Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 17-03-2007, 23:25
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Interpreting motor data
Now that I have the CIM motor data, I was wondering if somebody could help me interpret it. For example let's say that I want to see how much RPMs it will have if X torque is applied. So I look at the torque first to see where x is found, then go up to find RPMs (since RPM is dependant upon torque). Ok that seems like it is right.
But now lets say I wanna find what the max torque of a gearbox will be. For simplicity lets say the ration is 10:1. So that means the torque is multiplied by 10 on the output. So if I have a (once again for simplicity) a 1000 ounce load, I would work backwards and say that 1000 / 10 = 100. This means I look to see where 100 oz/in lays on the x axis then go up to find the RPMs at that load(before the gearbox)? then I divide RPMs by 10 to find the RPMs coming out of the gearbox?
I have never really been formally taught this skill, so any help is appreciated.
-John
Unread 17-03-2007, 23:43
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Interpreting motor data
That sounds Like you have it right. I can't remember off the top of my head the correct way of doing the calculations so that may not be entirely correct.
KK4KQO
http://voltair.us
Unread 18-03-2007, 00:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The RPM the motor will turn depends on how much voltage you supply to it. However, it also depends on how much load is applied to the motor...and the current the motor draws (amps) is also related to how much load is applied.
Also, the motor will work best if you keep the load to about 20% of the maximum (stall) torque, and the voltage to about 80% of the maximum voltage. So if the motor can produce 350 oz-in torque at stall, you would try to limit the load to 70 oz-in or less. If the RPM at maximum voltage is 5300, you would want to run the motor at about 4300 rpm (or less).
To calculate the maximum torque you can get from the motor at it's design conditions, multiply the torque times the transmission ratio. So if you have a 10:1 transmission, you would get 70 x 10 = 700 oz-in torque. Also if you are running the motor at 4300 rpm, the transmission would reduce that by a factor of 10, so the output shaft would turn at 430 rpm.
If you would give us some hints about what you are trying to do with the motor, we might be able to provide some more useful information.
Unread 18-03-2007, 17:20
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I don;t really have a use in mind I am thinking about it. I have a few ideas I am deciding between though. THe main one is gonna be what ratio to use on my personal robot.
-John
Unread 18-03-2007, 18:15
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
I posted some notes on Motor Selection in the white paper section (now CD-Media) a long time ago. Feel free to take a look at it here: http://www.chiefdelphi.com/media/papers/1713
I talked about motor power and gear ratio in there.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 21-03-2007, 03:57
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Thanks for that Ken, I looked it over and did learn some stuff. But Let me aska more specific question about all of this now based on what I am trying to do.
Right now in theory what my robot will have is 6 inch wheels and will be driven by 2 CIM motors running through banebots 12:1 transmissions (I know I have seen all the horror stories about them). So I figured I would start out by calculating the max weight the robot would be able to move. So from looking at the CIM motor specs it looks like stall torque is at around 340 oz-in.
I started out by figuring out the toque after the gear ratio, which is 12:1 so 340 * 12 = 4080 oz-in. then I wanted to convert the units to what is more useful to me. 4080 oz-in * (1 lb / 16 oz) * (1 wheel / 3 in radius) = 4080/48 = 85lbs per motor.
This would turn out to be 170 pounds with a 1:1 outside of the gearbox.
As for sprockets I will porbally be using a 28:12 ration (unreduced representation, 12 tooth drive, 28 tooth wheel) which will result in 170 * (28/12) = 397 pounds
Does this all sound right and make sense how I did it? (in a perfect system)
Also instead of going through and figuring out efficiency stage by stage is there a number people like to use for a overall drive system efficency?
Thanks,
-John
Unread 21-03-2007, 09:55
MrForbes's Avatar
AKA: Jim
That sounds about right. For the planetary transmissions, figure about 90% or so effieciency per planetary reduction stage....so you'd have somewhere around 80% total efficiency with the transmissions and gear reduction.
Also keep in mind that you won't get stall torque out of the motor for very long! it will soon pop the circuit breaker/fuse if you have the electrical system properly built.
And "the max weight the robot would be able to move" depends on how that weight is supported...if it is on wheels, then it takes a lot less force than you have available to move it, but if you are trying to slide it across a very tractive surface, it will take even more force.
Charts/Data on FRC Motor and Joystick Bias NeilS Technical Discussion 1 04-01-2007 13:48
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
HTML version of motor data sheet from FIRST manual Roland Motors 0 14-01-2005 22:13
Training: Interpreting Motor Spec Sheets presentation wanted kmcclary Motors 3 11-11-2003 17:26
