Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
  #40   Spotlight this post!
Unread 20-03-2007, 21:47
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Anyone lost thier BaneBots Carrier pins?
Does anyone think that instead of welding, a good hit with a center punch in the pin end flush with the carrier plate will tend to swage the pin in place?
Don
[EDIT]: The thought is that you support the far (sticking-out-and-holding-the-gears) end and give it a healthy whack. The pin shouldn't move, but the end of the pin should expand slightly by the displacement of metal from the ding in the end of the pin. BUT one must consider how hard the material is (can it deform elasically enough to increase in size) and whether the carrier plate will 'grip' a pin enough using this method. [/EDIT]
Rochester Democrat and Chronicle Gives Local FIRST Team Thier Own Spotlight Koko Ed FIRST In the News... 27 30-01-2008 11:51
pic: Carrier plate deathbycornchip Extra Discussion 2 18-02-2007 10:51
pic: Pins Pins and more pins CD47-Bot Extra Discussion 26 04-09-2005 23:07
who has combined PVC tubing for thier frame? Alex Cormier General Forum 8 12-12-2004 19:47
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
