Go to Post I just... I can't even comprehend it. Like, my brain is soup. Commas are everywhere. Sentences. Shrinking. zzzzzzzzzzzz... - PayneTrain [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 12-03-2007, 01:24
dtengineering's Avatar
AKA: Jason Brett
Re: Week 2 Regionals: Veterans Still Have No Advantage
Originally Posted by JamesBrown View Post
In each match with the exception of the last one or two in each round (ie when all except 6-12 teams have played the same number of matches) the sum of the team numbers on the red alliance is very close to the sum of the team numbers on the blue side. I am writing a program now to gather data from all of the regionals but from the three I have looked at it seems that in order for one alliance to win they must give losses to three teams with simmilar numbers. This Prevents any group of numbers from getting significantly more wins than any other. It seems that any data you have collected relating win percent (or seeding) to how well these groups are doing is invalid.
There really isn't any merit to any of the claims in this thread.
While I agree with you that having a seeding algorithm that averages team numbers across each alliance prevents any one group of numbers from getting significantly more wins than another, I disagree with your conclusion that this makes the data invalid. In fact, that is the whole point of the data!
Allow me to demonstrate by making two assumptions:
1) A team's performance (robot quality, strategy, resources, etc.) should be at least roughly reflected in their performance in qualifying matches. Note that I'm not saying that this is happening this year, but rather that, in general, your top seeded teams should be relatively better than lower seeded teams.
2) That veteran teams should have some advantages over rookie teams. Not, perhaps, an insurmountable advantage, but one would hope that as teams develop resources and learn more about robotics that they should become better each year. This is pretty much implied, if not explicitly stated by FIRST and is the logic behind the "rookie only" awards at each regional.
Now if one were to take those two assumptions, one could hypothesize that veteran teams should rank higher in qualifying matches than less experienced teams. The fact that this is not happening (at least as far as I can tell) is really rather important.
It suggests that at least one of the two assumptions is flawed. So either teams don't improve with time, or else the qualifying rankings do not adequately reflect the quality of a team and their robot. If we don't get better... why bother? And if the better teams aren't on top (in general...) then why do we give awards like "top rookie seed" and allow only the top eight alliances to pick their partners?
To be clear, I did not mean to suggest that veterans had absolutely no advantages... merely that they demonstrated no statistical advantage in qualifying matches, data that poses a very signficant and valid challenge to the two assumptions listed above.
If FIRST were to implement a scheduling algorithm that ignored team number then we could run a test to see which -- if either -- of the assumptions are invalid. (And probably end up with a much better representation of relative robot quality following the qualifying matches.)
Jason
Just a quick P.S.... If the scheduling algorithm is going to be biased for team number -- or anything other than operational measures such as equal numbers of matches and reasonable breaks between matches -- then that should be stated in the rules at the beginning of the season.
Veteran Teams have No Advantage dtengineering Regional Competitions 30 09-03-2007 21:05
Week 6 and still not finished! Phil Paspalas General Forum 61 19-02-2006 17:10
Which treads have an advantage? master Technical Discussion 15 15-12-2005 18:09
What do you still have to do? Mr. Roboto General Forum 7 06-03-2005 11:14
Still have work to do in St Louis? asher Regional Competitions 3 31-03-2002 23:18
