Go to Post I propose, these forums are not a competition. There is no race to prove a point, to prove you are right, to prove you are wrong. - rees2001 [more]
Unread 13-03-2007, 09:20
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
Re: Machining plastics with CNC
I've machined an iPod dock out of PVC without a problem; I'm pretty sure that the item you are trying to machine is feasible. You'll have to look up the speeds at which the CNC can machine PVC, of course, but as for thermal expansion, I didn't have too much of an issue.
(It did have to be sanded/Dremeled quite a bit, but more or less with any plastic, you'll encounter the same problem).
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
I need help with plastics mechanicalbrain Technical Discussion 13 14-06-2006 11:15
just wondering [g code cnc machining] [527]phil Technical Discussion 16 17-10-2004 17:21
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
Website on basic machining Adam Y. Technical Discussion 1 02-01-2004 20:12
Machining jrgrim12 Technical Discussion 21 07-01-2003 22:41
