Go to Post You can't stop trying to look for other ways to do things, or that really defeats the whole purpose of inovation. - AmoryG [more]
Unread 11-03-2007, 23:54
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
AC Adaptor?
Has anyone ever considered using an AC adaptor to power the robot, rather than the gigantic batteries. Does an adaptor even exist for our power needs? (not that we could actually use it at competition) We're working on a test electronics board we can use whenever we need to test a motor or a sensor, and having to drag around a battery kinda ruins the portability, although it doesn't really matter.
void function(void)
  function();
Unread 12-03-2007, 00:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: AC Adaptor?
The controller itself doesn't need a real big battery (the backup battery is about right for the job), but running the robot drive motors does.
Unread 12-03-2007, 00:33
void* Jake;
FRC #1178 (DURT)
Re: AC Adaptor?
Well, the idea is that the board will be an entire electronics system, with an RC and the whole power distribution system, and victors and spikes, etc. and theoretically capable of running an entire robot by just plugging things in, so we can test-drive the first-week chassis, and other things, without having to mess with the new electronics equipment until we have a better idea of all the parts we need. This year's electronics mounting was beautiful, but we built it a bit too soon and had to later add a victor and two spikes randomly to the frame, and had to run extra wires accordingly.
So, yeah, we need the same kind of power you get from the big battery.
void function(void)
  function();
Unread 12-03-2007, 00:38
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
You could run the whole system with a small 12v battery, but don't expect to be able to run any motors that are under much physical load. Look at the motor specs in the Tips and Good Practices manual, they give the no-load current draw. Figure out how much current it will take to power those motors, and read up on how battery specifications work. You should be able to figure out about how long you can run some motors with different size batteries (assuming the motors are not mechanically connected to anything, they just spin freely). Perhaps a 12v nicad battery pack would do what you want, with less weight/inconvenience. Just make sure to use the appropriate charger for it.
Unread 12-03-2007, 00:45
void* Jake;
FRC #1178 (DURT)
Re: AC Adaptor?
Meh. Convenience isn't really an issue. I'd use the normal batteries before I'd go buy another battery. I just kinda thought being able to plug into a wall would be ain interesting feature.
void function(void)
  function();
Unread 12-03-2007, 00:46
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: AC Adaptor?
Here's a link to a video of our "little black box" which enables us to drive any chassis with just the motors and gearboxes installed. http://www.youtube.com/watch?v=Bw7-EVB-XZU In the video we're using it to test drive a rookie team's chassis two weeks before they were able to get all the electronics installed. This box has become one of our most important development tools.
Unread 12-03-2007, 00:48
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
I just realized I did not answer the question you asked....which is whether or not you could use an AC adapter to power the robot.
You might want to ask IFI about this, as there may be some specifications for the power supply that would limit what you would want to do. Typical "wall wart" power supplies are rated to put out a specific voltage at some specific current load. If you have less load, they put out more voltage, which could possibly damage the controller. That is why think that using a battery might be wise.
A lab type regulated DC power supply would probably be fine, but it will be even more cumbersome to use than the regular robot battery!
Unread 12-03-2007, 01:01
void* Jake;
FRC #1178 (DURT)
Re: AC Adaptor?
Well, I knew there had to be a reason no one's tried it before. I just kinda wanted to know what it was.
And that black box is very nice. Could that battery fit any more perfectly?
We had something similar to that as our actual electronics system two years ago. It was actually a large tupperware box that had the Breaker panel and all the Victors bolted in it, with the RC, Radio, and backup battery suspended from the lid. With the held of quick connectors, it could be completely removed from the robot in under a minute. Won us an award too. But then we tried it the following year with a Craftsman toolbox and that was just plain horrible. I'd have to cut metal off of the robot just to get the box out anymore.
Once I get the new Autodesk downloaded to my computer (2.16GB download on Dial-up!) I'll cad up our ideas and put up a picture.
void function(void)
  function();
Unread 12-03-2007, 07:53
Re: AC Adaptor?
Jake,
Because the motors are in stall when they are not moving, the initial start current on a typical robot may be in the 200-300 amp range. An AC supply of that size would be enormous. I know that my 25 amp ham radio power supplies get bogged down just trying to start one motor. The supply is a linear supply and weighs over 20 pounds.
Unread 12-03-2007, 12:37
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: AC Adaptor?
If you're just after a bench setup to test electronics, why not use a power supply and get small motors. I've noticed our programmers dragging around a big board with a battery on it to test sensors. A lot of the time, they could have gotten away with a smaller setup to run their experiments. I have yet to convince them of this though...
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 12-03-2007, 12:42
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: AC Adaptor?
I won't say it can't be done, but I can tell you that you're talking about a HUGE AC/DC converter, and it's going to be very expensive.
For instance, if you want a DC power source of 10 amps, you'll pay ~$60 at radio shack. 20 amps is ~$100.
If you're running two motors for an arm at 15 amps each, 4 sim motors at 20 amps each, a compressor at (I don't know how many)....
You're talking hundreds of amps.
Unread 12-03-2007, 15:53
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
Not really, for testing out the electronics you would not run all these motors at once, and you would not be running the drivetrain under load, etc. 10 amps or less should be sufficient. The only thing that I can see causing problems could be the compressor, if you try to start it when there is pressure in the system it will draw a big load on startup.
Unread 12-03-2007, 16:59
void* Jake;
FRC #1178 (DURT)
Re: AC Adaptor?
That's about what I thought. Again, it's not a big deal.
void function(void)
  function();
Unread 12-03-2007, 22:32
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: AC Adaptor?
Why not just use a car battery charger? The higher quality electronic will put out around 100 amps at almost a perfect 13 volts, which should be within tolerance of the whole system.
-Mike
Unread 12-03-2007, 22:54
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: AC Adaptor?
You might check out the battery chargers themselves. I can't remember correctly, but I believe they're rated to 6 or 8 amps. The thing you may have to worry about is voltage - I think they're 12v output, but they might be higher. Time to break out the DMM.
Real programmers use vim.
Vision Sensor Power Adaptor ? CircularLogic Programming 8 17-01-2007 17:31
Power adaptor for the OI archiver 2000 1 23-06-2002 23:27
Need pinout for tether adaptor archiver 1999 4 23-06-2002 21:55
