No RS232 port alternative
The laptop computer my team uses for programmer our robot does not have an RS232 port on it, given that it is a newer model. For the competition, I have been using a USB to RS232 converter, but the download time is painfully slow! While at our regional competition, I had another team tell us that there was another port that we could use instead of the USB port for programming if we got a different converter.
Does anybody know what kind of converter this mght be, or where I could get one? If it helps, we're running Windows XP Media Center Edition, so it has some extra media ports for cards and the like. I think the team we heard this from referenced one of these ports, but I might be wrong. Demothesis |
Re: No RS232 port alternative
what brand usb --> rs232 adapter are you using?
i have a parralax one and it only takes like 2 seconds more that our other programmer with a native serial port. this is the one i have http://www.parallax.com/detail.asp?product_id=28031 good luck /forest |
Our team had this exact problem and after a bit of troubleshooting it came down to the brand/model of the USB-RS232 (Serial) convertor you use and the way it translate/converts the data in either the hardware (chipset) or software.
Our team has great success with the following adapter(s): Keyspan Serial to USB Adapter http://www.compusa.com/products/prod...to_USB_Adapter Port_Authority_USB_Serial_DB9_Adapter http://www.compusa.com/products/prod..._DB9_Adap ter Also changing some settings in the adapters has helped us improve the speeds to near native Serial speeds. This includes 1. Making sure in the Windows device manager your virtual serial port is SET to the default settings WITH 115,200 baud rate 2. Make sure that FIFO buffers are enabled in the adapter in the driver settings. This is a bit complex but it boils down to the way the adapter negotiates with the RC. |
I tried about 4 different USB to serial converter cables and found the IOgear to work the best and fastest. I think it takes 4/5 seconds to load the program.
-Mike |
#7
I just bought the Parallax one for my macbook if the cable goes bad I'll chop the connector off and solider it to the board. The VEX cable is slow it a capital "S".
#8
I had been using the cable from the VEX programming kit. It is SLOW.
I have good luck with the IOGear(I think) adapter from WalMart. |
| Problem with TTL-RS232 + CMUCam | Shinigami2057 | Programming | 6 | 28-01-2007 08:47 |
| Noisy power supply interfers with rs232/ttl | Mike Mahar | Programming | 1 | 27-01-2007 22:02 |
| Looking for Borrowed RS232 Camera Port Card from BAE Granite State Event | psycho7 | Regional Competitions | 0 | 12-03-2006 13:55 |
| RS232 Radio link | Rickertsen2 | Technical Discussion | 8 | 18-01-2006 12:02 |
| TTL port to a serial port on a demo board | ImmortalAres | Programming | 16 | 09-07-2005 23:44 |
