Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 18-03-2007, 14:28
teenmisfit's Avatar
teenmisfit teenmisfit is offline
AKA: John Willis
FRC #0501 (PowerKnights)
Team Role: Driver
teenmisfit has a spectacular aura aboutteenmisfit has a spectacular aura about
Re: Drive Train & Control Types '07
Originally Posted by Lil' Lavery View Post
384, 1086, and 540 (the West Henrico Triad) actually used Mecanum, not crab.
With a few exceptions (111 @ MWR, 540 @ VCU, 175 @ BAE, and probably a couple others), the traditional "tank steering" drive has won every event. Although, this may be (at least in part) a bi-product of the vastly higher quantity of these drives.
Becuase now with all the power being put into drivetrains you need a solid way of connecting with the floor... high traction wheels and power will get you far in any years game.
Unread 18-03-2007, 14:49
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I must say we are very happy with our 6 wheel drive system using 2" wide colsons and andymark 2 speed transmissions. We haven't been out-pushed yet after 2 regionals. and we haven't had a single problem with it yet.
Mentor 2415
Unread 18-03-2007, 15:13
AdamHeard's Avatar
Lead Mentor
Originally Posted by Joel J. View Post
I don't think they are using bumpers, and I think they are in the 110 lb weight class. So, they are at about 124lbs, with battery (maximum). I also read something about them weighing about 85lbs, because they were planning on adding ramps. If they didn't add weight to get to 110lbs, then they are really scrawny at 100lbs, with battery. That hurts their pushing power. 100*1.3 is equivalent to 150*.867, about the amount of traction advantage a full-weighted 4ft class robot would have with something even less grippy than the old wheelchair wheels that were in the kit. They have the torque, and they have the treads, but they are lacking the weight.
Do the old wheelchair wheels realyl have that much traction? The new AM wheels are 1.0-1.1 and they seem to have a lot more traction than the skyways...
And to contribute to the post; At LA we ran two small CIMs on each side to 1.2 cof wheels in a 6 wheel drive. We weren't traction limited and had a 9-10 fps top speed. For San Diego, we are probably switching to a small CIM, a large and a FP (modularity and CNCs = awesome) which will give us the same speed, but we will be traction limited so we we'll be able to push a lot better.
Unread 18-03-2007, 23:03
ScoutingNerd175's Avatar
ScoutingNerd175 ScoutingNerd175 is offline
Scouting Away
AKA: Caroline Marr
FRC #0175 (Buzz Robotics)
ScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud of
Send a message via AIM to ScoutingNerd175
Originally Posted by teenmisfit View Post
Personally i find 175 drivetrain to be wonderful. It isnt new but every year it helps them do wonderful. They use 2 drivetrains. One is the normal bot 6 wheel 4cim drivetrain and then they have another drivetrain mounted sideways underneath the chassis on pneumatic pistons. When this drive train pops down it enables them to physically move sideways.
Buzz's lateral drive is actually new this year. We have used the 6 wheel drive before (more than once), but not the lateral.
I hadn't seen any regionals in person this year, and it is very different watching the video feed where you cannot see the whole match. But I was at UTC this weekend, and I certainly came away with the impression that a strong drive train is very important this year. (last year as well, of course) It has certainly been important in other years, but this year there are many many ramp bots who don't score until the end of the match, and they play very strong defense during the rest of the match. I've seen really good and innovative scorers be shut down by great defensive bots. The scorers with stronger drives (and good drivers) are scoring.
Buzz 175 Alumna
University of Michigan, Class of 2012
Syracuse University, Class of 2010
Enrico Fermi High School, Class of 2006
Unread 18-03-2007, 23:15
JSand's Avatar
JSand JSand is offline
Pattycake Patrol
AKA: Josh Sandler
FRC #1848 (Team Soup)
Team Role: Driver
JSand is an unknown quantity at this point
Send a message via AIM to JSand Send a message via MSN to JSand Send a message via Yahoo to JSand
Originally Posted by Adamskiy View Post
There was one crab drive (1057), and one robot had mecanum wheels (I forget the number) with independent suspension.
I forget the team number as well but I saw the mecanum/suspension set up in their pits and it was impressive looking.
2007 Peachtree Regional Champions (Thanks 1127, 1369, and 1539)
2008 Peachtree Regional Imagery Award
Unread 18-03-2007, 23:21
RobJ RobJ is offline
FRC #0254 (Cheesy Poofs)
RobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of light
Lack of pushing power? I think they would be upset if they heard that...
They have a 5fps/16fps (or 6/15 I forget...). The high gear is very fast, and the low gear is putting out a significant amount of torque, probably just around traction limited knowing them (which is a lot, using gum rubber roughtop tread... which is about the highest coefficient of friction you can legally get for wheels). So, I'd say they can push if they need to; They're just too busy scoring.
It is 5 in low and 15 to 16 in high. The first statement was true about us not having much pushing power as we weighed in at about 90 pounds at each event since we did not have ramps.
Unread 19-03-2007, 15:34
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
That was ours, team 1379. It works great, you can drive over a 1x4 with it! Perfect for driving over field debris.
I will ask Matt to post some pictures of it when we get the robot back this week.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 19-03-2007, 18:35
Carpe_Noctem's Avatar
Carpe_Noctem Carpe_Noctem is offline
Carpe Noctem--Seize The Night!
AKA: Jordan Frost
FRC #1057 (Blue Knights)
Carpe_Noctem is an unknown quantity at this point
Our crab drive made getting aligned to ramps alot easier...
a lot of robots had to get running starts to make it up some ramps.
GO KNIGHTS!!!--TEAM 1057
Knifir un Skolir Waise Edoc'sil!
-The Sword and the Shield be Unconquerable!
Unread 19-03-2007, 19:25
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Team 703 took a deviation from our normal tank drive system and came up with a new powerhouse drivetrain....
14 WHEEL TANK DRIVE!!!!!
No joke either,
For more info, see This link, and This other link
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 19-03-2007, 22:39
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
At the Silicon Valley Regional, I saw a few teams with omnidrive wheels (two, three teams maybe), only noticed one team with Mecanums, and a lot of 4 or 6-wheel tank drive systems. A few rocker chassis, too. I know teams 100 and 254 were running rocker chassis setups.
675 ran a 4-wheel tank drive setup with one CIM+Gearbox per motor.
We also saw one or two teams with authentic tank tread setups, I know 670 (Homestead Robotics, HRT) ran tank treads.
I forget the number of the team, but I saw a mecanum-bot going sideways at the practice area at San Jose and it was really cool looking -- now I want to build a bot with Mecanums.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 02-04-2007, 19:50
Jared Russell's Avatar
Taking a year (mostly) off
We (341) used four AM Plastic Omniwheels this year. At Jersey, they were arranged in a diamond (kiwi style). However, we had bad slippage and controllability issues with this configuration.
For Chesapeake and Philly, we re-oriented the wheels a bit. The front left and rear right wheels go forwards/backwards, and the other two go left/right. This allows for:
1. Stability from all four corners of the robot.
2. Higher straight line speed in the principal axes than either kiwi or mecanum drives of the same gearing.
3. Mechanically straight driving. Try getting a kiwi bot driving straight without slippage or sluggish response, even with encoders and gyros! (We did, we failed, and then we changed it).
The drive is still holonomic, but way easier to control and operate in this configuration.
I also believe that this makes 341 (and I could be wrong about this) the only regional winner with a true holonomic drivetrain.
Unread 02-04-2007, 20:00
I suspect you mean 1072, Harker Robotics. Unless 1138 was up there. (The two most likely that I can think of, and I know that 1072 was up there.)
Unread 02-04-2007, 20:07
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
We didn't go up to San Jose, so it was probably 1072. I remember seeing a mecanum bot at LA that didn't use the AM wheels. It caught my eye because they used a record as their rotation control. Was that 1072?
We went with the AM wheels. Got the job done, and we had a decent amount of pushing power and controllability.
Unread 02-04-2007, 20:15
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
We, for the first time ever, used a "Sworm" drive. It is, to the best of our knowledge, the first application of a worm gearbox crossed with a crab drive. It has 180* rotation and our driver has done well with it.
I have noticed this year a few crab drives (1 at St Louis, 2 at GTR). There were a few teams using traditional omni-wheels with a diagonal setup (854) and a good number of teams trying out mecanums.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 02-04-2007, 20:26
JohnMorenski's Avatar
JohnMorenski JohnMorenski is offline
AKA: Rusty
FRC #1647 (Iron Devils)
Team Role: Driver
JohnMorenski is an unknown quantity at this point
we've got 2 speed pneumatic AM shifters with custom made direct drive shafts connected to a wheel then the direct wheel has a chain going to another wheel on each side we have a small drive wheelbase in the back with omni wheels in the front for stability
we also had 4 custom 3"wide wheels with an 8" diameter
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Where Are "Chassis & Drive Train Instructions" Robeaux Kit & Additional Hardware 1 10-01-2006 16:17
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Drive Train Thunder360 Motors 5 21-03-2003 20:41
