble picking up fairly underinflated tubes, but I don't recall us ever encountering a tube in a match that we couldn't pick up, only on the practice field.
Real programmers use vim.
Unread 11-03-2007, 23:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It is. I'm not sure if 100 has competed yet, but if they haven't, they better find a way to remove them or they will fail inspection.
Unread 11-03-2007, 23:32
AdamHeard's Avatar
Lead Mentor
Calm down everyone; He doesn't literally mean impossible.
The glove motors can be back driven by hand, therefore pulling a tube straight out will allow the tube to come out. Since this kind of pull probably won't happen in a match, the tube must be pretty secure during gameplay.
Elgin Clock's Avatar
FRC #0237 (Black Magic)
How is it impossible to remove without running the motors?
It may be difficult during a match cause of compression factors which is indeed a good thing when trying to hold onto a tube, but when I can pull a tube out of that gripper fairly easily because of an open gripper design, it's not impossible.
I would like to know where " impossible to remove an inflated tube without running the motors" logic comes from.
Unread 12-03-2007, 00:47
run the trap!!!
Okay!!! maybe I exaggerated, I'm kind of a weakling ( )
As was said earlier, the globes back-drive and the tube comes out. You can do it but its difficult.
What I should have said was "It is impossible to remove an inflated tube without turning the motors."
-Philip J. Fry
pic: Finished roller assembly Cody Carey Extra Discussion 2 08-10-2006 23:22
pic: 1902's intake roller Dan Richardson Robot Showcase 7 14-02-2006 20:59
Roller Prototype sdexp Robot Showcase 0 04-02-2006 22:41
Roller chain/sprocket supplier Gui Cavalcanti Technical Discussion 8 29-01-2003 21:17
Roller Chain Adrian Wong Inventor 3 23-02-2002 17:21
