Go to Post I like anything that is designed to bounce for up to 10 minutes. Expecially if it lands right side up :) - GregT [more]
Unread 17-03-2007, 15:49
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Re: pic: 1015 Rapscallion/Kirohitsuji: GLR Champ
Thanks for that advice, ericand. Sounds simple, and I've had zero luck finding other stuff on google...
I believe the large sprockets are 96 teeth. Connected to 16 teeth sprockets. #35 chain. the chain hasn't broken The only problem has been that we initially usedset screws for the small sprockets. We drilled through the shaft and put screws in during the finals at GLR. The main arm is powered by the two keyand motors, the secondary arm by the window motor, and the grabber by the globe motor. The globe (at 180 rpm I think) is WAY slow, though.
pic: 469 Loading up at GLR Don Wright Robot Showcase 0 30-03-2006 09:36
pic: 862\'s First Match at GLR 2006 pathew100 Regional Competitions 5 21-03-2006 10:49
Video: Team 1015 Shadowmage Robot Showcase 5 24-04-2005 12:12
The Unofficial Team 1015 regional video! Shadowmage Regional Competitions 3 18-04-2005 23:56
pic: Team 1015 Robot: SOSUMI lphan Robot Showcase 6 27-02-2005 18:54
