Re: Jump Drives as Data Recorders.
I started the Chip DOS thread last year after doing some preliminary work with reading SD chips, I haven't tried writing to them yet, but it can be done.
I haven't worked on it since build-season started, but there is a bunch of info on a blog I started here: http://www.techranch.com/blog/ I hope to create a small code library that will make it easy to interface this with the RC, but this project is on a list with others... ;-) Thanks, Jim |
Pavan. |
Jump drives involve usb. SD cards need SPI. Perhaps the easy way to add SD card data storage and logging to the FRC is to use a PIC 18 as a interface between the FRC and SD card. Use the pic to take a ttl serial from the FRC and the massage it and send It out the SPI hardware port. If you look at this link This PIC chip has all the libraries done for you to interface to the SD card and there are high level serial functions to handle the FRC side.
http://kronosrobotics.com/Projects/MMC.pdf Take a look at the Kronos site while your at it. The Dios chip language provides a large library of functions and routines that handle the low level stuff. |
| Seeing is believing...needed: video recorders w/e 3, 4, 5. | soap108 | General Forum | 12 | 12-03-2003 01:37 |
| Seeing is believing...needed: video recorders w/e 1 & 2 | soap108 | General Forum | 8 | 01-03-2003 21:51 |
| CDI Jump Off | Al Skierkiewicz | Off-Season Events | 0 | 07-10-2001 16:31 |
| big jump, up to 131 | Carolyn Duncan | Chit-Chat | 21 | 27-07-2001 17:54 |
