Go to Post It is a difficult balancing act - we're engineers because we like to solve problems, and to take a step back and let someone else solve it, with what may be a poorer solution, is darn hard. - DonRotolo [more]
Unread 19-03-2007, 12:59
Adam Schuman's Avatar
Adam Schuman Adam Schuman is offline
Schubox
AKA: Schubox
FRC #0357 (Royal Assault)
Adam Schuman is an unknown quantity at this point
Code For Mecanum Wheels
I thought it was about time that Team 357 posted some of their control mixing code for Jester Drive. So here goes...
void JesterDrive(signed int JOYX, signed int JOYY, signed int JOYZ)
char reduction_factor = 3;
if (JOYX == 0)
reduction_factor--;
if (JOYY == 0)
reduction_factor--;
if (JOYZ == 0)
reduction_factor--;
else
if(reduction_factor == 0)
LF = 0;
LR = 0;
RF = 0;
RR = 0;
return;
else
LF_X = JOYX /reduction_factor;
LF_Y = JOYY /reduction_factor;
LF_Z = JOYZ /reduction_factor;
RR_X = LF_X;
RF_X = -LF_X;
LR_X = -LF_X;
LR_Y = RF_Y = RR_Y = LF_Y;
RR_Z = -LF_Z;
RF_Z = -LF_Z;
LR_Z = LF_Z;
LF = (LF_X + LF_Y + LF_Z);
LR = (LR_X + LR_Y + LR_Z);
RF = (RF_X + RF_Y + RF_Z);
RR = (RR_X + RR_Y + RR_Z);
And thats about it! In order for this code to work there are several things that still need to be done...
1) Check and verify that there is no under or over flow. This means that the values for LF, LR, RF, RR must be in the range of -127 to +127.
2) Be very careful with the signed vs. unsigned numbers. Data from the OI
is unsigned data with a 127 center value and must be converted with a simple algorithm to signed data with a 0 center value.
ie. JOYX = p2_x - 127;
3) Same as number two but backwards. Data from this JesterDrive function needs to be converted back into appropriate values for output to the victors.
ie. pwm01 = LF + 127;
4) Don't forget joystick deadbands.... They help.
Also, there are some nifty simple filters to protect the motors and gearboxes but this post is too long already. I'll post it if someone asks. Team 357 Royal Assault uses the chicklet and a 3 axis joystick FYI. And if you haven't figured it out already the JesterDrive function yields complete holonomic drive capabilities.
GOOD LUCK to all... Feel free to use the code just make sure whenever borrowing any body's code to give credit where credit is due.
Unread 19-03-2007, 16:26
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: Code For Mecanum Wheels
thank you. im hoping that my team will build a mecanum drive soon and having the code really helps.
also im assuming the x and y axises are for translating and the z axis is for rotating....am i correct?
thanks
/forest
Unread 19-03-2007, 22:42
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
If you mind my asking.....what are Mecanum Wheels? It's probably just my lack of vocabulary....
void function(void)
  function();
Unread 19-03-2007, 23:08
Adamskiy's Avatar
Adamskiy Adamskiy is offline
Team Founder
AKA: Brandon Adams
FRC #1261 (RoboLions)
Adamskiy is on a distinguished road
http://www.chiefdelphi.com/media/photos/tags/mecanum
Depending on what direction you rotate each wheel, they allow you to drive and turn like a normal tank drive, but also to slide/swerve in any direction
Team 1261 - Motorola/Cognex/EMD Software & Peachtree Ridge High School
- 2005 Peachtree Regional Champions
(Thanks 281 and 801)
- 2006 Peachtree Regional Champions (Thanks 1414 and 1057)
- 2006 Peachtree Regional Delphi "Driving Tomorrow's Technology" Award
- 2006 Peachtree Regional Underwriters Laboratories Safety Award
- 2007 Peachtree Regional Innovation In Control Award
(Guitar Hero controller )
- 2007 Peachtree Regional Semi-Finalists (Thanks 1746 and 1057)
Unread 20-03-2007, 16:25
void* Jake;
FRC #1178 (DURT)
Ahhhhhh.....I see.
void function(void)
  function();
Unread 13-02-2008, 22:46
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Could you please explain this code? Ours is a bit uglier (and slower)... I am our team lead for the mechanical aspect of mecanum, but I'm also a bit of a coder (java, but this code is all basic math anyway) so I wrote up our mecanum code. Here is what I have (no rotation in this version):
public static double[] printMotorOutputs(int x, int y)
* When not turning mecanum drive has 2 logical pairs of wheels located at opposite corners.
* One of the pairs runs at a constant speed throughout a quadrant, and is scaled only on the
* basis of magnitude. The other pair of wheels change speed based on angle and magnitude.
int angleDrive, magDrive, ratio;
int absX= x<127 ? -(x-127): (x-127); //make 0-255 into 0-127
int absY = y<127 ? -(y-127)y-127);
//we did the math, this SHOULD fit in 16bit integers,
if(absY<absX)
ratio = (absY<<7)/absX; // calculate ratio, shift to avoid floats
angleDrive = ((176-((48*ratio)>>7))*ratio)>>7; // = (176*x/y)-(48*x^2/y^2) + magic (tan(y/x) approximation)
angleDrive-=127; // shift 0-255 to -127 to 127 for scaling
angleDrive = (angleDrive*absX)>>7; // scale angleDrive * (x/128)
angleDrive+=127; // shift back
magDrive = absX; // (absX/maxValue)*outputRange = (absX/128)/128
else
ratio = (absX<<7)/absY;
angleDrive = 255-(((176-((48*ratio)>>7))*ratio)>>7);
angleDrive-=127;
angleDrive = (angleDrive*absY)>>7;
angleDrive+=127;
magDrive = absY;
double r1, r2, l1, l2;
if(x > 127)
if(y > 127)
//System.out.println("Q1");
r1 = angleDrive;
l2 = angleDrive;
r2 = 127+magDrive;
l1 = 127+magDrive;
else
//System.out.println("Q4");
r1 = 127-magDrive;
l2 = 127-magDrive;
r2 = 255-angleDrive;
l1 = 255-angleDrive;
else
if(y < 127)
//System.out.println("Q3");
r1 = 255-angleDrive;
l2 = 255-angleDrive;
r2 = 127-magDrive;
l1 = 127-magDrive;
else
//System.out.println("Q2");
r1 = 127+magDrive;
l2 = 127+magDrive;
r2 = angleDrive;
l1 = angleDrive;
return new double[] {(r1-127)/127, (l1-127)/127, (r2-127)/127, (l2-127)/127};
the doubles and such are there only because it was integrated with a gui which took a double array, for the real code the doubles were simply replaced with ints. The code is completely commented. It took me a lot of tweaking to make this run fast (yay bit shift). But the code posted looks AMAZINGLY fast, but makes absolutely no sense to me. If you could explain it I would be very grateful.
Unread 14-02-2008, 11:47
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
if(absY<absX)
else
angleDrive-=127;
angleDrive+=127;
magDrive = absY;
if(x > 127)
if(y > 127)
r1 = angleDrive;
l2 = angleDrive;
r2 = 127+magDrive;
l1 = 127+magDrive;
else
r1 = 127-magDrive;
l2 = 127-magDrive;
else
if(y < 127)
r2 = 127-magDrive;
l1 = 127-magDrive;
else
r1 = 127+magDrive;
l2 = 127+magDrive;
r2 = angleDrive;
l1 = angleDrive;
Wow... This is very intense! Are you calculating angles for tracking? My drive coding is really short so I think I may be missing something here. I Scale my inputs with a simple Square of the numbers and then I have ten lines of code that mix x,y,& z.
In a nutshell, what does this code do?
Unread 14-02-2008, 13:32
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Lesman,
The Jester Drive code posted by Adam takes three inputs instead of 2 - strafe (X) , forward/back (Y), and turn (Z), from -127 (full power backwards in that direction) to 127 (full power forwards in that direction). If any particular direction is 0, it ignores it. Otherwise, it takes the power in each direction, and figures out which way each wheel needs to go (for turning, left wheels and right wheels are opposite; for strafing, diagonal pairs of wheels are opposite).
Each wheel gives a diagonal vector when told to move forward or backwards, so you simply combine the vectors to get the direction you want.
The wheels should give output along the following lines:
So, for example,
127 X gives left front and right rear wheels at 127, left rear and right front wheels at -127, which would strafe to the right.
127 Y gives all wheels at 127, which would go forward.
127 Z gives left wheels at -127, right wheels at 127, which would turn left.
The rest of the code simply combines the three directions through addition, then divides by the number of directional inputs you are giving so that the final result goes from -127 to 127. Presumably, the next bit of code adds 127 to make the output an unsigned char (which is what PWMs actually take), and then sets each wheel motor to the respective variable.
Unread 14-02-2008, 14:11
I was trying to program my mechanums and was worried while trying to sleep (when I do my best thinking) and reasoned a couple of things out.
First I needed scale my inputs with one of the table schemes or with a Square or Cubic Function.
but after that I came up with THIS code.
The code for single joystick that we use combines the joystick inputs and gives a resultant. If I just treat those resultants as if they were a single joystick input, I could combine them with the same formula adding the Z or Twist axis. Since the effect of the Z axis goes to different wheels I just needed to re group them... I just realized I can further reduce the last four lines to
pwm15 = pwm16 = Limit_Mix(2000 + pwm16 + p1_wheel - 127);
pwm13 = pwm14 = Limit_Mix(2000 + pwm14 - p1_wheel + 127);
and eliminate the interim values to make it a four line code,
But I wanted to give you the code as I'm actually using it.
I need to clean up my code.
The wheels are configured :
LF is pwm13 RF is pwm14
LR is pwm15 RR is pwm16
I think this is the simplest way to implement Mechanums. Since I'm not proficient enough to read everyone
else's code, I hope all this is in line with what you guys are saying.
Steve
 pwm13 = pwm16 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm15 = pwm14 = Limit_Mix(2000 + p1_y - p1_x + 127);
  intpwm13 = pwm13;    // set to interim variable to do the twist calculation
  intpwm14 = pwm14;    // I originally set this up for debugging purposes but
  intpwm15 = pwm15;    // this is actually an unnecessary step.  SO I can
  intpwm16 = pwm16;    // eliminate these four lines by just using the  values
                                 // to define themselves as mentioned in the post
pwm16 = Limit_Mix(2000 + intpwm16 + p1_wheel - 127); //These can be shortened but I was in a hurry and
pwm15 = Limit_Mix(2000 + intpwm15 + p1_wheel - 127); // I'm not really a programmer anyway.
pwm14 = Limit_Mix(2000 + intpwm14 - p1_wheel + 127);
pwm13 = Limit_Mix(2000 + intpwm13 - p1_wheel + 127);
(footnote... I believe I can combine everything to this:
pwm13 = pwm16 = Limit_Mix(2000 + p1_y + p1_x - 127); //Combines X & Y Axis
pwm15 = pwm16 = Limit_Mix(2000 + pwm16 + p1_wheel - 127);//Combines Z Axis with previously
pwm13 = pwm14 = Limit_Mix(2000 + pwm14 - p1_wheel + 127);//calculated X & Y Axis
I'll test it later today and let you know.
Steve )
Addendum
OK final code is
pwm15 = Limit_Mix(2000 + pwm15 + p1_wheel - 127);
pwm13 = Limit_Mix(2000 + pwm13 - p1_wheel + 127);
Unread 14-02-2008, 17:02
Lesman's Avatar
Ok. Here is a rundown on how my code works. It is based on one major assumption: the motor outputs depend linearly on the angle of the movement (also magnitude but that is obvious). So the simple psuedocode for the first quadrant, that does not take into account magnitude, would look like this (using degrees):
(int joyX, int joyY) from 0 to 255
x = absolute val: joyX-127
y = absolute val: joyY-127
pair1 = (arctan(y/x) / 90)*255-127;
pair2 = 255;
Basically, one pair is always full forward of full backward (depending on the quadrant). The other pair of wheels goes from full forward, to full backward throughout the quadrant. For example: going forward all motors go forward, going right one pair goes forward the other goes backward, and at 45 degrees the same pair still goes forward and the other just idles.
Then you want to scale back based on distance. I found that the best way to do this was to figure out the maximum possible value on one axis, and then create a scaling ration which was equal to actual/maximumPos, and applied this to all of the motors. The maximum value for a give axis is always 127 (this is from -127 to 127) the deviding my maximunPos can be replaced by a 7 bit shift. You want to use the x axis if you are at less that 45 degrees, and y axis for more than 45 degrees, thus:
if(y<x) //that would be less than 45 degrees
multiply all values by x and bit shift 7
else
multiply all values by y and bit shift 7
So that is now scaled for distance. The last major step is replacing arctan (because it doesn't exist). With the help of excel I made an approximation of arctan(y/x)/90*127. It looks like this:
which is equivalent to:
ratio= (absY << 7) / absX
((176 - ((48 * ratio) >> 7)) * ratio) >> 7
except loads faster. Unfortunately a simple approximation like that can't do the entire arctan domain, it only does up to 45. This is where it gets nifty. An angle over 45 can be calculated by reflecting across the y=x axis (ie, flipping the x and y) and the subtracting that from 90. So the final code looks like this:
int absX= x < 127 ? -(x - 127) : (x - 127); // make 0-255 into 0-127
int absY= y < 127 ? -(y - 127) : (y - 127);
// we did the math, this SHOULD fit in 16bit integers,
if(absY < absX)
ratio= (absY << 7) / absX; // calculate ratio, shift to avoid
// floats
angleDrive= ((176 - ((48 * ratio) >> 7)) * ratio) >> 7; // =
// (176*x/y)-(48*x^2/y^2)
// + magic
angleDrive-= 127; // shift 0-255 to -127 to 127 for scaling
angleDrive= (angleDrive * absX) >> 7; // scale angleDrive *
// (x/128)
angleDrive+= 127; // shift back
magDrive= absX; // (absX/maxValue)*outputRange = (absX/128)/128
else
ratio= (absX << 7) / absY;
angleDrive= 255 - (((176 - ((48 * ratio) >> 7)) * ratio) >> 7);
angleDrive-= 127;
angleDrive= (angleDrive * absY) >> 7;
angleDrive+= 127;
magDrive= absY;
The end.
Also! I added my original method, and jesterDrive to my gui. It shows a little gui, move the mouse around the square (or circle) to simulate the joystick. The four little graphics are the four motor outputs. To change the calculation method hit the following keys:
j for jesterDrive
o for originalMecanum
m for my final mecanum code
http://www.badongo.com/file/7796058
It is in java, packaged with complete source. I noticed that jesterDrive behaves funny, specifically, since it devides by the number of used inputs, y = 255 and x = 127 produces a significantly different result than y = 255 and x = 128.
Wow, that was long.
Unread 17-02-2008, 12:19
jacobhurwitz jacobhurwitz is offline
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
See this thread for an explanation of some mecanum drive code:
http://www.chiefdelphi.com/forums/sh...ad.php?t=61482
The thread doesn't give any actual code, but it nicely (and simply) describes how it should work.
Unread 17-02-2008, 14:02
JonA's Avatar
JonA JonA is offline
Embedded Firmware Engineer
no team (Semi-Retired)
JonA has a spectacular aura aboutJonA has a spectacular aura about
Controlling any holonomic-omnidirectional drive system is the same whether it is any number of omni-wheels or mecanum-wheels. The output of the motors are related by a sin curve. Phase shifting the sin curve by the desired heading results in the proper motor outputs for each of the wheels.
Having had a mecanum drive the last two years, we have attempted a number of control algorithms and have settled on this one. Please note that this algorithm takes advantage of Binary-Radians (256 b-rads per revolution) to simplify the trig math.
I hope that you find this useful in your attempts to control your onmi bot.
"That mecanum guy"
- Woodie Flowers Finalist Award Winner: 2010 Minnesota North Star Regional
- Mentor and Founder of 7 FRC Teams since 2003.
- FRC Regional Competition Score Keeper/Field Power Controller, Robot Inspector, Control System Adviser, Judge
- Co-Founder, Alumni: Milwaukee FIRST Support Organization
- Board Member, Game Design Committee, Judge, MVP-FTA: Midwest Vex Programs
- Computer Engineering Alumni '06: MSOE
- Embedded Firmware Engineer: Rockwell Automation
Last edited by JonA : 17-02-2008 at 14:09. Reason: There are 256 b-rads in a revolution as zero is a number too.
Unread 17-02-2008, 14:32
Lesman's Avatar
Which way is more 'correct'
Basically, my method calculates the angle of motion, and uses that to generate motor outputs. Then scales everything back based on the magnitude of the motion. Afterwards it adds the rotation by simply adding the z axis to the four motor outputs, and then, if necessary, scales them back to fit in 0-255.
The other methods I have seen appropriately add up all the x,y,z inputs and and then, one way or another, scale it back to fit into 0-255 (some do it better than others).
Which of these methods produce a more desirable result (ignoring code complexity and execution time)? I personally feel that my method is more 'correct'. For example: sliding at a 45 degree angle at full magnitude is not full forward + full sideways, as that would result in root(2) magnitude (on a scale of -1 to 1) in that direction, which is obviously not possible. As opposed to my code, which handles angles, and always outputs an appropriate magnitude.
I'm no expert, but that's just my gut feeling.
Unread 17-02-2008, 15:26
Without considering complexity and execution time I would say without a doubt your method is superior in that it is mathematically most correct. This would, to me, lend itself better to creating a virtual model of the motions involved in a computer or PDA display. It's a well organized and logical method for defining the motor speeds and motions.
That being said, if your code and a simpler code both give the desired results I'm not sure the word "correct" can apply. Both work so both would be "correct" but I personally admire the work and math you've applied in this problem. I just am not the brightest bulb in the hallway so I must be content with a lesser solution. (Ask me about cooking instead... I have a killer cheesecake recipe that's REALLY correct!)
Steve
Unread 17-02-2008, 15:46
JonA's Avatar
Well, neither method is more correct. The only true measures are of usability, controllability and accuracy. You can look at all sorts of data and generate all sorts of graphs and you could probably choose variations on algorithms that allow the most control and accuracy at a given range of speeds. In the end, it comes down to "does it do what you need it to do?"
Here is one easy way to look at it:
Usability is usually subjective. This includes how complicated it is for the driver to drive and, perhaps, how complicated it is for the programmers to write.
Controllability is closely tied to usability but focuses more on consistency. (ie: when I put the stick in this position, will it do the same thing?)
Accuracy is more objective and measurable. (ie: when I put my stick at 45 degrees, does the robot travel at 45 degrees?)
...sliding at a 45 degree angle at full magnitude is not full forward + full sideways, as that would result in root(2) magnitude (on a scale of -1 to 1) in that direction, which is obviously not possible.
In the end, for controllability and usability, it is usually best to limit the maximum speed in any heading to be the same. Just because you can you can drive faster in the forward direction as opposed to 45 degrees does not mean you should as when you start to turn, your speed is not proportional.
"That mecanum guy"
Mecanum wheels akash155 General Forum 12 20-02-2007 22:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Looking for Mecanum Wheels Armando Gonzalez General Forum 30 24-05-2006 12:54
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mixing Joystick Values for mecanum wheels Leav Programming 10 15-01-2006 14:51
