Go to Post Note that these comments are based on the 2006 FRC game rules, and they may or may not apply to the 2007 game. Your mileage may vary. - dlavery [more]
  #31   Spotlight this post!
Unread 13-03-2007, 15:05
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Banebots 42mm gearbox: Recommendations for use
Well, I haven't taken them apart to look. But, it appears that shaft misalignment may have been the issue. If you look at this picture you can see the second plate which supports the shaft moves up and down to tension. They both do, but they are not connected; We think they appear to be aligned but may be slightly off.
We are in a predicament now though. We already bought the AM gearboxes so we will probably go with those anyway. We have added standoffs to the plates to keep them in unison though.
Are you stealing the CIM motor for the AM solution from your drive? And are you worried that the reduction of drive power will lower your ability to drive (keep in mind, lower torque not only means less pushing power, but less ability to turn and accelerate as well)? If you are replacing the CIM in your drive with a Large CIM and/or FP, it might be alright, but otherwise I'd suggest looking for an alternative arm solution that does not sacrifice your existing abilities.
Some alternatives for the 42mm Banebots include:
KoP FP gearbox (it may be a bit big and clunky, but it works better than anyone gives it credit for, I believe it is a 128:1 reduction)
AM Planetary then reduced further by an AM single speed (46.793:1 reduction, can accept two motors)
DeWalt XRP transmission (3-speed; 47:1, 15:1, or 12:1 reductions)
Banebots 36mm gearbox: Recommendations for use Joe Johnson Motors 2 02-02-2007 17:10
Strange noises from the BaneBots gearbox/CIM combination. PhilBot Motors 5 15-01-2007 11:15
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
2007 BaneBots 52mm Gearbox is posted ! Ed Sparks Inventor 3 09-01-2007 07:38
Recommendations for 6-amp battery chargers kiettyyyy Electrical 12 25-07-2006 01:37
