Go to Post Unfortunately, you cannot always tell when some things are jokes on forums, because we only can rely on text and a limited number of smilies. - artdutra04 [more]
Unread 17-03-2007, 16:50
Demothesis's Avatar
Demothesis Demothesis is offline
Team Leader/Programmer
FRC #2169 (KING TeC)
Demothesis is on a distinguished road
No RS232 port alternative
The laptop computer my team uses for programmer our robot does not have an RS232 port on it, given that it is a newer model. For the competition, I have been using a USB to RS232 converter, but the download time is painfully slow! While at our regional competition, I had another team tell us that there was another port that we could use instead of the USB port for programming if we got a different converter.
Does anybody know what kind of converter this mght be, or where I could get one? If it helps, we're running Windows XP Media Center Edition, so it has some extra media ports for cards and the like. I think the team we heard this from referenced one of these ports, but I might be wrong.
Demothesis
Unread 17-03-2007, 17:35
Back after 4 years off
FRC #5279
Re: No RS232 port alternative
Something like this could work.
http://www.quatech.com/catalog/rs232_pcmcia.php
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 17-03-2007, 17:43
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
what brand usb --> rs232 adapter are you using?
i have a parralax one and it only takes like 2 seconds more that our other programmer with a native serial port.
this is the one i have
http://www.parallax.com/detail.asp?product_id=28031
good luck
/forest
Unread 17-03-2007, 23:55
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
I advise caution with the Quatech cards. The connector between the actual card and the cable is crap. I have three of the Quatech 4 port cards (QSP-100) at work and they are all but useless. I can't keep the cables connected to the card. I also tried the Socket brand of PCMCIA to Serial and they are OK but buffer the data. I use them at work to collect field data from instruments and when your GPS time tag data is 5 minutes older than your instrument data it tends to cause problems later in processing. I have had no problems since switching to USB-RS232 converters from IOGear.
Unread 18-03-2007, 16:18
WillZZZ's Avatar
WillZZZ WillZZZ is offline
FRC #0503 (Frog Force)
WillZZZ will become famous soon enough
Send a message via AIM to WillZZZ Send a message via Yahoo to WillZZZ
Smile Re: No RS232 port alternative
Our team had this exact problem and after a bit of troubleshooting it came down to the brand/model of the USB-RS232 (Serial) convertor you use and the way it translate/converts the data in either the hardware (chipset) or software.
Our team has great success with the following adapter(s):
Keyspan Serial to USB Adapter
http://www.compusa.com/products/prod...to_USB_Adapter
Port_Authority_USB_Serial_DB9_Adapter
http://www.compusa.com/products/prod..._DB9_Adap ter
Also changing some settings in the adapters has helped us improve the speeds
to near native Serial speeds. This includes
1. Making sure in the Windows device manager your virtual serial port is SET to the default settings WITH 115,200 baud rate
2. Make sure that FIFO buffers are enabled in the adapter in the driver settings. This is a bit complex but it boils down to the way the adapter negotiates with the RC.
--Will
Unread 18-03-2007, 16:37
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I tried about 4 different USB to serial converter cables and found the IOgear to work the best and fastest. I think it takes 4/5 seconds to load the program.
-Mike
Unread 21-03-2007, 16:33
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I just bought the Parallax one for my macbook if the cable goes bad I'll chop the connector off and solider it to the board. The VEX cable is slow it a capital "S".
Unread 21-03-2007, 18:25
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I had been using the cable from the VEX programming kit. It is SLOW.
I have good luck with the IOGear(I think) adapter from WalMart.
Eric Haskins KC9JVH
Problem with TTL-RS232 + CMUCam Shinigami2057 Programming 6 28-01-2007 08:47
Noisy power supply interfers with rs232/ttl Mike Mahar Programming 1 27-01-2007 22:02
Looking for Borrowed RS232 Camera Port Card from BAE Granite State Event psycho7 Regional Competitions 0 12-03-2006 13:55
RS232 Radio link Rickertsen2 Technical Discussion 8 18-01-2006 12:02
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
