Go to Post I will gladly be pied if that's something you guys want. I know I have people from the Clarkson FIRST dorm floor who will shell out PLENTY of cash for the chance to pie me in the face! - Libby K [more]
Unread 20-03-2007, 10:59
harriton harriton is offline
harriton is an unknown quantity at this point
Programming a Robotic Arm
How would one go about programming a robotic arm to move up and down more or less autonomously with easy c? no need for a whole code, just the basic process one woudl use is fine. thank you!
Unread 20-03-2007, 11:04
Bharat Nain's Avatar
Re: Programming a Robotic Arm
Are you using any sensors? I would use a potentiometer and limit switches if needed.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 20-03-2007, 12:17
I could use sensors, if I needed to.
Unread 20-03-2007, 12:42
If you want the arm to move autonomously, you most certainly need to use sensors.
The simplest way to do it is to use a potentiometer to give an indication of where the arm is pointing, and drive the arm's motor in the appropriate direction until the feedback from the pot matches what you want it to be. If the arm has significant inertia or presents a dynamic load due to weight, you'll want to get fancier and use a PID control system (look it up).
Dean Kamen's..... ROBOTIC ARM? Joe Matt Dean Kamen's Inventions 15 24-02-2010 08:47
OWI Robotic Arm cvhsrobotics Technical Discussion 2 18-01-2005 00:34
Robotic arm joints Collmandoman Technical Discussion 2 17-01-2005 23:23
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
