Go to Post Why does kick off take so long to get here but ship date comes toooooooooo fast? - Steve W [more]
Unread 08-03-2007, 16:17
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Code to Read the Binary Inputs on Analog Buttons
Does anyone have example code on how to read the binary digits from the OIs analog inputs? According to Mike only the first 4 binary digits are used to determine buttons being pressed.
For Example:
1000 0000 = Button 1
0100 0000 = Button 2
0010 0000 = BUtton 3
0001 0000 = Button 4
The trouble is the last four digits are random and fluctuate greatly
depending on what mood the chicklet is in so sometimes
or
1000 0001 = Button 1
or
1000 0010 = Button 1
The problem is we really don't want to make 4 cases for every button.
So we just want to ignore them.
Unread 08-03-2007, 16:23
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Code to Read the Binary Inputs on Analog Buttons
The important thing is to use the bitwise AND function in C (&). That's what it's designed for.
Make a set of global variables, and a function that you call every time through the loop that sets these variables from the OI state.
Something like this should work (and I've gotta love any chance I have to legitimately use C' ?: trinary operator) :
int p1_sw_5,p1_sw_6,p1_sw_7,p1_sw_8; // Virtual buttons
void Buttons(void)
   p1_sw_5=(p1_aux&1<<7)?0:1;
   p1_sw_6=(p1_aux&1<<6)?0:1;
   p1_sw_7=(p1_aux&1<<5)?0:1;
   p1_sw_8=(p1_aux&1<<4)?0:1;
Unread 08-03-2007, 16:40
Kingofl337's Avatar
AKA: Adam
Nice, never used that before
Unread 13-03-2007, 21:14
aegeon aegeon is offline
FRC #0818
aegeon is an unknown quantity at this point
now correct me if im wrong but isnt your use of the ? operator the same as the ! operator
im pretty sure that
p1_sw_5 = !(p1_aux&1<<7);
will do the same as
Unread 13-03-2007, 21:35
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
the "(statement)?true:false" syntax is like an if statement in one line
if statement, then true, else false
in this case, however, it would do the same
Unread 14-03-2007, 11:01
kaszeta's Avatar
Originally Posted by aegeon View Post
now correct me if im wrong but isnt youre use of the ? operator the same as the ! operator
You are correct.
Help! Analog Inputs!! brennerator Programming 7 11-02-2007 15:48
Analog Inputs bush Programming 5 13-03-2006 17:49
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
Analog Inputs 316_programer Technical Discussion 2 05-02-2002 05:53
