Go to Post I would rather KEEP the structural integrity of my skull, thank you. - carpedav000 [more]
Unread 20-03-2007, 18:40
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Most Unique Features
Originally Posted by Nuttyman54 View Post
Team 190's gripper uses one piston to both close our claw and raise the tube up to a 55* angle all in one motion. In addition, the top digit is a 4 bar linkage that curls around the tube, giving us maximum wrap, while allowing it to fit within our starting box. The grip surface is covered with 30 durometer polyurethane (similar to Dr Scholl's gel insoles in properties). The entire gripper weighs 7lbs including piston.
Our "wings" have a number of innovative features. They are made from sheet metal aluminum, and no one piece is thicker than 1/16". They have over 2000 dimpled holes in the top for strength and traction. Inside each wing is a complicated string system that activates various features automatically as the wings deploy:
1) There is a bungie attached to the outer wing sections that pull them out as the wings fold down.
2) One string attached to each of the three pistons keeps them within the starting box. These slacken to let them pop out.
3) A lexan anti-rollback device is also held down by a string which slackens with the bungie, allowing it to pop up.
4)the pistons lock into place with a ratchet system, to keep them from folding under when firing.
The wings have a constant slope of 12*, and an initial lip of 3/4". Thus, any robot with more than 3/4" ground clearance and sufficient drivetrain power can get up. The top lifting surface is 37.5" wide and and 36" long, so most robots can fit no problem. Once a robot is up, the pistons fire, raising them to 12.5". If the pistons malfunction or the robot does not make it up in time to fire, the anti-rollback device will keep them at 5" (these actually caught 1280 and won us SVR)
To reset, pins are removed from the capstans to unlock them from the globe motor shaft. The driver can then manually rotate the wings back into position.
When folded, the wings are held in place with cotter pins attached to a servo on the elevator. This doubles to keep the wings from deploying early, as well as providing strength and protection to the elevator.
Your ramps were the only ones I considered equal (or better ) than ours at BAE, and you had that wonderful arm too (I was sooooo green with envy).
What a great 'bot you all have there.
___________________
- Tennyson, Ulysses
Unread 20-03-2007, 19:16
AdamHeard's Avatar
Lead Mentor
4) the pistons lock into place with a ratchet system, to keep them from folding under when firing.
Your ramps have to be the most (not over) engineered of any team out there. They're awesome. Goodluck
Unread 20-03-2007, 19:24
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Gotta give some love to the ramps on 461 - watching that unfold was awesome. And I'll never tire of watching 1555 or 1501 lift two robots well after the final buzzer. Last shameless plug: LOLLIPOP!
Hi!
Unread 20-03-2007, 19:37
edboy's Avatar
edboy edboy is offline
Plays well with others
AKA: Patrick
FRC #1261 (Robolions)
edboy is on a distinguished road
our teams tube manipulator is extremely effective
using rubber rollers we simply run into a tube and it grabs it
we drive up to a tube and within a fraction of a second we have an extremely strong grip on the tube
it holds the tube at a slightly elevated from horizontal angle, about 30 degree, so it is easy to place on the rack
Inventor Submission, Look at bottom of file
That match was probably one of the most amazing displays of agile mobility I have seen in a FIRST competition. We were all convinced that 1261 had
been hiding their talents up to that point, and finally decided to really show their capabilities. And when they did, was it ever impressive!
Dave Lavery
DAVE LAVERY OWNZ
Unread 20-03-2007, 19:41
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
We designed our robot to do "drive by scoring." Meaning, we were able to score a ringer while still moving, thereby elimating a lot of the defense that would be played against us. The inspiration for this design came from two teams, Wildstang in 2005, and Rhodewarriors in 2006. Both teams scored off the side of their robots, and were able to use their drivetrains to ward off most defensive attacks.
We accomplished the same effect by allowing our grabber to rotate 90 degree to the left and right after picking up a ringer. The picture below shows the extra degree of freedom we have with our manipulator. As I said, in theory this mechanism works great. However, we found it very difficult to actually have any room to drive around in, nevermind a clear shot at any side of the rack. Fighting your way to/from the rack seems to be about the only way to score this year. (Unfortunately...)
Here's the picture of us in "drive-by" mode.
We powered this "wrist" mechanism with a window motor, geared down about 6:1. We tried two different codes to operate it. The first had the arm mimic the joystick position, so the co-driver had to hold the joystick in the position he wanted the arm to be in, with position feedback controlled with a gyro. The 2nd mode of operation allowed the co-drive to only use the joystick to move it to position, just like an elevator or arm. We then used a "home position" button to return the arm to it's vertical position, again controlled by the gyro.
Feel free to ask more questions. Hope it opens up some ideas for other teams.
BEN
Unread 20-03-2007, 19:48
CraigHickman
Posts: n/a
Our robot starts out in the 4 foot category, then locks up a 10 foot elevator. Anyone who saw it at PNW or Davis knows what I mean.
And we have two cameras. Because remember, it's as Mark Leon said at SVR last year: "CMU cam, it's just that easy." So we went with two.
Unread 20-03-2007, 20:16
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I absolutely love all of the features that our team was able to work into our robot this year (seen here), it's flippin' sweet! A short list:
Arm:
-Light and strong! I think the entire assembly weighs under 20 lbs with camera, motors, wiring, etc.
-Single jointed, runs off of a single 125:1 banebots motor (which has survived an entire competition with no problems at all)
-Completely modular: Mast comes off with a single bolt! Motor and joint mounts are held on with clamps so they can be easily adjusted with just two bolts.
-Awesome materials: 1/16" thick, 3" wide round alluminum tube for mast, 1/8" thick 2" wide tube for top part of arm. Neither are breaking any day soon.
Drivetrain:
-Made with 4" wide, 1/4" thick fiberglass I-beam. Fairly indestructable.
-Best part of robot: 4 out of the 6 drive trains on the robot have their tensioners built into our Andymark transmissions. They weigh virtually nothing and take up almost no space. (seen here)
Unread 20-03-2007, 20:24
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
One neat feature that caught my eye this year was the "easy button" feature from team 386 (Voltage). They have an easy button mounted by their gripper, so when they are ready to score, the easy button is right in the middle of the tube. When the easy button hits the plates on the spider, the grabber automatically lets the tube go and caps the ringer.
Unread 20-03-2007, 20:41
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Two unique things about our robot:
Our kicker wheel - it picks tubes off of the floor and turns them vertical
Our grabber - it opens from the inside of the tube, and holds the tube vertically. The long arms of the grabber act as guiding mechanisms so that when we drive up to the goal, the spider foot is pushed into the center of the grabber, where an IR sensor triggers closing the grabber, which shoots the tube onto the goal.
Real programmers use vim.
Unread 20-03-2007, 20:46
JYang's Avatar
JYang JYang is offline
AKA: Jenny
JYang is just really niceJYang is just really niceJYang is just really niceJYang is just really nice
The things unique... our transmission, gripper, wheels.
Unread 20-03-2007, 21:16
Taylor's Avatar
AKA: @taylorstem
This system really was quite elegant, and anybody unlucky enough not to see it needs to come to Indianapolis for a private showing. Winner of the BMR Xerox Creativity Award, and well-deserved.
Hi!
Unread 20-03-2007, 21:32
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
One of the nicest things about our robot is the modularity of it all. The entire ramp mechanism can be detached with two bolts, the pneumatics system and support frame for our ramp can be detached with four, each drive module can be detached with four, and the electronics board can be detached with four. The connections to the pneumatics board (all eight spikes) are all done with 15 pin connectors, and the motors are connected to the main electrical system with mini Anderson connectors.
The most unique design factor is our ramp. The following animation shows how it works.
Another nice feature is the built in wheelie bars on our drive modules. If you were to loko at our bot, you wouldn't even realize that the curves did this. The wheelie-bar effect can be seen in this next animation.
And Unique in the fact that we were one of the few teams that decided to go for a low-scorer is our arm. Only the bottom rung, but man can we score fast. ~5 tubes a minute now that we've gotten a little practice. (I'll throw the animation in for kicks, too)
Unread 20-03-2007, 21:35
Adamskiy's Avatar
Adamskiy Adamskiy is offline
Team Founder
AKA: Brandon Adams
FRC #1261 (RoboLions)
Adamskiy is on a distinguished road
Those rollers were actually polyurethane, no?
And of course, we can't fail to mention the uniqueness of our control system
Team 1261 - Motorola/Cognex/EMD Software & Peachtree Ridge High School
- 2005 Peachtree Regional Champions
(Thanks 281 and 801)
- 2006 Peachtree Regional Champions (Thanks 1414 and 1057)
- 2006 Peachtree Regional Delphi "Driving Tomorrow's Technology" Award
- 2006 Peachtree Regional Underwriters Laboratories Safety Award
- 2007 Peachtree Regional Innovation In Control Award
(Guitar Hero controller )
- 2007 Peachtree Regional Semi-Finalists (Thanks 1746 and 1057)
Unread 21-03-2007, 11:13
Darkforces's Avatar
Darkforces Darkforces is offline
Froforces
AKA: Taylor Burch
FRC #1875 (Autonomato Atonamatons)
Darkforces will become famous soon enoughDarkforces will become famous soon enough
Send a message via AIM to Darkforces
Our most unique aspect would defenitly be our spine arm. Even though we had programming problems at the florida regional but those are fixed so look out for some crazy onidirectional tube pickupage!
Unread 21-03-2007, 11:18
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The most unique feature on our robot is it's claw which is similair too but nowhere near as cool as the '05 claw.
But at least we have the only manipulator that can give the other robots "the finger"!
Most Impressive/Advanced/Unique/Cool drivetrain you've ever seen sanddrag Technical Discussion 41 03-06-2005 09:31
The most revealing teaser of any team yet!!! TEAM 41's UNIQUE BOT DoomdayX Robot Showcase 10 02-02-2005 20:12
What is your most loved and most hated video games of all time? Elgin Clock Chit-Chat 64 25-10-2004 09:41
What is your most loved and most hated video games of all time? Elgin Clock IT / Communications 8 14-07-2004 18:31
Unique FIRST archiver 2000 0 23-06-2002 22:53
