Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
Unread 03-19-2007, 05:17 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
pic: The 2007 Team 703 Phoenix Robot
Unread 03-19-2007, 05:18 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: The 2007 Team 703 Phoenix Robot
Better late then never I suppose. Here is our 2007 Robot.
The image in the top left shows a view of our 14 wheel drive and our Carbon Fiber "Riser".
In the top right is an image of our arm mock-up (I didn't have any good shots of our finished arm but it's basically the same only made out of lexan and aluminum).
The bottom left image shows our robot with ramps in the starting configuration just before we shipped the robot.
And finally the image on the bottom right shows our ramps fully deployed (Not all of the side rails were installed when the picture was taken).
Unread 03-19-2007, 05:22 PM
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
I have always liked 703's drive train and design sensibilities in general...keep up the good work! I was trying to get 461 to use carbon fiber/nomex panel for the ramps but it didn't work out.
What is the "sandwiched" material in your panels? Nomex? Aluminum? Something else?
Unread 03-19-2007, 05:28 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Thanks, we're very proud of our drive train this year. Our goal was to fix the issues we had had with our tracks breaking in previous years robots, so instead of dealing with all the belts, we just came up with this. It simulates many of the advantages of a tread system and adds the reliability of gears and wheels.
We used Divinycell foam for the sandwiched material as it had much more compression strength than typical Styrofoam but was still very lightweight.
Unread 03-19-2007, 06:09 PM
EricH EricH is online now
That bottom left one better have the ramps slightly out of starting position, or you've got some work at your first event. (If the ramp on the right is in the box, that's an awfully small robot.)
How do you deploy the ramps? Did you keep the arm (I can't see it in the bottom two pictures)?
Unread 03-19-2007, 06:15 PM
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Are your wheels in a gentle "U" shape? My team is trying to perfect our drive train for next year so we are looking around. Would you recomend this?
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 03-19-2007, 06:19 PM
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
sup defensive POWERHOUSE haha. I really enojoyed getting pushed around the rack by that at Detroit
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 03-19-2007, 06:22 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Yeh, we solved that problem by pulling the ramps in so they fit square inside the starting configuration, We just didn't have the cables attached in that picture.
The ramps get deployed by being retracted up and to the center of the robot by our winch system to a point where they are no longer restricted by the bumpers, our spring hinges then take care of popping them out and we then reverse the winch to allow them to slide out.
It isn't the fastest process (takes about 5-7 seconds to deploy fully) and we had a few issues with it in Detroit which we believe we have addressed (deploying early, getting stuck, ect.).
We did not attach the arm in Detroit, we knew we had to make an new mast for it after we shipped it in order to make weight at the regionals and because the gearing needed to be ajusted, we just never got the time to attach the new mast in Detroit due to all the troubleshooting we did with the ramps.
I'm hoping we can get it on for West Michigan, if not, expect to see it at least once or twice at Nationals.
Chris
Yes, the whole thing is actually in a huge ark. I couldn't tell you the angle right off hand, but its REALLY big. The best part is that the whole thing turns smoothly on a dime!
Kati_Kat's Avatar
Kati_Kat Kati_Kat is offline
Public Relations Girl
AKA: Kati
FRC #0703 (Phoenix)
Team Role: Communications
Kati_Kat is on a distinguished road
Send a message via AIM to Kati_Kat Send a message via MSN to Kati_Kat
God, I love our robot. It was amazing in action at Detroit.
Phoenix 703
* 2005 Kettering Kickoff Champions
* 2006 Kettering Kickoff Champions
* 2007 Detroit Regional Sportsmanship Award Winners
* 2007 West Michigan Regional Champions
Unread 03-19-2007, 07:16 PM
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
That drivetrain is a beast.
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 03-19-2007, 07:17 PM
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
about time i see a picture of this robot! Now let's see some video!
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 03-19-2007, 07:19 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
I didn't have a video camera there and our team videographer couldn't make it, though I think a few members did take some video so I'll have to ask around a bit to find some.
Unread 03-19-2007, 07:54 PM
POLISH703's Avatar
POLISH703 POLISH703 is offline
The special mentor on the team.
AKA: Joe
FRC #0703 (Phoenix)
POLISH703 has a spectacular aura aboutPOLISH703 has a spectacular aura about
Send a message via AIM to POLISH703
Wow, a picture of us. Glad you posted it. Nice work Chris.
Fear the Fro!
Unread 03-19-2007, 10:15 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Yeh, I figure since we've been to a regional now there's no sense in keeping it a secret any longer.
Unread 03-20-2007, 12:08 AM
TrippyMohan's Avatar
TrippyMohan TrippyMohan is offline
Sweetness
AKA: Jake
FRC #0573 (MechWarriors)
TrippyMohan is on a distinguished road
Send a message via AIM to TrippyMohan Send a message via MSN to TrippyMohan Send a message via Yahoo to TrippyMohan
Very clean. I like it.
email me?
pic: Team 968 - 2007 Robot Travis Covington Extra Discussion 16 03-06-2007 08:10 PM
pic: Team 1345's 2007 Robot, The Condor. Arefin Bari Robot Showcase 22 02-23-2007 08:18 PM
pic: Team Phoenix - 703 at Buckeye MattB703 Extra Discussion 1 04-03-2006 03:57 PM
pic: Team 703 Phoenix POLISH703 Robot Showcase 6 03-07-2005 12:39 PM
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 02-16-2005 02:34 PM
