Go to Post Keep in mind that words can be harsh and people do not forget what is said against them. Please, for your teammates sake, keep your egos in check and try to use some tact and consideration. - Andy Baker [more]
Unread 17-03-2007, 00:57
Carpe_Noctem's Avatar
Carpe_Noctem Carpe_Noctem is offline
Carpe Noctem--Seize The Night!
AKA: Jordan Frost
FRC #1057 (Blue Knights)
Carpe_Noctem is an unknown quantity at this point
Drive Train & Control Types '07
I'm at the Peachtree Regional in Atlantaand i have seen a lot of omni drive trains. Many are the set-up of 2 omni, one on back and one on front....
What is common at the other regionals?
Also i have seen some very innovative control schemes!
Team 1261 won an award mainly for their mix of a Guitar Hero guitar controller and a Xbox 360 controller!
Are there any more kinds out there?
GO KNIGHTS!!!--TEAM 1057
Knifir un Skolir Waise Edoc'sil!
-The Sword and the Shield be Unconquerable!
Unread 17-03-2007, 01:21
dtape's Avatar
dtape dtape is offline
AKA: Jeff
FRC #0467 (The Duct Tape Bandits)
dtape will become famous soon enoughdtape will become famous soon enough
Re: Drive Train & Control Types '07
can you get a picture of 1261's control board?
Unread 17-03-2007, 06:51
Billfred's Avatar
Billfred Billfred is offline
Up at Chesapeake, it seems that we're seeing a lot of kit drivetrains (loosely defined as BaneBots transmissions and AM kit wheels, most with the kit frame). There are a few IFI wheels, but there's about as many teams running AndyMark mecanums to varying degrees of success.
However, mecanums haven't completely killed off traditional omni--both 341 and 1418 are rolling on some variation of AM omnis (plastic for 341, aluminum for 1418).
Unread 17-03-2007, 10:05
teenmisfit's Avatar
teenmisfit teenmisfit is offline
AKA: John Willis
FRC #0501 (PowerKnights)
Team Role: Driver
teenmisfit has a spectacular aura aboutteenmisfit has a spectacular aura about
Personally i find 175 drivetrain to be wonderful. It isnt new but every year it helps them do wonderful. They use 2 drivetrains. One is the normal bot 6 wheel 4cim drivetrain and then they have another drivetrain mounted sideways underneath the chassis on pneumatic pistons. When this drive train pops down it enables them to physically move sideways.
Powerhouse drivetrains are also do verywell this year because defense and pushing robots aside to score ringers is big.
Unread 17-03-2007, 18:14
Adamskiy's Avatar
Adamskiy Adamskiy is offline
Team Founder
AKA: Brandon Adams
FRC #1261 (RoboLions)
Adamskiy is on a distinguished road
Not really much of a control board, just 80-20 and plexiglass. For the Guitar Hero controller, instead of trying to interface with the Playstation2 plug, we just ran wires directly from the switches to the pinouts. We then used a USB Chicklet for the XBox 360 controller.
Our drive system (all wheel drive) was chain-driven off of two large CIMS with two IFI "sticky" wheels in the front and two omni wheels in the back, and operated with the Xbox controller. Our manipulator (sorry, no picture) was a cable-operated elevator that had two "fingers" that would slide under a tube, and two rubber wheels that would pull a tube in and rotate it upward to about a 30-degree angle.
The winch was a small CIM with a BaneBots gearhead and encoder....so we used 3 of "string" buttons on the guitar for high/medium/low positions, with the other 2 buttons used for manual adjustment. The load/unload function of our grabber was then controlled by the "strum" switches on the guitar.
Team 1261 - Motorola/Cognex/EMD Software & Peachtree Ridge High School
- 2005 Peachtree Regional Champions
(Thanks 281 and 801)
- 2006 Peachtree Regional Champions (Thanks 1414 and 1057)
- 2006 Peachtree Regional Delphi "Driving Tomorrow's Technology" Award
- 2006 Peachtree Regional Underwriters Laboratories Safety Award
- 2007 Peachtree Regional Innovation In Control Award
(Guitar Hero controller )
- 2007 Peachtree Regional Semi-Finalists (Thanks 1746 and 1057)
Unread 17-03-2007, 18:38
JackN JackN is offline
AKA: Jack Nowakowski
JackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond repute
This seems to be the year of the crab. I have seen so many great teams use it including 71, 111, 118, 384/1086/540, 469, 1503/1680 648 and 1625. It has been very interesting to see all of these teams sliding around the field. These drivetrains are very good but they require some very skilled drivers to operate.
I also was impressed by 703's 14WD. No that is not a misprint. Search CD Media for it. The strength it gave them made them strong defenders and they are able to get up just about any ramp that is put down in front of them.
The two quickest drives I have seen are 247 and 1114. I know the Simbots can get to 14 FPS and I would not be surprised if Da Bears weren't going at least that fast. These two robots are going to be scary at championship.
2005-2007 Team 494 (Lead Scout and Strategist)
2008 Team 70 (Drive Coach)
2009-2011 Team 1504 (College Mentor)
Unread 17-03-2007, 22:57
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Here in California, I have been seeing mostly 4/6 WDs, lots of interesting omni setups, and a few mecanum drives (my team is the only one I've seen so far with non-AM mecanums).
There was one very interesting omnidrive at SVR (I think it was team 362) that used two wheels on each side of the bot, with each pair parallel to its corresponding side. Pretty wicked looking
I also saw one with AM omnis arranged at 45 degree angles, much like mecanums.
I really like 254's 6WD drive. It's not only faster than my team's mecanum bot (which can go about 13-14 fps), but it can turn on point better than us Even though it has a significant lack of pushing power, the agility is beautiful.
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 17-03-2007, 23:24
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
422 also did the first method of omni wheels, although for ramping I think that the 45 degree method would have been better.
We also controlled it like a first person shooter game to try and get a more intuitive drive system.
KK4KQO
http://voltair.us
Unread 18-03-2007, 02:30
AdamHeard's Avatar
Lead Mentor
Lack of pushing power? I think they would be upset if they heard that...
They have a 5fps/16fps (or 6/15 I forget...). The high gear is very fast, and the low gear is putting out a significant amount of torque, probably just around traction limited knowing them (which is a lot, using gum rubber roughtop tread... which is about the highest coefficient of friction you can legally get for wheels). So, I'd say they can push if they need to; They're just too busy scoring.
Unread 18-03-2007, 13:03
Joel J's Avatar
Joel J Joel J is offline
do you..
I don't think they are using bumpers, and I think they are in the 110 lb weight class. So, they are at about 124lbs, with battery (maximum). I also read something about them weighing about 85lbs, because they were planning on adding ramps. If they didn't add weight to get to 110lbs, then they are really scrawny at 100lbs, with battery. That hurts their pushing power. 100*1.3 is equivalent to 150*.867, about the amount of traction advantage a full-weighted 4ft class robot would have with something even less grippy than the old wheelchair wheels that were in the kit. They have the torque, and they have the treads, but they are lacking the weight.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 18-03-2007, 13:25
Adamskiy's Avatar
Team Founder
AKA: Brandon Adams
As did we with our Xbox controller - left thumbstick was throttle, and right thumbstick was steering.....so basically the same as Halo
Unread 18-03-2007, 14:01
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
384, 1086, and 540 (the West Henrico Triad) actually used Mecanum, not crab.
With a few exceptions (111 @ MWR, 540 @ VCU, 175 @ BAE, and probably a couple others), the traditional "tank steering" drive has won every event. Although, this may be (at least in part) a bi-product of the vastly higher quantity of these drives.
Unread 18-03-2007, 14:05
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Im a little confused about the post about omnis at Peachtree. Yes teams used omnis but not in an actual omni drive they were only used as casters more or less to allow for easier turning.
Mentor 2415
Unread 18-03-2007, 14:20
Adamskiy's Avatar
Team Founder
AKA: Brandon Adams
Yeah, all of the omni wheels I saw were just used to aid turning, like we used. There was one crab drive (1057), and one robot had mecanum wheels (I forget the number) with independent suspension. Other than that, though, I think all other robots were 4- or 6-wheel tank drives.
Unread 18-03-2007, 14:27
Brian J. R.'s Avatar
Brian J. R. Brian J. R. is offline
Pit Chief
AKA: Brian Richards
FRC #1983 (Skunkworks)
Brian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to behold
Send a message via AIM to Brian J. R. Send a message via Yahoo to Brian J. R.
We used the 2 omni 2 traction wheel method like other teams. With 2 motors to a transmition (having 2 transmitions, so a motor per wheel essentially) we had plenty of pushing power and speed which made it easy for us to defend or score. Even though it gave us the power and speed we needed, it wasn't enough aginst an all traction drive system (that wasn't pretty....)
Brian Richards, 1983 Mechanic
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Where Are "Chassis & Drive Train Instructions" Robeaux Kit & Additional Hardware 1 10-01-2006 16:17
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Drive Train Thunder360 Motors 5 21-03-2003 20:41
