Go to Post Don’t get caught in mindsets which will limit the potential that the future may hold. - Jaine Perotti [more]
Unread 20-03-2007, 15:26
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Simple Swerve/Crab
After reading numerous threads and ideas, I had a few questions about swerve and crab drive.
Did anyone use a Banebots gearbox in their swerve assembly this year?
What material is best for making a module? And in what thickness? I noticed some people used Delrin, while others used metal. If you used Delrin, would you need bearings?
What are the advantages to having the modules set up in pairs, as opposed to having one motor control the direction of all 4 wheels?
What size are your modules and how do you have them supported to protect them?
Thanks in advance!
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 20-03-2007, 16:02
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Simple Swerve/Crab
I'm not sure what is "best" really depends on what you are using and how, but last year ours were made from bent 1/8" ours were surrounded by 1X1 square extrustion
module
http://flickr.com/photos/jskowski/91...7594544781064/
frame:
http://flickr.com/photos/jskowski/99...7594544781064/
good luck
Unread 20-03-2007, 17:28
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
module
frame:
good luck
wow, that's a really nice drivetrain...
Unread 20-03-2007, 18:49
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Although i have never made a swervedrive, drivetrians are my "area of expertese" (although take that with a grain of salt, because i have only actually built one)
Assuming you can get any material that exists, i'd then start considering what you can do with it (what tools you have, how complex the cut outs can be, etc.) If you don't have a cnc mill, or a mill at all, then maybe some crazy aluminum contraption isn't the best for your team. Just ask the people who would be cutting/bending the meterial. lighter would be better, however, considering that a swerve drive is going to be a bit hevyer than kitbot drivetrains (generally more material and more complexity/parts)
There is a diference between independent (or paired) controll of modual rotation with respect to robot frame, and then haveing "one motor" like you said controlling all moduals, such that they all point the same way no matter what.
basically:
Independent controll means more motors, and slightly more freedom/complexity for the driver. also mechanically redundent as long as your wheels can be powered forward and back independently.
"one motor" controll means less motors, and generally makes things easyer on the driver. however to rotate the robot around an axis, two wheels will have to turn forwards, while two wheels turn backwards. lots of skiff here, because it's impossible to posititon wheels at a tangent to the "circle" your rotateing about. I hope you understand what i'm saying here.
Because i've never intended to make a swerve drive ( i prefer "holonomic" drives (mechanum or all omni-wheels)) i haven't the slightest clue how to mount a modual. I'd go find someone from "bomb squad" team #16. this year they sported a 3 wheeled swerve drive at the kansas city regional. they'll have some time to talk because I don't remember them winning anythng, although i don't know if they are goign to nat's just becasue.
hope that helps...
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 20-03-2007, 19:00
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Putting more functions on the bot should not make the driver's job more difficult.
A good programmer should be able to make nice interface from a simple 3-axis joystick. Push forward to go forward, push sideways to go sideways, rotate it to turn. Bonus points for using the gyro to make directions relative to the driver rather than the bot. (Careful, though, you may have to buy a faster gyro - the KOP gyro maxes out at 80 degrees/second. Found that out the hard way.)
Real programmers use vim.
Swerve/Crab Rob2713g Technical Discussion 5 12-11-2006 22:05
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
Crab/Swerve/Synchro Pics Joe_Widen Technical Discussion 6 15-04-2006 20:54
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
