Go to Post ...Of course, all the scales in the world won't help you if your robot is 135lb two nights before the ship date... - J Flex 188 [more]
Unread 16-03-2007, 19:20
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Autonomous Target Tracking at Regionals
I'm at my witts end with trying to get my auto code running this year. I'm trying to find the "silver bullet" that will explain what I'm not seeing this year.
Background...
We had great auto modes last year. Dependable target tracking etc. We avoided the pan-tilt unit and just scanned our robot directly.
This year, we have several auto-ringer placing auto modes, that all work great at our home facillity and at the regional practice fields, but we can't get any joy on the actual playing field. The bot just DOES NOT see the lamps.
We had the problem at Pittsburgh and now again at the Chesapeake regional. I polled some of the other teams and many of the teams that are trying to get auto mode working are having the same trouble. Good on practice, bad on real field.
I started suspecting that the Rack's lamp power supply wasn't able to drive all four lamps. This would explain why single lamp test racks all seemed to work. I raised this possiblity at the Chesapeake regional and I was shown the camera verification setup they use to ensure that the arena lamps are all working properly.
They use the Labview GUI to load the "default" settings and show the tracking numbers. It looked fine.
I verified that my camera.h file data was the same & matched the on-screen numbers. (I'm using the streamlined 2.1 camera code.)
At this point I'm convinced that there is some subtle difference between the GUI program (which works fine) and the camera.c/h code (that hardly anyone can get working on a real playing field). (something like a flag that only has an effect in a really bright environment)
I even spoke to Dave Lavery on the sidelines today, but he re-affirmed that everything sould be fine.
Ask yourself... how many relaible auto-modes have you seen this year (compared to last year)... There was maybe two at pittsburgh and none so far at Annapolis....
In my case the camera initializes fine. but does not show any targets with any non-zero confidence levels despite how close I get to the spiders... (Unlike in the pits where I get a great target)
Any brainstorms...
I've attached my .h file.. I've tried filtering on/off to no avail.
Unfortunatly we can't get on the field with a computer attached...
Phil
Phil Malone
http://www.GEARSinc.org
Unread 16-03-2007, 19:36
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Autonomous Target Tracking at Regionals
I would check to make sure that your camera is focused. When you are a large distance away(like on the field) that makes a difference but when you are closer like in the pits its much easier for the camera to see the lights.
Also check the camera manual to see if there is anything that may help you adjust for the different light, I know there are some but I don't remember how to use them atm, and my copy of the manual is AWOL.
KK4KQO
http://voltair.us
Unread 16-03-2007, 20:36
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
check your focus, check your autonomous switches, check everything.
a problem that we encountered was EMI that was interfering with the camera and causing it to cycle out until it completely lost the target. perhaps your robot may be experiencing this?
We have actually had some very successful auto modes this competition... after we got away from the silly mechanical errors we were fine.
EDIT: actually, come to think of it, the light gains that we perfected last year have served us very well... we went through about 3 hours just adjusting the color gains and the ranges until they were just right... i guess we just got lucky that it worked all around.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 16-03-2007, 20:37
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
0) Double check your color numbers (R, G, and B). I remember at GTR last year they changed them a few times over the course of the regional to try and improve detection, such that to use our test lamp we had to change the code from our competition code. It was one of the things on our pre-match checklist to make sure that we had the correct camera colours.
1) See if you might be able to add shades or blinders around the camera so that you aren't picking up particularely high or low arena lights. Bright arena lights can get confused for the target. They may not exist on the practice fields, but they are there in the real thing.
2) I guess it is too late for it now, but maybe ask to be let onto the field with labview and see what it is?
Unread 16-03-2007, 20:52
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
There has been some discussion on the light this morning in another thread here. I wish I knew for sure on how to fix it. We had the exact same problem on the Wisconsin Regional Field. There was a value that we changed that fixed a lot of noise and I believe it was the Noise Filter like what petek mentioned in post 598538. I hope you get it. If you figure something out I would be interested to know for future designs in Off-Season project
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 16-03-2007, 21:34
PhilBot's Avatar
AKA: Phil Malone
We have a new camera and a spare. We focussed both. We also have a full size field at home and the routines worked fine there so we are pretty comfortable that it's not a camera optics or allignment problem.
Also, we do get right up in the face of the rack (closer than in the pits even) and still not lock indication.
I'm really looking for information from anyone who has actually GOT target lock during Rack 'n Roll "competiton".... any special trick you discovered.
Phil Malone
Unread 16-03-2007, 21:39
PhilBot's Avatar
AKA: Phil Malone
I also discovered that the noise filter is good at removing "fly aways" at my home field, but right now I'd just like to see ANY target
Phil Malone
Unread 16-03-2007, 22:10
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
We had no problem seeing the camera at Forida regional.
Our sister bot 1369 is at peachtree with our main programmer of 1902. they could not see the light on the playing field. They switched cameras and now it is working.
Doug Leppard
Unread 16-03-2007, 22:33
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
uhmm
maybe the lighting has something to do with it
at home our camera couldn't track a green light for anything(it kept looking out the window)
but at night or in a darker area it tracked it real well.
so maybe adjusting the noise filter like the other teams said will fix it
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 16-03-2007, 22:44
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Arg.
Developing proficient camera image analyzation software in an uncontrolled environment while having to account for thousands of small environmental nuances is a near impossible task in and of itself. Then realize that it has to be written in a few days (programmer deadline's are a little shorter than six weeks) by high school kids.
I mean I guess I should be happy that the robot even moves, but I swear: give me one overnighter and an open field and it'll be perfect... I would've stayed over at the convention center tonight! I JUST WANT ONE NIGHTTT
Sigh.
http://www.mikesorrenti.com/
Unread 17-03-2007, 00:06
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
We haven't been at a regional yet, but our gym has similar lighting to that of a regional. When we tested everything out in our robotics portable it worked like a charm from lab views values, but in the gym, during the last couple days, I spent a good 4-5 hours changing this and that, because lab view's values simply didn't give us values which were tracking from. I literately changed everything in hopes it would work.... eventually I hit the right combination of tweaks and my autonomous worked right then and there.. what I found out from the experience was that in that lighting environment, Lab view tended to to give lower values then the needed, to confirm we slowly turned off the lights one by one, and as it got dimmer the Lab view values would become closer to the needed values. We tried it on our other camera, and found the same thing happened but at a different rate... so we don't know if its labview, camera or what. hope that helps.
David
Unread 17-03-2007, 00:13
Back after 4 years off
FRC #5279
Tomorrow before matches if you can go out on the field with either LABVIEw or the GUI and your camera and check the numbers and make sure they fall into your range. If you have no luck with that then see if you can switch in another camera.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 17-03-2007, 03:00
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
We had the same problem in Arizona. I fixed it in the code and now it works perfect.
message me if you want the solution.
-Borna Emami
Team 0x27
Unread 17-03-2007, 06:20
PhilBot's Avatar
AKA: Phil Malone
Hi... I don't have IM... & only limited connectivity...
Can you email me something? Phil.Malone(at)mr-phil.com
Phil Malone
Unread 17-03-2007, 06:24
PhilBot's Avatar
AKA: Phil Malone
That's what I'd love to do, but despite how helpfull the staff have been, they draw the line at letting anyone on the field.....
I'm going to see what I can try from the sidelines.....
Note to organizers....... maybe next year, consider lowering the lights during auto mode
The the general concensus becomes that "Auto mode is too hard and not worth it" then one key part of the engineering challenge will be lost.
Phil Malone
No Tracking During Autonomous jdejoannis Programming 4 10-02-2007 14:46
Camera Tracking Target Jade Programming 3 20-01-2007 01:41
How should we call camera tracking functions during autonomous mode? SHerpich Programming 1 15-02-2006 18:33
Autonomous Capping Regionals Collmandoman Regional Competitions 15 15-03-2005 22:48
Autonomous at Regionals Babyhueyhnx Regional Competitions 34 14-03-2005 20:00
