Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 17-03-2007, 22:35
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Programming jokes
[not really a joke, but you might appreciate this]
I never could figure out why my auton never worked freshman year; I was just learning C and had written this:
if (counter = 5) {
pwm01 = 254;
pwm02 = 254;
counter = counter + 1;
I told the drive guys that "yeah, it would be fine and work"...needless to say the robot took off and smashed into the other side of the field...[/notajoke]
Insults:
Go put do loops in your slow loop! (crashes the processor)
Go plug your computer into the tether port! (explodes the system board)
I'm working on some more, so I'll probably post again, but there's the ones I've got for now.
End Post (VB reference)
Aren't signatures a bit outdated?
Unread 17-03-2007, 22:54
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
if(1==1)
actNormal();
else
temp = black;
black = white;
white = temp;
temp = up;
up = down;
down = temp;
//correcting for rip in space time
ok heres a good one.
2 programmers are changing a light bulb. programmer #1 takes out the light bulb then programmer #2 puts in the replacement light bulb. As he does this programmer #1 starts to get an angry look on his face . . programmer #2 stops then says " ohh sorry off by one error".
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 17-03-2007, 23:38
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
[To a mentor]
In theory, this fix should work great!
[robot entangles arm in rack at full speed]
Oops.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 17-03-2007, 23:48
Stvn's Avatar
Stvn Stvn is offline
FIRST Competition Competer
AKA: Steven Rhodes
FRC #0100 (WHS/CHS - WildHats)
Stvn is an unknown quantity at this point
Send a message via AIM to Stvn
"We need to save weight. Take out all the white space"
"Just one small change and it will work perfectly."
"That wasn't supposed to do that."
Unread 18-03-2007, 20:02
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
One of our programmers was working for hours on our arm code. He couldn't figure out why it wasn't working. I looked over the code, put it in, turned off the safety switch.... it worked fine.
Thats why you need more then one programmer.
Team 973 : 06-09
Unread 18-03-2007, 20:31
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
My programmers, not that I know the slightest thing about the wonderful world of C, were talking about the code in the kind of tones that implie one intends to rearrange the others face, so I step in. It seems that the first angry one was unsatisfied with out auton. code. The first practice match we dropped the arm and ran at the other alliance full speed like jousting, hit the wall with a sickening crunch and grinds to a halt. The second programmer, the one who made the code, is very confused by its performance, swearing that he made it correctly. They crack open the code and see that infact it is an open ended code with no stop to the movement! The replace it with a code that makes it spin in circles.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 18-03-2007, 20:42
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
So after working for an entire day on our team's auton code with no success I had finally made the simplest auton yet: shift to high gear and floor it in reverse. At the start of the match the robot turns a complete circle then hits the alliance wall and stops. The entire team shooting me angry glances I hurry to the pits to find the error. One mentor in particular states that the robot must have functioned properly and it was my(the caode's) fault. When the robot comes back the mentor takes one look at the transmission, swears, and apologizes. And just once I could say, "I told you so!"
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 18-03-2007, 20:51
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Coffeeism View Post
The robot's too heavy, take out some code.
Originally Posted by mtaman02 View Post
Everything on this robot needs to lose weight, I don't care what you gotta do to get it off just lose the weight, start with the code and work your way back to the hardware.
We actually had one parent who was told stuff like this and completely believed it. Actually, (person) believed that only the ones weighed something, the zeros had no weight. Of course, the lead programmer then showed the parent that I was wrong, only the zeros had weight, not the ones...
True.
Don
Unread 18-03-2007, 20:55
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
dy/dx = robot go foward
The programmer's all found that humorous. I found it as a scary nightmare.
'07 FLR Rookie All-Stars
'07 FLR Highest Rookie Seed
Unread 18-03-2007, 21:05
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
some kid dropped an old sensor in some salsa... and i just laughed.
it is also quite humorous to define aliases for the IFI functions...
putdata -> cheese
getdata -> explode
autonomous_mode -> special_mode_to_run_annoying_drivers_over
only a programmer would do this, i suppose
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 18-03-2007, 21:10
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
I dropped our label maker in a bowl of Red Beans and Rice. The amazing part is that I got it working after diner like it was new!
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 18-03-2007, 21:38
Athleticgirl389's Avatar
Athleticgirl389 Athleticgirl389 is offline
I Am The Robot
AKA: Ashley Marshall Aka Sharpie
FRC #0102 (Gearheads)
Athleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond repute
Send a message via AIM to Athleticgirl389 Send a message via MSN to Athleticgirl389 Send a message via Yahoo to Athleticgirl389
Our team used that A LOT this year lol. Also, "Nope, we're still over weight... put in the lighter code.'"
2010: New Jersey Regional Quarter Finalist, J&J Gracious Professionalism Award. Connecticut Regional Champions (With 1124 & 383)
2009: New Jersey Regional Quarter Finalist. SBPLI Long Island Semi-Finalist, Motorola Quality Award. Newton Division Semi-Finalist (2970 & 33), BR^2 Champion (With 2793 & 136) & Highest Scoring Match Award
2008: New Jersey Regional Quarter Finalist, Judges Award (Innovative Financial Management). SBPLI Long Island Regional Winner (With 2487 & 2010), Entrepreneurship Award. Fastest Robot In The World
2007: SBPLI Long Island Engineering Inspiration Award Winners
2006: SBPLI Long Island General Motors Industrial Design Award Winners, Brunswick Eruption Champions
2004: New Jersey Regional Motorola Quality Award
2003: J&J Mid-Atlantic Regional Winners
2000: National Finalists
1999: Mid-Atlantic Regional Regional Finalist
Team 102
"Teamwork Is The Fuel That Allows Common People To Accomplish Uncommon Results." - Jeff Gordon
Unread 18-03-2007, 22:11
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
1. This one is probably all too common:
visitor/sponsor/etc: "Hi, John, nice to meet you. I saw the electrica, mechanical, (etc...) teams, where is the rest of the programming team?"
2. The ever popular:
QUICK! Re-enable the disable switch!
3. I was the play-by-play commentator at the state VEX Championship, where, in the finals, I found myself saying:
"That was quite a depressing autonomous period: we just saw four robots sit and waste millions of microprocessor cycles, contributing to organizational entropy in the universe without actually doing any work!"
Half the people laughed because they had no idea, and the other half laughed because they knew exactly what I was saying.
What place are we at? ... TODAI!
Unread 18-03-2007, 23:17
Originally Posted by Andrew Morris View Post
...When the robot comes back the mentor takes one look at the transmission, swears, and apologizes.
Our 2004 'bot developed a transmission issue that only showed up at high speed in reverse with an actual load on the wheels. It wasn't apparent with the robot "up on blocks" in the pit. It happened that our autonomous routine was to go high speed in reverse. It started drifting seriously to one side, but things seemed fine when under operator control. I was the only real programmer on the team at the competition, so it fell to me to correct the problem. I put in some "go straight" code to increase power to the slower side and decrease power to the faster side until the left and right wheel rotation sensors matched. The robot then went straight in autonomous, but only for a foot or two before stopping completely.
It took several disappointing matches and lots of testing on the floor with a very long tether cable before we discovered that the software was doing exactly what we asked it to, and the trouble was with the hardware (a gear was riding up out of place and disengaging with its partner). I think the final clue was when the driver complained about not being able to turn one direction in reverse.
That's about the time I started putting in "defensive diagnostics" so I could easily demonstrate that the code was operating properly, and could quickly determine when undesired operation was due to disconnected wiring or misbehaving mechanisms.
Unread 18-03-2007, 23:24
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
As opposed to the really useful work that the robot does during the rest of the game?
Jacob
Jokes Branden Ghena Chit-Chat 42 14-05-2006 14:06
Arrrr!! It be robot pirate jokes!! superbeano2004 Games/Trivia 21 20-09-2005 09:06
Science jokes..... Adam Y. Chit-Chat 20 10-12-2004 11:55
Practical Jokes & Mr. M Jack Chit-Chat 1 21-04-2003 13:40
FIRST JOKES AntiCrombieDuck Chit-Chat 20 21-02-2002 15:09
