Go to Post A lack of knowledge is okay; a lack of initiative to learn more is not. - Madison [more]
Unread 12-03-2007, 18:32
Drewsterrules11's Avatar
Drewsterrules11 Drewsterrules11 is offline
316 Elavation Machine
AKA: Andrew Hine
FRC #0316 (LuNaTeCs)
Drewsterrules11 is an unknown quantity at this point
Send a message via AIM to Drewsterrules11
Re: What is your favorite motor....
My favorite motor for our drives is no question the small cim. It was a great change from the old drill motors we had to use back in the day.
My other favorite motor is the Fisher Price. We use this motor to lift our platforms 12 inches this year. I was surprised when i found out they had enough power but they did.
Andrew Hine
Team 316
2007 Finger Lakes Regional 2nd Seeded Team
2007 Finger Lakes Regional alliance 316 1126 and 73
2007 Finger Lakes Regional General Motors Industrial Design Award
2005 Drexel Regional Champions 365 316 and 56
Attending Finger Lakes Regional, Drexel Regional and ofcourse Nationals
Unread 12-03-2007, 18:36
AdamHeard's Avatar
Lead Mentor
Hands down, small CIM.
Unread 12-03-2007, 19:12
Billfred's Avatar
Billfred Billfred is offline
If the question is drive, the answer is small CIM. A keen eye may note two large CIMs on our drivetrain this year. That's only because we're using one small CIM on the arm, since the BaneBots setup was far easier to work with than trying to figure out how to interface with the large CIM. If we were to switch out the arm CIM for some other motors for whatever reason, I'd definitely make the switch back as time allowed.
For arms, I much enjoyed the van door motor (it was on both of 1293's lifts during my tenure), and have been quite satisfied with the Denso motor thus far on 1618's arm (those black hubs are lovely). Looking at 1902's method of adapting the Globe motor down at UCF, however, has made me realize that perhaps I haven't given it a fair shake.
Unread 12-03-2007, 19:19
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
CIMs and FPs are on the top of my list. With the power they unleashed at Bayou, 2.5 horses sure did look like it helped at times, especially when we being pushed and for once could fight back.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 12-03-2007, 19:29
Andrew Blair's Avatar
FRC #0306 (CRT)
By far, the best motor in the in the kit is the small CIM. In most any application, it's a robust, powerful, and forgiving thing. It basically cannot be burned up, and for that reliability alone, it's better than the FP. It has equivalent power and efficiency, and though heavier, it's easier to design into gearboxes, abuse, and needs almost zero maintenance.
It's big little brother is even more forgiving, but it's weight and lower power negate this significantly.
But, a big thanks goes out to the old Van Door motor- that thing was robust and easy to design around, which saved us many times in the past.
-Sir Francis Bacon
-Albert Einstein
Unread 12-03-2007, 19:49
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
That 400hp electric motor they use on the Epcot test track ride.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-03-2007, 19:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
the 700 hp engine in my 55 chevy is right up there too...but I fear we're getting off topic!
Unread 12-03-2007, 19:56
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I didn't hear anyone say FIRST KoP Motors or electric motors. [Although that's what they probably meant.]
Kevin Li
596 - Sciclones
Unread 12-03-2007, 19:57
Athleticgirl389's Avatar
Athleticgirl389 Athleticgirl389 is offline
I Am The Robot
AKA: Ashley Marshall Aka Sharpie
FRC #0102 (Gearheads)
Athleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond repute
Send a message via AIM to Athleticgirl389 Send a message via MSN to Athleticgirl389 Send a message via Yahoo to Athleticgirl389
I'm gonna have to go with many others and say CIM. It has done wonders for our team haha.
2010: New Jersey Regional Quarter Finalist, J&J Gracious Professionalism Award. Connecticut Regional Champions (With 1124 & 383)
2009: New Jersey Regional Quarter Finalist. SBPLI Long Island Semi-Finalist, Motorola Quality Award. Newton Division Semi-Finalist (2970 & 33), BR^2 Champion (With 2793 & 136) & Highest Scoring Match Award
2008: New Jersey Regional Quarter Finalist, Judges Award (Innovative Financial Management). SBPLI Long Island Regional Winner (With 2487 & 2010), Entrepreneurship Award. Fastest Robot In The World
2007: SBPLI Long Island Engineering Inspiration Award Winners
2006: SBPLI Long Island General Motors Industrial Design Award Winners, Brunswick Eruption Champions
2004: New Jersey Regional Motorola Quality Award
2003: J&J Mid-Atlantic Regional Winners
2000: National Finalists
1999: Mid-Atlantic Regional Regional Finalist
Team 102
"Teamwork Is The Fuel That Allows Common People To Accomplish Uncommon Results." - Jeff Gordon
Unread 12-03-2007, 20:34
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Small CIM tops the list, although I could be biased since I remember the horrors of tripping breakers with the Bosch drill motors.
I would vote the Van Door as a close second, as they always seemed to be the perfect arm motor. It's too bad FIRST discontinued using them in the KoP. RIP little fella.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-03-2007, 22:06
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
well since no one said "FIRST motors"
Im gonna go with the A20A3, B18C5, B20A, H22A,K20A,F20B....... and oh ya the twin turbo supra motor
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 12-03-2007, 23:09
underwood's Avatar
underwood underwood is offline
lead machinist
AKA: alex
FRC #1072 (Harker Robotics)
underwood is an unknown quantity at this point
depends on what they are used for.
LOVE the small cims, because first thing a robot needs to do before even thinking about anything else (figuratively speaking of course), the robot needs to be able to move. and move well it usually will, with small cims
big cims are awesome in their own way, not necessarily for use on a drivetrain or bot usually. they are heavy, hard to interface, and take up more space when one could usually use a small cim. however, when someone either new to or outside of FIRST sees these bad boys, the look on their face is priceless.
globe motors i like much. small, built in gearbox, durable. very good for most manipulators. much more could be said, but i wont say it here.
however, my opinion of FPs has somewhat gone down this year, considering the built in heat activated breaker that nobody knew about until we actually ripped one of these motors apart (by bandsaw, not by robot ) words cannot describe how annoying this 'add-on' was.
btw, it really sucks that we cant use vandoors this year. they rock
My Famous Last Words Will Be:
"I dunno, press the button and find out."
If life gives you lemons, find someone who's life has given them vodka and have a party.
"Bad artists copy. Great artists steal."
-Pablo Picasso
"Anyone who has never made a mistake has never tried anything new"
-Albert Einstein
MECHANICAL MONKEYS RULE!!!
Unread 12-03-2007, 23:25
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
1. Globe Motor: these little things are indestructable, I tell you. It's a high quality gearbox on a small motor that is very compact. Very easy to design around.
2. Bosch Van Door Motor: that thing is powerful and has a long shaft to work around, unlike the smaller window motors.
(On a side note, 604 has accumulated several globe motors over the years and we can bring them to the Silicon Valley regional if anyone needs them.)
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 12-03-2007, 23:54
Nick02's Avatar
Nick02 Nick02 is offline
AKA: nick
FRC #0991 (Dukes)
Nick02 is an unknown quantity at this point
I personally love the keying window motor; it’s robust and has plenty of power. I found that a #25 chain sprocket mates perfectly with its gear I had this connected to an arm. The window motor bent the screws holding the arm to the sprocket! I had to go and make hardened steel screws by heating and dipping them in oil.
I hate any bane bots transmission product. Our main 56mm gearbox failed (output plate) in the elimination matches. We couldn’t replace it in time………….
Unread 13-03-2007, 00:27
Aren_Hill's Avatar
Build Nifty Things
i'd have to go with the small cims or the vandoor
believe it or not last year we actually managed to partially toast(horrible response time/power) 2 cims which basically lost us the galileo finals gah, but when we found out and switched them at iri we headed for the win. so small cims all the way
A guy who likes robots.
What Are Your Favorite Cars? Crash101 Chit-Chat 61 07-03-2006 22:02
What is your favorite thread size? Ryan Curry Chit-Chat 5 13-02-2004 16:42
What is your favorite Bushism? Cory Chit-Chat 12 18-01-2003 00:16
What is YOUR favorite toy? asher Chit-Chat 34 10-05-2002 01:42
What was your favorite match? Wetzel Championship Event 26 02-05-2002 00:36
