Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
  #61   Spotlight this post!
Unread 09-03-2007, 10:40
JonA's Avatar
JonA JonA is offline
Embedded Firmware Engineer
no team (Semi-Retired)
JonA has a spectacular aura aboutJonA has a spectacular aura about
Re: Programming tricks (and former trade secrets)
Pro-Tip: Don't use 255 as a full forward value.
With stop at 127, there are 127 effective negative numbers (0-126) and 128 effective positive numbers (128-255). Enforcing 254 as the maximum forward value allows you to easily change the sign of the number (254-n) by using the 8 bit number circle.
Pro-Tip: Use object oriented design. (And implement it that way)
Objects allow you to divide up your code based on things in real life instead of what the processor can do. It also is the easiest way to do abstraction, encapsulation and modularity in C. Even though the language (C) does not natively support objects, there are many ways to implement objects. My preferred way is to define a typedef structure with all of the members/attributes in the class and then implement functions that are prefixed with the class name that take in a pointer to the class structure. To get encapsulation put public function definitions in the header file and private function definitions in the c file.
"That mecanum guy"
- Woodie Flowers Finalist Award Winner: 2010 Minnesota North Star Regional
- Mentor and Founder of 7 FRC Teams since 2003.
- FRC Regional Competition Score Keeper/Field Power Controller, Robot Inspector, Control System Adviser, Judge
- Co-Founder, Alumni: Milwaukee FIRST Support Organization
- Board Member, Game Design Committee, Judge, MVP-FTA: Midwest Vex Programs
- Computer Engineering Alumni '06: MSOE
- Embedded Firmware Engineer: Rockwell Automation
  #62   Spotlight this post!
Unread 09-03-2007, 13:39
Snappel328's Avatar
Snappel328 Snappel328 is offline
Programmer
AKA: Chris Reins
FRC #1746 (Forsyth Alliance)
Snappel328 will become famous soon enough
Well, this year we made whole different .c and .h files for every part on our robot.
Arm.c
Grabber.c
Lifter.c
Drive.c
I don't know how obvious this is to anyone else, but it got quite confusing last year when we kept typing all our code in userroutines.c
2006 Peachtree Regional Rookie All-Stars
2006 Championship Imagery Award Winners
2007 Peachtree Regional Imagery Award Winners
  #63   Spotlight this post!
Unread 09-03-2007, 16:14
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Blame it on hardware.
Behold the power of SPAM.
  #64   Spotlight this post!
Unread 12-03-2007, 00:04
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Quite the tempting idea when, on my team at least, anyone who's not involved with programming immediately says "Blame the programmers" when something doesn't work...
One of the cool things my team did this year was use VNC when teaching the rookie programmers. As one of the experienced programmers worked on the code, the rookies could follow along by connecting to the computer remotely.
Which badges can you claim?
  #65   Spotlight this post!
Unread 14-03-2007, 07:37
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
The shop was riding us pretty hard, even on stuff that was obviously their problem. I think they slowed down (but not totally stopped) when I started replying "I'll get right on it."....
"Aw gee, the arm broke again -- must be a programming error."
"I'll get right on it!"
"Pneumatics tube popped out -- programming error!"
They do not want me touching anything but a keyboard....
They also slowed down when I got their #@$$^% robot to actually work
  #66   Spotlight this post!
Unread 20-03-2007, 17:27
♥♣♠♪'s Avatar
♥♣♠♪ ♥♣♠♪ is offline
DemiOmniGod
FRC #1546 (Chaos Inc.)
♥♣♠♪ will become famous soon enough
Originally Posted by meatmanek View Post
Our team uses an 'abstraction layer' which consists of a bunch of global variables and two functions: abstractIn() and abstractOut().
The global variables are things like driveLeft, driveRight, joyL, joyR, etc.
Our abstraction code takes renaming it one step farther. Rather than using the 0-255 scale where 127 means stop, we shift it down 128 (signed char, rather than unsigned), and we also invert motors where it makes sense. (one side of the drivetrain, any appendages where the motor is 'backwards')
This helps make our code MUCH more readable and configurable, and makes algorithms a bit simpler.
Another trick we did this year was one big state machine for teleoperated mode. In the past, our robot has been nothing more than a glorified remote control car. This year, our robot knows what it's supposed to be doing, with a set of states for each objective, and so the drivers are freed to think more about the game, rather than the robot.
Our code did the abstractions, but to the point where we had #define unsign(x) ((x)-127-((x)==255))
We #defined all the pwms to things like pwmL, pwmR, pwmA, etc.
The worst was when we needed to use two motors to control the wheels on the left and right. pwmL is #defined as (pwm05=pwm06)
Programming && English !mix
Our website
  #67   Spotlight this post!
Unread 20-03-2007, 22:11
Adamskiy's Avatar
Adamskiy Adamskiy is offline
Team Founder
AKA: Brandon Adams
FRC #1261 (RoboLions)
Adamskiy is on a distinguished road
We did similar to the above quote of meatmanek, but scaled it from -100 to +100....lost some resolution, but it made calculations much more simple. And although we had a tank drive, we set the left thumbstick on our Xbox controller to the throttle, and the right thumbstick controlled steering. We did that after picking drivers, as one of them loves Halo and figured it would be more easy for him to control.
For our elevator, the motor that acted as the winch was a small CIM with a BaneBots gearhead/encoder on it, so we used the encoder to have set rack positions (high/med/low) that would be assigned to a single button on the Guitar Hero controller. We then had a limit switch at the bottom (load position) that would reset the encoder count to 0 to account for slight variations that would occur....obviously not the best method, but it was accurate to about an inch, so good enough since we lower the tube onto the rack to score.
Team 1261 - Motorola/Cognex/EMD Software & Peachtree Ridge High School
- 2005 Peachtree Regional Champions
(Thanks 281 and 801)
- 2006 Peachtree Regional Champions (Thanks 1414 and 1057)
- 2006 Peachtree Regional Delphi "Driving Tomorrow's Technology" Award
- 2006 Peachtree Regional Underwriters Laboratories Safety Award
- 2007 Peachtree Regional Innovation In Control Award
(Guitar Hero controller )
- 2007 Peachtree Regional Semi-Finalists (Thanks 1746 and 1057)
  #68   Spotlight this post!
Unread 20-03-2007, 22:31
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
I also wrote sscanf but haven't gotten a chance to use it yet. My stupid state machine based input code works well enough, so I haven't bothered to change the code to use sscanf yet.
It compiles, and it works when I test it on my linux box. Only has %c, %u, and %d at the moment, but it should be pretty easy for someone to add other stuff to it.
http://meatmanek.net/scanf.c
Real programmers use vim.
  #69   Spotlight this post!
Unread 20-03-2007, 22:33
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
I created this: http://www.falconir.com/products.php
After calibrating once at our home practice field, it was literally "set it and forget it". We did not have to recalibrate once at either of the two regionals! It even handled a dim target light on the practice field.
Then we changed our arms out and autonomous broke permanently
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
  #70   Spotlight this post!
Unread 20-03-2007, 23:07
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Whoaa, cool! I do wish that this was open-source, or at least a few more details were included on the website...but good job! I did consider briefly a PC with a webcam onboard--that would be much easier to deal with than a CMUcam...but I'm also starting to lose confidence in the camera module. The lens seems to distort the image horribly, and it's not a defect because it does it on 2 cameras. I don't know as if I'll ever use the CMUcam. Too complicated...
My little bit: stay SIMPLE! And make sure the basics are done first! Autonomous mode does no good if the arm control module doesn't work...I should know, I just got it done yesterday during our last build window before Waterloo. I know I can do much better next year.
JBot
Aren't signatures a bit outdated?
  #71   Spotlight this post!
Unread 20-03-2007, 23:13
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Looks cool, but have you checked out your main open-source competition: the avrcam
http://www.mikesorrenti.com/
  #72   Spotlight this post!
Unread 20-03-2007, 23:15
Eldarion's Avatar
If you want to, you can download the manual from the website. It offers some insight into the basic algorithms involved (adaptive image segmentation is the main one). Another featue is that the system natively uses 320x240 images, and scales the centroids down by two for output purposes. I will probably put a little more detail on the main products page; thanks for the suggestion!
I did not make this open source as I have been working on the algorithms for the past 2 1/2 years, and would like to make a little bit of profit so that I can fund my other vision systems research. It is hard to continue researching with no funds available to test ideas with! Besides, it is written for an FPGA, an FPGA which is pretty much filled up by the code. (1 million logic cells, all in use! )
The OV7620 camera module itself is not a bad module for this kind of work. I have yet to see this distortion you speak of, and I have had the oppertunity to work with 6 different OV7620 modules. Out of curiosity, did you plug both of them (one at a time, of course ) into the same CMUCam board or different CMUCam boards when you noticed the distortion?
-- Thomas Paine
-- Anonymous
  #73   Spotlight this post!
Unread 20-03-2007, 23:20
Eldarion's Avatar
That's interesting, but I think it will be hard to beat the raw processing power of a dedicated FPGA. The FPGA allows me to use 320x240 resolution, over 6 times the resolution of the CMUCam or the avrcam. It does sacrifice speed a little bit, runnig at a little over 6 FPS, but I have found that to be more than adequate. The increased resolution allowed me to stably track the lights from the home zone, (and far beyond it, actually ).
It is hard to go up against an open-source project, though...
-- Thomas Paine
-- Anonymous
  #74   Spotlight this post!
Unread 20-03-2007, 23:35
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I don't mean to be rude, but I took a look at the code you provide and I must say, it's terribly disorganized and disheveled. I find it hard to navigate and poorly commented, it took me and a friend several minutes to figure out what is apparently a timeout reset of the cameras. Your project looks promising, but I think you should polish it up quite a bit more before charging such a hefty sum for it. And I'm not certain but is that full blown development board depicted in your picture actually entirely necessary? Seems like you could design your own hardware to house the device and save some money in removal of unnecessary parts.
Again I don't mean to be rude, and if I'd made a mistake in my conclusions, please forgive me, your site is somewhat sparse on details, I'll happily stand corrected if I am wrong.
Matt Krass
  #75   Spotlight this post!
Unread 20-03-2007, 23:50
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
We have an accerlerating, exponentiating drive code, which means, if you slam the joysticks from center to full forward, the robot, accelerates at an increasing speed.
For controls, we have our "conditional limit" system. operator moves arm, then holds a button, which corresponds to a spider, then stops at that limit and can't move. It can go past all the other limits (except top and bottom of course), but its very convenient. Also, our limit switches were velcro-ed on, to allow for mobility and last-minute-changability.
What else did I do this year? OH YEAH! Those LEDs on the OI....I made them all have a purpose. switch 1/2 - drive forward/back for each side. switch 3/4 - arm up/down and max limit/min limit. relay 1->3 - 3 levels of spiders. Fun times.
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Former FIRST student and mentor dies in a tragic rocket attack in Iraq today. Munkaboo General Forum 48 19-04-2005 12:21
Off-season competetions and former teams Venkatesh Off-Season Events 5 10-12-2004 17:23
Harry Potter and the Chamber of Secrets Ryan Dognaux Chit-Chat 33 01-12-2002 19:57
scouting tips and tricks Rick Scouting 1 08-01-2002 00:52
