Go to Post "Mother nature does not give partial credit" -Woodie Flowers, Kickoff 2003 - TerryDolan [more]
Unread 11-03-2007, 22:40
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Help! Calculating drag coefficient in Autodesk Inventor?
Hi,
is it possible to calculate the drag coefficient of a modeled object in autodesk inventor?
Unread 11-03-2007, 22:43
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
Re: Help! Calculating drag coefficient in Autodesk Inventor?
If it does, it would be the first time I've ever used Inventor to do my physics homework.
Unread 12-03-2007, 01:19
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Originally Posted by brennerator View Post
Hi,
As far as I know Inventor does not do the sorts of calculations required to estimate drag coefficients. Those are usually done using specialized programs for Computational Fluid Dynamics (CFD).
Inventor can be used to create a shape to be used in a CFD code and outputs the shape in several formats that can be translated into something a CFD code can understand. Inventor can also be used to determine the cross-sectional area of a shape, and important factor in determining the drag force.
Christopher H Husmann, PE
"Who is John Galt?"
Autodesk liscenses and Inventor 11 Gurdian Inventor 7 17-09-2006 23:31
We attempt to work out the coefficient of drag on a boring sunday afternoon Bongle Math and Science 6 17-04-2006 08:04
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
proE wildfire vs autodesk inventor ryan_f Inventor 6 18-12-2004 21:36
