Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 14-03-2007, 08:08
Re: Swerve Module Question
Adlai,
You are very close to good design. We have found that a combination of things works. We use a bronze sleeve bearing with a thrust plate built in for the top. Added to that is a Delrin circle that surrounds a circular plate at the bottom of the module. This bottom plate is mounted on the bottom of the module and is designed to match the bottom of the chassis. This way the top and bottom of the module is secured by bearing points. The bottom bearing goes a long way to keeping the bottom of the module aligned (so that there is no misalignment in the top bearing producing friction) and prevents the module from moving during driving and collisions. By locking the bottom, you prevent the wheels from getting up on edge (less friction) and you allow the steering linkage(at the top of the module) to maintain a reasonable amount of tension for better control.
Unread 14-03-2007, 17:37
adlai adlai is offline
FRC #0948
adlai is an unknown quantity at this point
Thank you.
I assumed I would need to support the module at the bottom and the top. What I was especially curious about was where you get your delrin, how you mount it to the rest of the module and frame, and if you use small bearings or rollers around the arc to lower friction. I can see how the top bearing would work, seeing as it is a smaller radius.
Another decision i have to make is whether to have one CIM + gearing within each module or to use miter gears and transfer power through the pivot(using outside gearboxes and a sprocket.) The price and inconvenience of mounting the CIM inside the module points me in the other direction, but I was wondering whether one miter gear rotating around the other while they are spinning at high RPM causes problems. I guess now that I think about it it wouldnt really matter, you just need to make sure that your pivot is very precise so that your miter gears maintain good mesh no matter what angle the one that rotates with the module is.
Unread 14-03-2007, 22:22
Adlai,
The delrin bearing is cut from a sheet using standard machining technique. It is a "z" shape through the cross section but with the vertical at right angles to the horizontal pieces. This allows the circular plate at the bottom of the module to hold the delrin in place once the module is mounted in the robot. I have been under the impression that bevel gears are just too lossy for this application. We have always mounted the motors inside the module. We have used drill motors, Fisher Price Motors and the small Chalupas. As I remember, the gear box uses standard gears cut from gear stock and mounted on shafts with bearings in the side plates of the module. Even with the Chalupa, the module ends up just slightly larger than the length of the motor with a gear on the shaft. The wheel is mounted almost touching the motor case and the gear box is just off to the side of the wheel. As you can imagine, using crab drive does bring the wheels closer to the center of the robot since the turning radius of the module must fit inside the outer dimension of the robot frame.
Swerve/Crab Rob2713g Technical Discussion 5 12-11-2006 22:05
A Swerve Drive Question lndnny Technical Discussion 10 20-07-2006 08:09
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
