Go to Post You want to be treated like a professional, so you need to continue to act like one even if the odds are against you. - Eugenia Gabrielov [more]
Unread 15-03-2007, 14:35
normaldotcom's Avatar
normaldotcom normaldotcom is offline
EthanZ
AKA: Ethan.Z
FRC #0067 (Heroes Of Tomorrow [HOT])
Team Role: Electrical
normaldotcom is an unknown quantity at this point
Send a message via ICQ to normaldotcom Send a message via AIM to normaldotcom Send a message via MSN to normaldotcom Send a message via Yahoo to normaldotcom
Victor 883 24v
There has been a lot of conversation about if the victor 883 supports 24v with a 24v fan... both recently and in the past. Just to confirm suspicions (if any), a recent email to IFI robotics reads as follows: (with my name/address blocked out)
Yes the 883 will operate at 24 with a 24V fan.
Regards,
Ricky Torrance
IFI Robotics Tech Support
-----Original Message-----
Sent: Tuesday, March 13, 2007 12:23 PM
To: Info@innovationfirst.com;
Subject: Victor 883 Question.
II was wondering if your victor 883 speed controllers
can operate
at 24v if I replace the 12v fan with a 24v fan.
--<normaldotcom>--
http://protofusion.org/
Unread 15-03-2007, 15:11
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Victor 883 24v
The 883 supports up to 30 V, as noted on the datasheet; they even sell a model with a 24 V fan.
N.B. The Victor 883 is not legal for the FRC in 2007.
Unread 15-03-2007, 16:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Victor 883 24v
But do the 883s we used to get in previous years in the KOP support 24V operation?
Unread 15-03-2007, 16:44
EthanZ
AKA: Ethan.Z
Re: Victor 883 24v
Yes, I believe so. The 883's in the KOP should be the same, unless they are the ones with RED and not BLUE text. The ones with red text lack a central capacitor, and I am not sure as if they support 24v or not.
--<normaldotcom>--
Unread 02-01-2008, 17:21
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
Re: Victor 883 24v
Eric,
The older Victor 883's that were included in the FIRST kit of parts are not capable of running at 24V. The units will be damaged if 24V is applied. The Victor 883-24V that is available today was a complete redesign of the PCB.
Regards,
Tom Watson
Innovation First
(903) 453-0802
Sent: Tuesday, January 01, 2008 11:03 PM
To: Info-Innovatoinfirst
Subject: Old Victor 883 at 24v
Hello IFI,
I am sure you get these questions a lot:
Victor 883's that were provided inside the kit of parts for FIRST Robotics Competition in past years, are they able to run 24V (if the 24V fan was added)?
Also, are the new 883's different from the old 883's from inside the kit, and if so, what are the changes?
Thank You,
Eric
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
VICTOR 883/884 HELP hanspflaumer Electrical 2 23-02-2007 18:14
Old 883= 24V Speed controller??? stealth13777 Electrical 17 21-07-2005 12:45
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
24v Motors, run on 12v? Jacob Morgan Electrical 26 01-01-2004 23:11
victor 883/884 Brett W Technical Discussion 21 08-01-2003 20:36
