Go to Post Dedication to FIRST gets more challenging as life gets more complicated but the rewards are SOOOOO worth it! - Sean Schuff [more]
Unread 11-03-2007, 21:33
bagawk bagawk is offline
AKA: LeeP
FRC #0997 (Spartan Robotics)
bagawk is an unknown quantity at this point
Re: Team 997 Lifter
Originally Posted by BRosser314 View Post
ok a bit of suggestion if u have the weight, add a small ramp so bots can get on it easier, alot of bots that i have noticed have under a inch of ground clearance
We did add ramps during day 2 of the PNW regional. They worked quite well and we will be making them even better for the Davis regional and championship event!
Unread 11-03-2007, 22:04
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Team 997 Lifter
Originally Posted by Dillon Compton View Post
How do you guys lower your platforms?
Clarification: How do you deploy your platforms from the vertical position they begin in to the horizontal position they are in when actually lifting 'bots? is it just a "let it fall and hope it doesnt break" sort of thing, or is there some other system I'm missing in the pic?
//Dillon Compton
www.metalmoose.com
Unread 11-03-2007, 22:32
1359th Scalawag's Avatar
1359th Scalawag 1359th Scalawag is offline
AKA: Eric
FRC #1359 (The Scalawags)
Team Role: Marketing
1359th Scalawag is just really nice1359th Scalawag is just really nice1359th Scalawag is just really nice1359th Scalawag is just really nice
Re: Team 997 Lifter
997, your robot rocked. I remember seeing you guys at the scrimmage a couple weeks before the regional and our entire team agreed that you'd be going into the finals, if not winning. *and you won*
We'll be seeing you at the Davis Sacramento Regional. Hopefully we'll have match or two with you this time. Good luck!
Unread 12-03-2007, 00:14
BorisTheBlade's Avatar
BorisTheBlade BorisTheBlade is offline
lead programmer 2004
AKA: Dane
FRC #1351 (TKO)
BorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura about
Send a message via AIM to BorisTheBlade
Re: Team 997 Lifter
looks good see you at davis
Team 1351 TKO Robotics (click for our website)
2007 sacramento regional Johnson & Johnson Sportsmanship Award winners
2007 CAL Games Finalists
Unread 13-03-2007, 20:13
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
Re: Team 997 Lifter
//Dillon Compton
one the support pieces for the feet stick out completely to the other platform where we have a pneumatic cylinder that shoots through a whole in the rod, and they are pulled apart by a budgie cord, when we retract the pneumatics, the bungee pulls them apart.
and yeah they just fall, but we looked at all of our parts and they don't hit to hard, they are just like big flaps so the air resistance helps out, also nothing is welded together so we don't have to worry about any of it cracking
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 01-04-2007, 05:30
AKA: Tim L.
Re: Team 997 Lifter
this B...E...A...utiful just won it's second regional :-)
and for being the first year our team has ever won a regional we are really, really happy.
Nationals Here We Come
Unread 09-04-2007, 01:59
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: Team 997 Lifter
It was great being with you guys at Davis, the only question I had after seeing it was how does it continue going up after the power is off?
Unread 09-04-2007, 02:06
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Team 997 Lifter
Once the air flow to the cylinder is opened, after power is cut, the cylinder will continue to be filled until the system is out of stored air.
This will happen as long as the solenoid is triggered before power is cut off.
Unread 09-04-2007, 02:07
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Team 997 Lifter
It's probably* because the valves do not close when power is removed. As a result, the air in the tanks keeps flowing into the pistons, even when power is cut.
*Speculation, but it fits the scenario.
Unread 09-04-2007, 02:44
Stephi Rae's Avatar
Stephi Rae Stephi Rae is offline
Lets play robots!
AKA: Stephanie Morrison
FRC #5803 (Apex Robotics)
Stephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to behold
Send a message via AIM to Stephi Rae
Re: Team 997 Lifter
Congrats on the double wins!! Thats awesome!! We were super fortunate to come out with a win in Vegas (and Rookie All Star) to go with the Imagery from Portland, so we'll be seeing you in Atlanta!
Originally Posted by pakratt1991 View Post
Same to you 1983,
you guys had an awesome pit (i think you even won an award for its colors?)
and that bot really came together on the first day, I really liked the idea for grabbing tubes then turning them sideways to score. The way your crate held all your tools and had places to hang everything was really a space saver, but did you guys have to pay overages on shipping costs?
BTW your mascot really rocked
About the overages... we do pay overages, but it's mainly because we had a ton of extra materials shoved in there and everything... but as Dave said, it's definitely worth it. It's a lot less stressful if you're at least a little organized. We're fortunate to have an awesome coach who's had a little experience and came up with the whole crate idea.
Good luck in Atlanta, we can't wait to be there! The mascot will be there too, we'll make sure to send it your way sometime!
~Stephanie Morrison (Hoag)~
Student - Team 1983 (2007-2008)
Mentor - Team 190 (2009-2012)
Mentor - Team 1983 (2013-2014)
Mentor - Team 1318 (2015)
Coach - Apex Robotics 5803 (2016-Present)
pic: Team #39 lifter Ken Loyd Robot Showcase 1 21-02-2007 11:54
pic: 1584, lifter 6 pirates Extra Discussion 11 28-01-2007 21:38
pic: 1584, lifter 4 pirates Extra Discussion 13 27-01-2007 20:54
pic: 1584, lifter 7 pirates Extra Discussion 4 26-01-2007 17:47
Who's a Lifter? LordKronus Rules/Strategy 2 21-01-2007 00:00
