Go to Post What about "I h8 Autonomous Mode" (for the programmers who actually have to make the robots work)? - Tristan Lall [more]
Unread 16-03-2007, 22:53
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Re: Anyone actually using hardware timers?
Thanks for all the help everyone! I've created the timer, wrote my autonomous code and I should be up and running fully in Waterloo . It'll require a bit a tweaking, but I'm up for the challenge .
Unread 18-03-2007, 21:00
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Team 11 uses a timer to count 14.5 seconds, we drop our keeper last half second of autonomous mode.. it worked great for us and we never had any problems with it
Unread 24-03-2007, 00:24
dragoonex's Avatar
dragoonex dragoonex is offline
FRC #1325 (Inverse Paradox)
dragoonex is on a distinguished road
We implemented Timers into our code this year, and they are great. We set ours to fire off every millisecond. Unfortunately, we didn't have the time, but we plan to write a wrapper around one timer so we can schedule "events" to happen at certain time intervals. But so far, the timers have been proven to be extremely useful and you should definitely implement them.
Some tips, your interrupt routine should be fast. In fact, you should really only be really incrementing a number in it. Remember that since your timer is firing every X milliseconds, your number is being increased very rapidly. So use a big type like a long, or a long short. These will last your for days.
Also, always, always, always, disable your timer interrupts before trying to access your "tick" variable. Bad things will happen if you don't.
Unread 26-03-2007, 03:11
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
We have a scheduler based on the hardware timers. It allows scheduling of events at regular intervals, or single shot events at some time in the future.
It uses function pointers to allow the scheduler code to avoid needning to know what functions it may be calling.
Unread 26-03-2007, 08:16
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
What kind of things are you scheduling?
Unread 27-03-2007, 03:21
ericand's Avatar
AKA: Eric Anderson
Anything that needs to be called on a regular basis. For example, a regular sensor reading that is faster than the 26ms loop, but not "as fast as possible".
Unread 27-03-2007, 12:43
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
It seems like timers are a problem for a lot of teams so I posted ours this morning on this thread in the wrong place... I didn't see the rest of the thread or that the issue was already solved.
http://www.chiefdelphi.com/forums/sh...d.php?p=605834
It sounds like you have taken a similar approach with event timers that call routines when they time out. After all when all your other sensors have failed or you should still at least have timers! The example shows one way to estimate processor loading which also seems to come up a lot.
Are you actually using bumpers? Chriszuma Technical Discussion 28 16-02-2006 18:41
Using Timers psquared Programming 9 30-01-2006 10:29
IS ANYONE USING PNUEMATICS archiver 2001 14 24-06-2002 00:18
Does anyone know what actually happened...? Adam Y. Regional Competitions 7 30-03-2002 01:48
Does anyone actually plan on playing rough? Joe Menassa General Forum 10 10-02-2002 05:09
