Go to Post I was outvoted by conservative teenagers (curse them...). - Rick TYler [more]
Unread 15-03-2007, 18:08
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
pic: 1015 Rapscallion/Kirohitsuji: GLR Champ
Unread 15-03-2007, 18:10
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Re: pic: 1015 Rapscallion/Kirohitsuji: GLR Champ
Are those huge things sprockets? How big are they and what pitch of chain are you using?
I like the surgical tubing in the back, we tried that on our jointed arm too
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 15-03-2007, 19:08
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
To tint the gripper, have you considered colored mono-kote? I'm refering to thin, semi-transparent, heat shrink covering used for model airplanes. You could find it in any hobby store that caters to the RC airplain kit building.
It would be light weight and easy to apply (scissors, iron, and heat gun), and would let you add color without swapping out your gripper. Your could even use multiple colors to create a fancy design.
Thanks for sharing your robot picture.
Team 1425 - ERROR CODE 1425 - Wilsonville Robotics
Unread 17-03-2007, 15:49
Gertlex's Avatar
Alumni and mentor
AKA: E Relson
Thanks for that advice, ericand. Sounds simple, and I've had zero luck finding other stuff on google...
I believe the large sprockets are 96 teeth. Connected to 16 teeth sprockets. #35 chain. the chain hasn't broken The only problem has been that we initially usedset screws for the small sprockets. We drilled through the shaft and put screws in during the finals at GLR. The main arm is powered by the two keyand motors, the secondary arm by the window motor, and the grabber by the globe motor. The globe (at 180 rpm I think) is WAY slow, though.
pic: 469 Loading up at GLR Don Wright Robot Showcase 0 30-03-2006 09:36
pic: 862\'s First Match at GLR 2006 pathew100 Regional Competitions 5 21-03-2006 10:49
Video: Team 1015 Shadowmage Robot Showcase 5 24-04-2005 12:12
The Unofficial Team 1015 regional video! Shadowmage Regional Competitions 3 18-04-2005 23:56
pic: Team 1015 Robot: SOSUMI lphan Robot Showcase 6 27-02-2005 18:54
