Re: File Inclusion
One solution would be to just write your own absolute value function.
int abs(int x){
if(x<0)
return x*-1;
return x;
Re: File Inclusion
but do keep in mind that I'm using easyC, so writing my own function would be a headache. I just want to include "stdlib.h" to shorten the time until completion. an issue I noticed is that the file isn't being properly included because easyC won't put the next #include function in quotes
it looks something similar to this: Code:
#include "UserAPI.h" #include stdlib.h |
Re: File Inclusion
Maybe you can just count up each time the limit switch is pressed. Then to check the state you can see if the limit switch counter variable is even or odd. You can do this by dividing by 2 and using the remainder (zero=even, 1=odd). I don't know the c commands for remainders, as I do most of my programming in VBScript. Usually there is a mod function that is a truncated division (gives the integer portion of the quotient and drops the remainder). IF you subtract the integer mod quotient from the real# quotient you can check the real # answer. If it is zero you've got an even #. If it is not zero you've got an odd number.
Than again, if you can;t use and absolute value function without including it, you probably won't be able to use a mod function either. Anyway, I hope this helps you to some degree. |
| "Error.MCP" file after HEX file trans | iwdu15 | Programming | 1 | 24-01-2007 20:05 |
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| File inclusion issue: | Joshua Lynn | Programming | 1 | 10-02-2006 08:34 |
| File resize? | ryan_f | Website Design/Showcase | 9 | 10-10-2004 12:03 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
