#16
Re: Programming jokes
[not really a joke, but you might appreciate this]
I never could figure out why my auton never worked freshman year; I was just learning C and had written this: Code:
if (counter = 5) {
pwm01 = 254;
pwm02 = 254;
counter = counter + 1;
------------- Insults: Go put do loops in your slow loop! (crashes the processor) Go plug your computer into the tether port! (explodes the system board) I'm working on some more, so I'll probably post again, but there's the ones I've got for now. End Post (VB reference) |
#17
if(1==1)
{ actNormal(); } else { temp = black; black = white; white = temp; temp = up; up = down; down = temp; /*^^^^^^^^^^^^^^^^^*/ //correcting for rip in space time } ok heres a good one. 2 programmers are changing a light bulb. programmer #1 takes out the light bulb then programmer #2 puts in the replacement light bulb. As he does this programmer #1 starts to get an angry look on his face . . programmer #2 stops then says " ohh sorry off by one error". Last edited by Stuart : 17-03-2007 at 23:07. |
#18
[To a mentor]
In theory, this fix should work great! [robot entangles arm in rack at full speed] Oops. ![]() |
#19
"We need to save weight. Take out all the white space"
"Just one small change and it will work perfectly." "That wasn't supposed to do that." |
#20
One of our programmers was working for hours on our arm code. He couldn't figure out why it wasn't working. I looked over the code, put it in, turned off the safety switch.... it worked fine.
Thats why you need more then one programmer. ![]() |
#21
My programmers, not that I know the slightest thing about the wonderful world of C, were talking about the code in the kind of tones that implie one intends to rearrange the others face, so I step in. It seems that the first angry one was unsatisfied with out auton. code. The first practice match we dropped the arm and ran at the other alliance full speed like jousting, hit the wall with a sickening crunch and grinds to a halt. The second programmer, the one who made the code, is very confused by its performance, swearing that he made it correctly. They crack open the code and see that infact it is an open ended code with no stop to the movement!
The replace it with a code that makes it spin in circles. Chris |
#22
So after working for an entire day on our team's auton code with no success I had finally made the simplest auton yet: shift to high gear and floor it in reverse. At the start of the match the robot turns a complete circle then hits the alliance wall and stops. The entire team shooting me angry glances I hurry to the pits to find the error. One mentor in particular states that the robot must have functioned properly and it was my(the caode's) fault. When the robot comes back the mentor takes one look at the transmission, swears, and apologizes. And just once I could say, "I told you so!"
#23
True. Don |
#24
dy/dx = robot go foward
The programmer's all found that humorous. I found it as a scary nightmare. |
#25
some kid dropped an old sensor in some salsa... and i just laughed.
it is also quite humorous to define aliases for the IFI functions... putdata -> cheese getdata -> explode autonomous_mode -> special_mode_to_run_annoying_drivers_over only a programmer would do this, i suppose Last edited by Uberbots : 18-03-2007 at 23:54. |
#26
I dropped our label maker in a bowl of Red Beans and Rice. The amazing part is that I got it working after diner like it was new!
#27
Our team used that A LOT this year lol. Also, "Nope, we're still over weight... put in the lighter code.'"
#28
1. This one is probably all too common:
visitor/sponsor/etc: "Hi, John, nice to meet you. I saw the electrica, mechanical, (etc...) teams, where is the rest of the programming team?" 2. The ever popular: QUICK! Re-enable the disable switch! 3. I was the play-by-play commentator at the state VEX Championship, where, in the finals, I found myself saying: "That was quite a depressing autonomous period: we just saw four robots sit and waste millions of microprocessor cycles, contributing to organizational entropy in the universe without actually doing any work!" Half the people laughed because they had no idea, and the other half laughed because they knew exactly what I was saying. |
#29
It took several disappointing matches and lots of testing on the floor with a very long tether cable before we discovered that the software was doing exactly what we asked it to, and the trouble was with the hardware (a gear was riding up out of place and disengaging with its partner). I think the final clue was when the driver complained about not being able to turn one direction in reverse. That's about the time I started putting in "defensive diagnostics" so I could easily demonstrate that the code was operating properly, and could quickly determine when undesired operation was due to disconnected wiring or misbehaving mechanisms. |
#30
![]() Jacob |
| Jokes | Branden Ghena | Chit-Chat | 42 | 14-05-2006 14:06 |
| Arrrr!! It be robot pirate jokes!! | superbeano2004 | Games/Trivia | 21 | 20-09-2005 09:06 |
| Science jokes..... | Adam Y. | Chit-Chat | 20 | 10-12-2004 11:55 |
| Practical Jokes & Mr. M | Jack | Chit-Chat | 1 | 21-04-2003 13:40 |
| FIRST JOKES | AntiCrombieDuck | Chit-Chat | 20 | 21-02-2002 15:09 |
