Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 19-03-2007, 17:18
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: The 2007 Team 703 Phoenix Robot
Better late then never I suppose. Here is our 2007 Robot.
The image in the top left shows a view of our 14 wheel drive and our Carbon Fiber "Riser".
In the top right is an image of our arm mock-up (I didn't have any good shots of our finished arm but it's basically the same only made out of lexan and aluminum).
The bottom left image shows our robot with ramps in the starting configuration just before we shipped the robot.
And finally the image on the bottom right shows our ramps fully deployed (Not all of the side rails were installed when the picture was taken).
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
pic: Team 968 - 2007 Robot Travis Covington Extra Discussion 16 06-03-2007 20:10
pic: Team 1345's 2007 Robot, The Condor. Arefin Bari Robot Showcase 22 23-02-2007 20:18
pic: Team Phoenix - 703 at Buckeye MattB703 Extra Discussion 1 03-04-2006 15:57
pic: Team 703 Phoenix POLISH703 Robot Showcase 6 07-03-2005 12:39
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 16-02-2005 14:34
