Re: pic: Team 1501 Lifting Teams 45 and 1990
have a picture of your elim alliance for boiler?
1501, that bot was amazing. I couldn't help but stand and stare at it in your pit on Saturday. Any idea how much it can lift? Also, I'm curious as to how exactly you built it- even after power was cut off, it was still going up. How'd y'all do it?
JH |
The mechcanial team says it can lift around 500 lbs. 480 lbs to be exact. It uses two air cylinders, and two gas springs with a 100 lbs rating. We use compressed air to compress the gas shocks down, and hold them down. The lifting after power is cut is EASY....we use a double soleniod valve. The SMC one comes in the KOP. When the spool shifts in a double soleniod valve, the air changes state and keeps on lifting even after the electrical is cut from the soleniod on a double valve. We used chrome moly tubing that was welded by a student and a mentor. It's the same tubing they build landing gears for airplanes and race care chassis. It's very strong. The whole frame only weighs I think around 34 lbs if I remember right. Each wing is moncoque and weighs about 11 lbs or so I think. I can't quite remember what the mechcanial team said so don't quote me on it. |
| pic: Team 1501 Daddy-Daughter | Chris_Elston | Extra Discussion | 5 | 06-04-2007 23:22 |
| pic: Team 1501 finished robot | Wayne Doenges | Robot Showcase | 11 | 31-03-2006 20:02 |
| pic: Team 1501 Real Deal | Wayne Doenges | Robot Showcase | 20 | 17-02-2006 01:56 |
| pic: Team 1501 wheels | Wayne Doenges | Robot Showcase | 13 | 13-02-2006 05:34 |
| pic: Team 1501 Tranny | Wayne Doenges | Robot Showcase | 8 | 19-02-2005 02:52 |
